1 Ton XJ - Page 4 - JeepForum.com
post #46 of 286 Old 07-17-2011, 02:32 PM Thread Starter
jkl
Today I got the brake lines hooked back up and bled. Had to switch the axle lines to the opposite sides due to the cherokee frame lines exit from a different location than the CJ did. Hopefully this evening I can get the Jeep turned around so I can start pulling the front axle.
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #47 of 286 Old 07-17-2011, 02:32 PM Thread Starter
jkl
Originally Posted by tucanbob View Post
Originally Posted by Boogalooper View Post
Turning out great I can't wait to see the finished product.
Thanks guys
...now parting out
jkl is offline
post #48 of 286 Old 07-18-2011, 07:15 PM Thread Starter
jkl
The Ballistic Fab coil/lca brackets arrived today!
...now parting out
jkl is offline
post #49 of 286 Old 07-18-2011, 07:31 PM
JeepFreak1982
So why are you on here and not in the garage welding! lol
JeepFreak1982 is offline
post #50 of 286 Old 07-18-2011, 07:48 PM Thread Starter
jkl
If it were up to me I'd be burning some metal right now, but instead I'm watching Sesame Street with my boy.
...now parting out
jkl is offline
post #51 of 286 Old 07-19-2011, 04:31 AM
JeepFreak1982
Thats always a good thing too you gota get him out in the garage with you! My daughter loves being in the garage with me whenever im doing something safe enough for a 4 year old to be around. She'll be a Jeeper one day.
post #52 of 286 Old 07-19-2011, 01:40 PM Thread Starter
jkl
He loves to work on the Jeeps!
...now parting out
jkl is offline
post #53 of 286 Old 07-19-2011, 03:08 PM
JeepFreak1982
lol thats awesome
post #54 of 286 Old 07-24-2011, 05:02 PM Thread Starter
jkl
Guess now it can offically be a 1 ton XJ I had to change my orignal plan of attack as some of my orginal measurements were off. After some remeasuring and planing I got it figured out, I think lol. I'll get some better pics and show what I'm going to do later.
Now I need to decide if I want to fab up my own 3 link and save some cash or buy the Clayton or Poly Performance kit and save time
Orignal Chevy brackets cut off
No more Dana Turdy
Ballistic brackets tacked on
Sittin on factory springs and 33s all the way around. And yes I know that the driver side is sticking waaay out. It was hot, I was tired and after all my hard work of centering the axle I set it down on it's on weight, forgot I had no trac bar and the body shifted to the pass side
...now parting out
jkl is offline
post #55 of 286 Old 07-24-2011, 05:42 PM
JeepFreak1982
Why not use a ford axle so the pumpkin is on the drivers side? Plan to go Dana 300?
post #56 of 286 Old 07-24-2011, 05:53 PM Thread Starter
jkl
Cause I like to be different, but mainly cause I already had the Chevy. Yes Dana 300 but maybe a 231/300 doubler.
...now parting out
jkl is offline
post #57 of 286 Old 08-07-2011, 02:37 PM Thread Starter
jkl
Haven't had to much time to work on the Jeep lately. Have next weekend off but were going camping, I may end up burning some vacation time to get some work done. Today I cut some pipe and made some spring retainers. My plan was to pull the 4.5" springs out of my LJ and put them in the XJ to get and idea on tire clearance so I can order some springs, but I got busy and only had time to make these. Once I get eveything fitted I'll cap them off.
...now parting out
jkl is offline
post #58 of 286 Old 08-07-2011, 05:44 PM
JeepFreak1982
Id make a bigger plate to weld to the tabs on the axle. Gusset it under the side that sits over the housing also. I wouldnt be to comfortable with that as a final design. Unless thats just a temp thing to use just to figure out ride height? Either way i cant wait to see this beast done!
post #59 of 286 Old 08-08-2011, 03:32 PM Thread Starter
jkl
I am going to gusset it better once I make sure eveything is going to fit right. I knew the top plates were going to be offset a little , but somehow my measurements got screwed up and thats how the top plates ended up. Hopefully it will all work out in the end.
...now parting out
jkl is offline
post #60 of 286 Old 08-08-2011, 03:59 PM
JeepFreak1982
Maybe use a square plate? Id want as much welded to the axle brackets as possible.
1 ton , cherokee , chevy , xj
