1 Ton XJ - Page 12 - JeepForum.com
post #166 of 286 Old 11-20-2011, 06:42 PM Thread Starter
jkl
Just got done placing these orders:
Barnes 4WD - 2 DOM sleeves w/bushings, adj. upper link mount, axle link tower and frame link mounts
Liquid Iron Ind. - 2 Johnny Joints and DIY front bumper brackets
Clayton Offroad - 4 square tube inserts, 4 jam nuts and 6 bolts, washers, nuts
Also got the front axle back under the Jeep today. Shooting for front axle placement somewhere around here.
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #167 of 286 Old 11-20-2011, 08:53 PM
andrewmacc
So is that around 3 inches of front stretch? Looks like the ticket to me.
Good to see you're keeping on this.
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #168 of 286 Old 11-20-2011, 08:57 PM
2doorxj
2doorxj's Avatar
good job brother, ill be following this one
2012 Cherokee of the Year
2doorxj is offline
post #169 of 286 Old 11-21-2011, 03:02 PM Thread Starter
jkl
I think it's about 2-3. Once I get everything in place I'll measure the wheelbase and be able to figure it out. The rear is +3 now but may go to 4 if I use one of the offset spring perch holes.
...now parting out
jkl is offline
post #170 of 286 Old 11-21-2011, 03:02 PM Thread Starter
jkl
Thanks!
...now parting out
jkl is offline
post #171 of 286 Old 11-21-2011, 03:16 PM
egodfrey
egodfrey's Avatar
Sorry to hear about your dad.
Nice work on the xj, cant wait to see what it can do.
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #172 of 286 Old 11-22-2011, 07:16 PM Thread Starter
jkl
Thanks. I can't wait till it's done either, hoping to have it drivable in January.
...now parting out
jkl is offline
post #173 of 286 Old 11-26-2011, 10:55 AM Thread Starter
jkl
My Barnes 4WD order arrived yesterday while I was at work. My other 2 orders should be here Monday, and of course I'm on duty again
...now parting out
jkl is offline
post #174 of 286 Old 11-28-2011, 02:19 PM
andrewmacc
Let's see some work!
How's it coming along? I'm trying to find a torch to get my outside front stiffeners sucked up against the big dip in the frame rail (where the motor mount sits on the inside). Can't seem to get it to close up.
post #175 of 286 Old 11-28-2011, 10:05 PM Thread Starter
jkl
Was busy hanging Christmas lights this weekend, but did start drilling rosette holes in the frame stiffeners. Brown Santa showed up today with my other two orders. Hopefully I'll have some time next week to get most of this stuff welded together.
...now parting out
jkl is offline
post #176 of 286 Old 11-29-2011, 05:46 PM Thread Starter
jkl
More parts arrived yesterday! Just waiting on the 2 Johnny Joints being shipped from Currie. Started welding on the driver side frame stiffener tonight, no pics though.
...now parting out
jkl is offline
post #177 of 286 Old 11-29-2011, 08:10 PM
2doorxj
2doorxj's Avatar
I've got the same upper control arm bracket, its nice
2doorxj is offline
post #178 of 286 Old 12-03-2011, 02:51 PM Thread Starter
jkl
My other 2 JJs arrived on Thurs! Today I finished welding up the drivers side frame stiffener. Heres a crappy cell pic.
...now parting out
jkl is offline
post #179 of 286 Old 12-09-2011, 01:36 PM Thread Starter
jkl
Over the last few days I've got to work on it here and there. Plated part of the inner frame with 1/8" plate the used a piece of 3 x 3/16" angle over that and butted it up to the frame stiffener. Plated a small section of the floor with 1/8" to tie the mount into the floor. Had to modify the Barnes upper link mount a bit cause it was a little to big. Just a little cut and bend and it fit better. Have about 4 1/2" vertical seperation on the frame end and about 8" on the axle end. Lower link is going to be roughly 36.5" long and upper about 36".
...now parting out
jkl is offline
post #180 of 286 Old 12-09-2011, 04:29 PM
andrewmacc
]http://i278.photobucket.com/albums/kk93/kevinlatta/XJ/DSC02368.jpg[/IMG]
]http://i278.photobucket.com/albums/kk93/kevinlatta/XJ/DSC02367.jpg[/IMG]
Very friggin' sweet!
You worried about lock-to-lock clearance at all?
I took my lower links to a shop to get a 20* bend in them so that the tire will just fit in the nook of the bend. It will make alignments a little more difficult, but I figured the extra turning radius was worth it. Just waiting on them now.. -twiddles thumbs-
I like the way your upper link turned out - that's on the driver's side of the tube, correct?
I'm a little envious that you decided to make the upper link work like that.. my grinder had a bad day and I'm missing a lot of floorboard now because I wanted the upper link up inside the cabin.
Looking good!
1 ton , cherokee , chevy , xj
