1 Ton 99 XJ - Page 2 - JeepForum.com
post #16 of 202 Old 10-14-2011, 07:04 AM Thread Starter
NHJeep4x4
1987 YJ Wrangler
Originally Posted by sean883 View Post
The stock LCA mounts are angled something like 10 degrees inward and aren't centered on the coil. To use those brackets you need custom frame side LCA mounts.
Or you could use these...
http://www.ballisticfabrication.com/...it_p_1542.html
These look great, but I do not have 5+" of mounting space on the drivers side.
Old:
2.5L, 31s
NHJeep4x4 is offline
post #17 of 202 Old 10-14-2011, 07:06 AM Thread Starter
NHJeep4x4
1987 YJ Wrangler
Originally Posted by Bama_WJ View Post
Looking great man. I'm having the same problem on my front 60 with the driver side. There is even less room on mine that came out of a 03 F350.
Have you come up with a solution? I skimmed through your thread and see that you're still planning on coil springs.
Old:
2.5L, 31s
post #18 of 202 Old 10-14-2011, 07:20 AM Thread Starter
NHJeep4x4
1987 YJ Wrangler
What if I had flex joints on the axle end of the lower control arm; would that still be too extreme of an angle? I'd like to use the brackets I have, because of their compact mounting width- only problem is the mount angle.
Old:
2.5L, 31s
post #19 of 202 Old 10-14-2011, 09:42 AM
jkl
Originally Posted by NHJeep4x4 View Post
I plan to run 37s or bigger with about 6" of lift.
I'll be following this. With the 14 bolt I would run the same height lift but 40" + cause it will be a anchor.
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #20 of 202 Old 10-14-2011, 10:26 AM
Bama_WJ
Bama_WJ's Avatar
Yea, guess you skimmed right over the good stuff. Here is what I plan on doing:
http://pirate4x4.com/forum/showthrea...hlight=dana+60
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #21 of 202 Old 10-14-2011, 10:32 AM Thread Starter
NHJeep4x4
1987 YJ Wrangler
I agree. Tire size depends on what I can get a deal on/what will fit once it's all done. 37 minimum.
Old:
2.5L, 31s
post #22 of 202 Old 10-14-2011, 10:48 AM Thread Starter
NHJeep4x4
1987 YJ Wrangler
Yea, missed the good stuff. I'll probably do a similar setup with the Ballistic bracket on driver's side.
Old:
2.5L, 31s
post #23 of 202 Old 10-14-2011, 01:12 PM Thread Starter
NHJeep4x4
1987 YJ Wrangler
Originally Posted by JeepStar007 View Post
Nice
Hey alright, someone else from NH
Old:
2.5L, 31s
post #24 of 202 Old 10-14-2011, 04:17 PM
sean883
I have the same 3in1 Ballistic brackets on my D60, before i cut the stock frame side mounts off i tried to bolt the axle in to help move the jeep around, even with the flex joints on my RE arms, the control arms would not bolt up. I run a 79 axle with lots of room and i would think you would have to mount your brackets even wider than i did.
I have no problems with 37's and a shaved 14 bolt. Do your 39.5s measure out to 39.5 mounted on your jeep?
Originally Posted by PhilipJ View Post
Your ego fits, the XJ should be fine with room to spare.
sean883 is offline
post #25 of 202 Old 10-16-2011, 05:24 PM
GSSFC
Nice, I'll be following this. Great plans Ben!
Tim
GSSFC is offline
post #26 of 202 Old 10-16-2011, 06:10 PM
jkl
IIRC, on the jeep they measure about 38.5 @ 20 psi.
...now parting out
jkl is offline
post #27 of 202 Old 10-16-2011, 08:20 PM Thread Starter
NHJeep4x4
1987 YJ Wrangler
Tim
How did you like the front spool? I was considering it for some cheap, reliable, temporary traction up front. I figured I would unlock a hub on the street (or both), and then lock them once on the trail. How was the steering off road?
I plan to have it street legal, but not necessarily street-comfortable.
Old:
2.5L, 31s
post #28 of 202 Old 10-16-2011, 08:23 PM
GSSFC
Spool is fine. It will pull hard to one side if you just unlock a hub and try to drive in the snow or ice. Off road it works great, just like an OX or ARB engaged. It's definitely the way to go, no moving parts and reliable.
Tim
GSSFC is offline
post #29 of 202 Old 10-16-2011, 08:31 PM Thread Starter
NHJeep4x4
1987 YJ Wrangler
Tim
Sounds good; I am definitely a fan of simplicity and reliability. The 14 bolt is either going to be spool or mini spool, since the carrier is so massive. The mini spool from ECGS has a lifetime warranty.
This is not a daily driver.
Old:
2.5L, 31s
post #30 of 202 Old 10-16-2011, 09:57 PM
Sgt.Fuzz
Subbed.
My build:
Sgt.Fuzz is offline
