1 Ton 99 XJ - Page 12 - JeepForum.com
post #166 of 202 Old 02-22-2013, 07:56 PM
Jersey59
Looks badass man
98 Jeep Grand Cherokee 5.9 Limited - Lifted 4" ~ 33" Firestone MTs, 3" Skyjacker Springs, 1/1.5" BB, Bilstein 5100's, RC SB Quick Discos, Rusty's TB, RC Fixed Front LCAs, Rock Krawler Adjustable Front Uppers, Skyjacker rear LCAs, Safari Style Snorkel, ARB Bumper with custom stinger, Smittybilt XRC 10k Winch, EBC Greenstuff
Jersey59 is offline
post #167 of 202 Old 04-13-2013, 04:56 PM Thread Starter
NHJeep4x4
1987 YJ Wrangler
I haven't had a lot of time to work on it lately, but got a few things done. At least the axles are in for the last time! I cleaned and painted the rear suspension and frame work, etc. I started putting drive shafts together. I didn't want to mess around with changing driveshaft lengths, so I found a couple that fit just right. The front is out of a 1996 Dodge Ram, and the rear is a ZJ front shaft. I need to put in the gas tank and extend the lines, then I'll finally be able to get it running again.
I rolled it outside just for kicks, and I'm really liking the height and width. I'm not a fan of the departure with those shackles, but we'll see what happens. Don't mind the ratchet strap crossmember and wood block; it's temporary.
Sweet gas tank clearance...
Approach angle looks good...
Old:
2.5L, 31s
NHJeep4x4 is offline
post #168 of 202 Old 04-13-2013, 07:47 PM
Bama_WJ
Bama_WJ's Avatar
Looks good. I really like that stance. Not wide as hell, but just wide enough. I guess having a not-so-wide tire and shallow wheels helps with that.
Originally Posted by NHJeep4x4 View Post
And is it just me or does the front tires look like they're doing this... \ /
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #169 of 202 Old 04-13-2013, 08:12 PM Thread Starter
NHJeep4x4
1987 YJ Wrangler
Yeah, they're doing that. When I put the front end back together, there were some thin disks left over, which mounted behind the spindles. I wasn't sure what they were, so I just left them off. Turns out, they are slightly tapered and adjust the camber angle. They'll go back on later.
Old:
2.5L, 31s
post #170 of 202 Old 04-21-2013, 12:40 AM
aircruiser
aircruiser's Avatar
Nice work man, I wouldnt worry about those shackles hanging low, something will hit eventually and shackles can take the abuse. Any idea on the back spacing on those wheels? I am eventually swapping in tons and dont want it to be overly wide either.
aircruiser is offline
post #171 of 202 Old 04-21-2013, 09:10 PM Thread Starter
NHJeep4x4
1987 YJ Wrangler
The backspacing is around 6". With 1/2" wheel spacers in front, the wheels just clear the tie rod ends.
Old:
2.5L, 31s
post #172 of 202 Old 04-22-2013, 01:25 AM
andrewmacc
Aircruiser, a popular option are the H2 rims that are 8-bolt pattern, 17" dia., about 9" wide, and have 5-5/8" backspacing. They're awesome and look pretty darn good. I've got a bunch of pics of them mounted on my Jeep in my build thread if you want.
Looks awesome! I'm tempted to buy some camber plates, I have a little bit of funny camber as well, without any plates. I've heard that's fairly common.
When you get it driving on the roads, you'll have to tell me how your 3-link acts on the road. I'm inboarding my lower links some, they were parallel like yours but I felt that they gave me oversteer in the front which made it a little twitchy.
Keep it up!
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #173 of 202 Old 05-18-2013, 06:57 PM Thread Starter
NHJeep4x4
1987 YJ Wrangler
Got the exhaust and crossmember back in, plumbed the rear brakes, ran fuel lines and extended the pump wiring, and topped off the diffs and t-case. I can drive it!
Here's my temporary tank setup until I make the cover and steel straps...
The rear actually flexes more than the front; the leaves seem to be pretty soft. I still don't have rear shocks yet either.
Much more than this, and I can pick up the back corner. I may put wheel spacers in the rear to widen the stance a bit...
Still have a lot to do, but it's great to be able to drive it!
Old:
2.5L, 31s
post #174 of 202 Old 05-21-2013, 01:54 PM Thread Starter
NHJeep4x4
1987 YJ Wrangler
A few things...
-I replaced the battery so I don't have to jump start it every time.
-I realized that I forgot to disconnect the front sway bar, which is why it wasn't articulating very well. Felt kinda dumb.
-One of the old rusty brake lines under the hood ruptured, so no more brakes. This made driving around the yard interesting, especially since if I forget and use the brakes, I get white brake fluid smoke under the hood from it spraying on the motor.
-There are also some interesting things going on with the lights. One of the headlights only works on hi beam. The blinkers don't work, except for the emergency flashers- but then only one side in the front works- no rears. The 3rd brake light stays on whenever the ignition is on.
-While diagnosing a fuel delivery issue, I managed to crack the port on the fuel rail, so no wheeling for me this weekend after all. A replacement fuel rail is on order.
-Something is leaking on the driver side. It appears reddish, so I thought maybe trans fluid, but I see the engine coolant level has dropped some. Needs more investigating.
Old:
2.5L, 31s
post #175 of 202 Old 06-29-2013, 05:13 PM Thread Starter
NHJeep4x4
1987 YJ Wrangler
Well since last time, I've replaced the fuel rail and front brake lines under the hood. The motor runs pretty decent and the brakes are good. They feel pretty soft, even after bleeding, but they stop fine, so I guess I'll forget about it. I installed Brown Dog motor mounts. So now I have their brackets and mounts. In 4 low and drive, holding the brake, the Jeep will raise up an inch or so, and then go back down once you release the brake or go back into park. There is a noticeable, direct power transfer with the poly mounts.
I disconnected the sway bar and things work much better.
I finally got rear shocks. I had been driving up and down my road without them, and it's much better now.
Found a spot for the spare tire...
I wanted it inside, but it wouldn't fit behind the back seat without blocking the view. I doubt I'll use the back seat much, but I still have it if I change my mind.
Most of what's left to do is only stuff to make it street legal. I think I'll hold off on that, since I just want to go wheeling. So, I ended up getting a trailer for it. I do want to be able to drive it around town eventually, and drive to a few local spots, but even then I'd like to be able to haul it long distance. Besides, I can think of a lot of other handy uses for a trailer. I got it 20' and 10,000 lb gross, so I can haul a full size truck, or whatever.
The only last hurdle is to remedy an upper link/driveshaft contact problem. Unfortunately, I didn't have the shaft when I built the front suspension, and there is contact when the driver side is compressed. There is some adjustment in the frame mount, and I think I'll have enough to work with there. Other than that, I just need to bed line the floor and rear wheel wells, do some minor exhaust work, reinstall the interior panels, install a hitch for recovery and I'm good to go!
Old:
2.5L, 31s
post #176 of 202 Old 06-29-2013, 08:43 PM
propjockey2002
This rig is freakin amazing and your welds are very pretty. Good job, hope to see trail pics soon.
My build
propjockey2002 is offline
post #177 of 202 Old 07-21-2013, 06:46 PM Thread Starter
NHJeep4x4
1987 YJ Wrangler
Got to try it out for the first time today! I hit up some local spots with friends and found out what needs tweaking. I need bump stops really bad. I forgot how I like to go fast, so now my wheel wells are a different shape. I have some steering linkage contact, so I need to move the front axle back a bit. I learned not to continue wheeling with the winch control routed to the window, because a branch could rip it off and then I'd need to replace it. It stalled on me three times before I noticed the bad ground on the ignition coil. I need to re-route the fuel lines because the tank pinches them a little, slowing the flow. I have death wobble at just under 30 mph... but not at 40
All in all, I'm learning how it behaves with the new setup, and it's a blast to drive. I always ran open diffs before and I'm loving the spools. No problems running the rear spool, even on pavement. It's only really noticeable when you turn really tight on pavement. Even then, it's not bad at all. I locked the hubs once I was on the trail and having a spooled front is awesome. No weird turning in the dirt.
Nothing too hardcore, but a lot of fun...
Old:
2.5L, 31s
post #178 of 202 Old 07-22-2013, 02:22 AM
andrewmacc
Woo!
Looks awesome.
Yeah my first time actually doing harder stuff I realized how badly I needed bumpstops, too... especially since I was bottoming out the coilover (soft coils). Dropping off stuff and hearing a bang was heartbreaking.
I'm jelly of your sway bar.. my stocker won't work with high steer.
Now, I've gotta ask you to clarify.. spooled front and you noticed nothing detrimental enough to unlock the hubs? Did you do any sharp turning on the trail? I'm trying to save $300 and just weld the front end for now, but I haven't wanted to have a grueling time on the trail stuck "spooled", or especially ripping through the logging roads to the trail with the hubs locked.
post #179 of 202 Old 07-22-2013, 07:31 AM Thread Starter
NHJeep4x4
1987 YJ Wrangler
I basically left the front hubs locked the whole time I was on the trail. Most of the trail was loose, and the steering seemed pretty normal. I did do a lot of tight turns, and it was fine in the dirt/loose spots. I did have to turn tight a few times on exposed ledge, so like pavement. It was a little jerky, but not as bad as I expected. I see no problem leaving them locked. Especially if you're just going to weld it; if you don't like it, you didn't lose anything trying it out.
I think a selectable would be nice up front; but after trying spools, I find they're not as bad as I thought they would be. Granted, I would unlock the hubs if I was driving down the road, but spools are great for me since my rig will see very little road use. Besides, it's nice to not worry about breakage or if the locker is engaged.
Old:
2.5L, 31s
post #180 of 202 Old 07-22-2013, 10:32 AM
ibjeepin95
I've skimmed through your build and it looks like a nice build. But I must say, the angle on your rear shocks are terrible. You can't be getting much use out of them being mounted like that. Ever thought of running them through the floor to a set of hoops?
ibjeepin95 is offline
