'06 Rubicon build. - Page 4 - JeepForum.com
post #46 of 54 Old 03-22-2012, 03:31 PM Thread Starter
Fusco
2016 JK Wrangler
Finally done traveling with work. Spent some time with a lonely Jeep in the garage.
Herculiner the tub. Came out kinda good considering I hate painting and this project similar.
While that was drying I installed the Tom Woods rear drive shaft. I'll have the rear adjustable control arms installed this weekend to take care of the slight drive line vibe.
After that I want to start to Herculiner the undercarriage. It'll be done in sections working my way down from the body, frame and then axels. It's going to take a while but the long term investment its worth it. The fight against all man rust. Even though outside the exhaust system there's little to no rust.
2016 Jeep JK 2D Sport S
2006 Jeep TJ Rubicon Impact Orange - SOLD :-)
Fusco is offline
post #47 of 54 Old 05-17-2012, 02:27 PM Thread Starter
Fusco
2016 JK Wrangler
I decided to upgrade the sound system from the stock 7 speaker set up.
Went with the Kenwood Excelon KDC-X696 head unit. I wanted Bluetooth Audio Streaming and Phone.
Then the Polk db series Speakers for the 2 in the roll bar, 4 in the dash and the sub.
UPS will deliver new toys tomorrow....I'll do a before and after audio clip.
Fusco is offline
post #48 of 54 Old 02-08-2014, 06:52 AM Thread Starter
Fusco
2016 JK Wrangler
Jeep is out of service as I'm installing new shocks (top rear bolt is a mofo) and hubs.
So I haven't been wheeln in a while. Attached is my wood cart articulation, as u can see I air down haha.
Fusco is offline
post #49 of 54 Old 05-16-2014, 07:47 PM Thread Starter
Fusco
2016 JK Wrangler
Installed Currie HD tie rod and drag link setup. The rig drives 100x better...should've done this a long time ago. Next up is the Metalcloak arms
Fusco is offline
post #50 of 54 Old 07-10-2014, 01:04 PM Thread Starter
Fusco
2016 JK Wrangler
My rig usually idles at 500 rpms, she has 81k on the clock.
Yesterday she started up and was idling at 1000 rpms and the engine was shaking. I was getting a P0300 Random Misfire and P2308 Ignition Coil C Secondary Circuit.
I changed out the plugs last summer about 8k miles ago with the NGK plugs. Had no issues since the install. So I decided to change out the plugs for the Autolite APP985. Started her back up, engine was still shaking, code P0300 was gone but still had P2308 showing up.
I did change out the Ignition Coil Sept last year. It was the Crown model #56041476AA, paid $113 via Amazon. I was pressed for time so I bought the BWD model #18240464 at Advance Auto Parts and paid $104.
So with the plugs and coil rail replaced she started right up, no codes/shake and shes back to idling at 500rpms.
Hopefully this will help other late model TJ owners.
-Fusco
Fusco is offline
post #51 of 54 Old 07-12-2014, 12:21 AM
Aaleck
2011 JK Wrangler
Looks good! What did you decide?
Aaleck is offline
post #52 of 54 Old 12-13-2015, 03:48 PM Thread Starter
Fusco
2016 JK Wrangler
Installed the Metalcloak control arms all around...worth the money.
These things are built like a beast.
Fusco is offline
post #53 of 54 Old 12-13-2015, 03:55 PM Thread Starter
Fusco
2016 JK Wrangler
Had KO2 35s installed.
They ride quality is very good and the larger tire changes the entire appearance of the Jeep.
Vanco 16" BBk, BM rotor/pads all the way around and new HUBs on the way. Shot out to Blaine at Black Magic brakes...that guy has patience for 20 question emails!
Fusco is offline
post #54 of 54 Old 12-14-2015, 02:07 PM Thread Starter
Fusco
2016 JK Wrangler
I need some input please.
BM Vanco 16" BBK is on its way along with new HUBS and BM rear rotors/pads.
I'd also like to install a Trans and Steering cooler. Can anyone recommend a brand?
I have Currie steering installed with a OME steering stabilizer already. I don't need dual stabilizer right for 35s (KO2)?
Still have the original front and rear track bars installed. Should I upgrade that as well?
Thanks
Chris
Fusco is offline
My 2004 Rubicon TJ Build havoc64 Jeep Builds 90 01-13-2017 08:08 AM
spyder6's rubicon build spyder6 Jeep Builds 4084 03-23-2013 09:59 AM
2004 NC Rubicon Build Hinson Jeep Builds 134 03-04-2011 10:12 AM
BigMike's '09 2D Rubicon Build BigMikeATL Jeep Builds 38 06-30-2010 06:10 AM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 12:04 PM
