05 Rubicon Build with M4WD&Fabricaitons/Fingerlakes 4x4 - JeepForum.com
post #1 of 47 Old 02-21-2012, 10:13 AM Thread Starter
cavmedic
05 TJ Rubicon Build with M4WD&Fabricaitons
This build is on going , so I thought I would share the build so far.
All fabrication and Install was conducted with M4WD&Fabrications located in Rochester NY
2005 Rubicon 6 speed 90,000 picked up 3 weeks ago
Steering
- Currie Steering Kit
- Factory Pitman Arm
- FOX Steering stabilizer
Suspension
- Skyjacker Lower Bent long arms
- Skyjacker Shocks
- Currie Front and Rear Double Adjustable upper Control Arm's
- Currie Aluminum ANTIROCK sway bar
- JKS Front and Rear Adjustable track bars
- RE Front and Rear 4.5 Coils
- 1" Daystar Cab/Body Lift
- 1" M.O.R.E Bomb Proof motor mount
Wheels
- Walker Evans 17' Bead Locks (polished aluminum finish)
- Goodyear MTR-K tires
Brakes
-Vanco 16" Big Brake kit with Blackmagic Pads
- Wizard Rear brackets and rotated rear calipers to front of rotor
Drivetrain
- Tom Woods CV Drive Shaft
- Lubelocker D44 gasket
- Spicer ball joints and U joints
- Ten Factory Rear Axle Shaft
Engine
- K&N CAI
- k&N Drycharger for dry dusty days
- throttle body spacer
Armor
- Custom Transfer/ motor Skid
- Steering box Skid
- Custom Lower Control arm bracket skids
- Riddler D44 Diff Cover
- Genright Front and Rear G3 tube fenders
- Genright bumper
- Savvy tailgate armor
- Under Cover Fab license plate / cb tab
- m4wd roll cage
Top
- Rampage Bowless top
Interior
- Corbeau Seats and 4 point harness
- Bed armored interior
Recovery
- Superwinch 9500 tigershark
- Master Pull synthetic Line
- Viking Shackles
This is how the vehicle was upon delivery.
U.S. Army Medic
cavmedic is offline
post #2 of 47 Old 02-21-2012, 10:16 AM Thread Starter
cavmedic
Just installed Front Lowers and now removing rear lowers
U.S. Army Medic
cavmedic is offline
post #3 of 47 Old 02-21-2012, 10:19 AM Thread Starter
cavmedic
Springs are in, now adjusting the Rear Track bar
Rear Currie's
Tom Woods Drive shaft installed
One side done
U.S. Army Medic
cavmedic is offline
post #4 of 47 Old 02-21-2012, 10:23 AM Thread Starter
cavmedic
Tonight we will be doing the Shocks, Body lift / T case relocation and motor mount lift and hopefully get everything taped so we can test drive it!
U.S. Army Medic
cavmedic is offline
post #5 of 47 Old 02-21-2012, 10:52 PM Thread Starter
cavmedic
Shocks and body lift just installed tonight, with a couple set backs that took longer than expected ( Broken Upper Shock Bolts) , but all in all a great night
The M.O.R.E bomb proof mounts are nice and simple install.
Jeep is sitting on its own weight.
U.S. Army Medic
cavmedic is offline
post #6 of 47 Old 02-21-2012, 10:55 PM Thread Starter
cavmedic
A few pics of M4WD&Fabrications buggy
U.S. Army Medic
cavmedic is offline
post #7 of 47 Old 03-07-2012, 04:52 PM Thread Starter
cavmedic
Currie Steering kit
U.S. Army Medic
cavmedic is offline
post #8 of 47 Old 03-30-2012, 07:51 AM Thread Starter
cavmedic
Just added a custom flat tummy tuck
Engine Skid
Next install will be Riddler D44 Diff Covers with Air locker pump relocation and toggle switches
U.S. Army Medic
cavmedic is offline
post #9 of 47 Old 03-30-2012, 12:14 PM Thread Starter
cavmedic
Riddler D44 Covers just came from ups. I will prime and paint tonight
Thanks to Jeep Forum for the walk though of locker pump relocation
Front and Rear Toggle Switch for Lockers
U.S. Army Medic
cavmedic is offline
post #10 of 47 Old 03-31-2012, 03:35 PM Thread Starter
cavmedic
Primed the covers today, I will let it sit for a few days then will paint it Orange with black logo
U.S. Army Medic
cavmedic is offline
post #11 of 47 Old 03-31-2012, 03:43 PM Thread Starter
cavmedic
Just put base coat on today over primer. Tomorrow I will paint the Logo Black by hand.
U.S. Army Medic
cavmedic is offline
post #12 of 47 Old 04-03-2012, 08:33 PM Thread Starter
cavmedic
Just finished painting Diff Covers.
Will install tomorrow with lube-locker gaskets
U.S. Army Medic
cavmedic is offline
post #13 of 47 Old 04-04-2012, 12:12 PM Thread Starter
cavmedic
Just put front diff cover on, will do rear tonight
Image and video hosting by TinyPic
U.S. Army Medic
cavmedic is offline
post #14 of 47 Old 04-04-2012, 12:23 PM
Imped
Long lowers + short uppers = WTF
OlllllllO
Float Test Build
IndyORV
Imped is offline
post #15 of 47 Old 04-04-2012, 01:34 PM Thread Starter
cavmedic
These long lowers are ment to be used with stock or adjustable short uppers. Adjustables were used over the stock for tummy tuck.. this has great road manners compaired to a short arm and better flex than a short arm. When and at max flex there is no binding or pinion angle change so for my application this is the route i chose to take. If i wanted a true long arm i would go with a tri link front and a 4 link rear from poly performance.. but this wont be untill after my deployment and when i do coil over conversion.
U.S. Army Medic
cavmedic is offline
'06 Rubicon build. Fusco Jeep Builds 53 12-14-2015 02:07 PM
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 07:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 06:10 PM
04 TJ Rubicon Build angrybear Jeep Builds 0 11-19-2011 01:57 AM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 12:04 PM
