04 TJ build up from stock to...... - Page 5 - JeepForum.com
post #61 of 124 Old 05-07-2012, 04:41 PM Thread Starter
RobSheaTJ
Beginning of day 3 photo. Sadly, it looks pretty similar to the end of day 4 (I hate that there even is a day 4). I got the rear shocks, springs, and control arms off and relocated the track bar. Then spent the rest of the day working off the broken upper shock mount bolts that broke off. HUGE PITA! Anyone about to do their first lift, make that an area where you wanna soak soak soak it in PB Blaster and be careful working it out. All 4 of them broke on me and it took about 6 hours, lots of drill bits, and grind wheels to get through them.
"Wha's a Jeep?" Popeye asks Professor Brainstine.
_/l ,[___],
l--L --OlllllO-
()_)()_)-o-)_)
RobSheaTJ is offline
post #62 of 124 Old 05-14-2012, 11:37 AM Thread Starter
RobSheaTJ
Finally done.
_/l ,[___],
l--L --OlllllO-
()_)()_)-o-)_)
post #63 of 124 Old 05-16-2012, 01:44 PM Thread Starter
RobSheaTJ
Need help getting rid of vibrations
I have some slight vibrations since installing my lift. I assume it's related to my driveshaft being at an incorrect angle but I'm a little lost to be honest. Here's some pics I took and some info I found on WranglerForum.
"Your rear driveshaft slope should be at no more than a 15 deg. and the engine/tranny slope should be equal to the rear pinion.
Also, the angles between the driveshaft and tranny/rear pinion should be no more than 3 deg., according to Tom Wood, the known leader for driveshafts.
Here is a picture of the proper geometry for a conventional two joint driveshaft.
I have the Zone Combo, installed the MML and the 3/4" TC drop with a few washers. My driveshaft slope is 15 deg now. The only way to make it less than that would be to drop the TC even more. I can run it like this with minor vibes, but it will cause my u-joints to wear out earlier than normal."
I could use some opinions on these pictures I took. How does it look other than some pretty mean rust?
_/l ,[___],
l--L --OlllllO-
()_)()_)-o-)_)
post #64 of 124 Old 05-16-2012, 09:23 PM
2003X
Hard to tell from the pics, but it does look okay compared to the drawing. I would try the MML first, and see what that does for you. They will lift the tranny 1" possible helping the drive line.
My Build
2003X is offline
post #65 of 124 Old 05-18-2012, 04:13 PM Thread Starter
RobSheaTJ
1" Brown Dog MML and 1.25" Savvy BL is in the mail.
MML
http://browndogindustries.com/CU2883...ts-Rubber.aspx
$99.95
BL
http://shop.savvyoffroad.com/product...&categoryId=-1
$134
_/l ,[___],
l--L --OlllllO-
()_)()_)-o-)_)
post #66 of 124 Old 05-18-2012, 04:34 PM
2003X
Nice choice on the rubber mml.
My Build
2003X is offline
post #67 of 124 Old 05-19-2012, 06:21 AM Thread Starter
RobSheaTJ
They had a nice list of pros and cons on the Brown Dog website. In our neighborhood, I think rubber wins. And also I hate f*cking vibrations. I'll bounce around on brand new stiff springs all day and that's fun, but no vibes.
_/l ,[___],
l--L --OlllllO-
()_)()_)-o-)_)
post #68 of 124 Old 05-19-2012, 07:59 AM
2003X
Rubber is the way to go.
My Build
2003X is offline
post #69 of 124 Old 05-29-2012, 03:21 PM Thread Starter
RobSheaTJ
Took the Jeep on a trip to Lake Winnipesawkee this weekend then down to the Cape. Ran great other than a little bit of death wobble at 45 mph. The trip ended in my getting towed back from Harwich MA when an idler pulley got depressed and blew it's brains out all over the underside of my hood yesterday. Took a trip to autozone, got a replacement, and threw it in in less than ten minutes. Back on the road.
Next step will be MML and BL which are on backorder from Brown Dog and Savvy respectively.
Then it'll be time to get some 33's, seat risers, a Poison Spyder hood louver, a Brute Force CAI, and change my back window to the tinted window i have waiting (can't get the back window off right now, zipper is stuck).
_/l ,[___],
l--L --OlllllO-
()_)()_)-o-)_)
post #70 of 124 Old 05-31-2012, 02:50 PM
billy_butler
you can look up death wobble videos on youtube and they will help you find exactly where your problem is comming from, i replaced my steering linkage with a heavy duty one... my steering has been great with 35's and a 4 inch lift ever since. your best bet with the vibrations is going to be to remove your front drive shaft and drive it, if you still have vibrations then you have isolated it to the rear and you will need to go ahead and get a SYE and new rear drive shaft. i recomend doing this anyway. if there are no vibrations when you take the front drive shaft off, then you have to start looking into getting a new front driveshaft.
billy_butler is offline
post #71 of 124 Old 05-31-2012, 06:44 PM Thread Starter
RobSheaTJ
I've still got a steering stabilizer to install. Would be awesome if that took care of it but I do'nt have my hopes up.
_/l ,[___],
l--L --OlllllO-
()_)()_)-o-)_)
post #72 of 124 Old 06-01-2012, 12:19 PM Thread Starter
RobSheaTJ
Just got an oil change. The guy talked me into wheel balancing too which I'm wicked happy about because he showed me the machine and they were waay off. And now.....NO MORE DEAATH WOBBLE!!!
Still some vibes in 3rd so I'll work that out next.
Also, traded my stock suspension parts (front and rear shocks, springs, and sway bar links, and front track bar) for brand new shiny parts that some guy was stuck with. I was literally about 3 hours from bringing them to a dumpster when this guy emailed me and I'm now the proud owner of a black fuel door cover, chrome tail lights, and chrome tail light guards. Not a big fan of chrome but I know someone will be and I just like parts.
I'll be doing a little more business with this guy when my steering stabilizer comes off this weekend. See what else he's got.
_/l ,[___],
l--L --OlllllO-
()_)()_)-o-)_)
post #73 of 124 Old 06-01-2012, 01:58 PM
Ak-max
My upper shock mounts broke off on my TJ when i lifted it too! you arent kidding by saying its a PITA. I had to cut some nice 4" holes in the tub on both sides just to get a cut off wheel in there to cut the mounts off. took a good day just to do that. Then patched it up with some new sheet metal. Gotta love salty michigan roads
Ak-max is offline
post #74 of 124 Old 06-01-2012, 07:54 PM Thread Starter
RobSheaTJ
Dremel tools are lifesavers.
_/l ,[___],
l--L --OlllllO-
()_)()_)-o-)_)
post #75 of 124 Old 06-15-2012, 10:35 AM Thread Starter
RobSheaTJ
Motor mounts came in the mail. Along with a wicked high tech alarm system for my jeep that makes noise and shoots fire and bees at anyone trying to break in (not really, it's just a blinking red light wired into my ignition Dont tell anybody.)
Sold a spare soft top today to pay for some Rampage Nerf Bars I'm gonna buy tonight.
Also gonna buy a tow receiver on Sunday. I wanna get a rack to plug in for road trips.
Still waiting on the Savvy BL.
Also traded my old suspension parts for new tail lights and guards which I gave to YJ1994 and kept a fuel door cover, also from the trade, for myself.
_/l ,[___],
l--L --OlllllO-
()_)()_)-o-)_)
MY TJ build from stock Contra Jeep Builds 2 06-13-2013 11:27 AM
97 ZJ build, completely stock to whatever it turns into.... sixety8msg Jeep Builds 24 10-13-2010 08:07 PM
ZJ Build Stock until now. Monsterkx117 Jeep Builds 0 09-07-2010 02:24 PM
ZJ build stock to now paintball10148 Jeep Builds 3 05-25-2010 08:11 PM
My build from a stock 97 SE $lick Jeep Builds 14 05-06-2010 08:22 AM
