04 Rubicon build - Page 5 - JeepForum.com
post #61 of 91 Old 06-06-2012, 05:30 PM Thread Starter
GregStephens2
Should be getting it on the RTI ramp in two weeks just to see what it will score.
Yes I know poser shots but I was out checking the new rear shock travel after moving the axle end brackets and making sure I had the bump stops set up correctly.
Greg Stephens/Arboreal Specialties
http://www.arborealspecialties.com/Home.html
GregStephens2 is offline
post #62 of 91 Old 06-07-2012, 11:20 AM Thread Starter
GregStephens2
Originally Posted by FirstTJ12321 View Post
the lite dots look amazing i'm really jealous. the black on blue looks really good, too. good luck with it!
about how much cash you put into it total?
Hmmmm there's just under 30k in parts and about 8k in labor for the stuff I either don't have time to do or can not due to the lack of the needed tools.
post #63 of 91 Old 06-07-2012, 02:49 PM
02crewcab
sick rubi man!
02crewcab is offline
post #64 of 91 Old 08-07-2013, 03:02 PM Thread Starter
GregStephens2
Ok so after getting tired of the lame *** ps box and system I was stuck with via Chrysler.
I decided to upgrade to the PSC extreme trail assist set up.
I should have done this a long time ago........
post #65 of 91 Old 08-08-2013, 07:27 AM
Holaday
Looks good man. That is my next purchase. Did you get the full kit?
Also, can you snap a pic of what you did with your Track Bar mounts? They are not in the stock location right.
Holaday is offline
post #66 of 91 Old 08-08-2013, 11:13 AM Thread Starter
GregStephens2
Yup I got the complete kit with the psc recommended cooler.
I did order the tie rod clamp from poly. I am running a modified ORO U turn steering linkage which made the clamp pretty attractive over welding to cromo.
The track bar mounts are teraflex it is their highsteer track bar set up.
When I did the initial build I chose the fab fours diff covers which are over sized and I had binding issues with the regular T flex track bar.
I'll work on some better pics of the axle side tb and cylinder mounts asap.
post #67 of 91 Old 08-08-2013, 01:33 PM
Holaday
Thanks!
Holaday is offline
post #68 of 91 Old 08-08-2013, 01:33 PM Thread Starter
GregStephens2
Here ya go......
Its not completely clear in the pics but I cut three pieces of 1/4 to add to the tb mount.
Two got welded to tb mount to get the centerline of the hiems as close to the centerline of the tr as possible when completely extended and collapsed. This also helps in getting less twist or roll in tr and tre's while the cylinder moves.
The third was just a brace of sorts to add some strength by connecting the outer tb mount to the inner in a second place inline with the cylinder.
Hope that's what you were looking for?
post #69 of 91 Old 08-08-2013, 01:38 PM Thread Starter
GregStephens2
Ha we posted at the same time too funny..........
post #70 of 91 Old 08-11-2013, 05:35 PM Thread Starter
GregStephens2
This week I should get the in cab winch control wired up and a e fan indicator light.......
post #71 of 91 Old 08-11-2013, 06:59 PM
Holaday
Thanks for the pics. In cab controls will be awesome as well. I hate hanging from a ledge and getting out to connect everything
Holaday is offline
post #72 of 91 Old 08-18-2013, 08:40 AM Thread Starter
GregStephens2
For any one running the flexlite black magic fan you can hook a wire to the manual switch terminal on the relay to make a led indicator light.
it works like a charm and makes tuning the stat way easier.
I also have to say that offroadcontrols.com makes an extremely nice in cab winch control panel.
Seeing I am not a good electrician it took me about two hours to run wire and hook it up but it works perfectly and looks sweet.
Pics are coming.........
Last thing I'll be heading to RC offroad park with the guys from the local jeep dealership on Sept. 7th I know there is a core of guys who are normally up there.
I hope too see them on the trails.....
post #73 of 91 Old 08-18-2013, 01:01 PM Thread Starter
GregStephens2
post #74 of 91 Old 09-08-2013, 11:09 AM Thread Starter
GregStephens2
Just some wheeling pics seeing how Lu and a couple of the guys like to give me ****!
post #75 of 91 Old 09-08-2013, 05:09 PM
AngryTJ
Sweet! You referring to me ? Lol
AngryTJ is offline
'06 Rubicon build. Fusco Jeep Builds 53 12-14-2015 02:07 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 01:59 PM
The Seal Rubicon Build -TJ Seal Jeep Builds 170 06-25-2012 09:01 PM
BigMike's '09 2D Rubicon Build BigMikeATL Jeep Builds 38 06-30-2010 06:10 AM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 12:04 PM
