03 Rubi Build Thread - Page 2 - JeepForum.com
post #16 of 25 Old 04-21-2010, 05:59 PM
WtrHamer97
WtrHamer97's Avatar
Very nice build so far. Real nice Rubi
It is what it is...
WtrHamer97 is offline
post #17 of 25 Old 04-21-2010, 09:30 PM
dhodgee
1997 XJ Cherokee
Looks Great!!! Can't wait to ride in it!!!
-Derek
dhodgee is offline
post #18 of 25 Old 04-21-2010, 09:37 PM
DezertTJ
very nice rubi! i want your lift and tires! haha my 03 rubi will have it a long time from now
DezertTJ is offline
post #19 of 25 Old 04-21-2010, 10:03 PM
mikerzz
your rubi looks great, hows the new suspension ride for you
Mike
03 TJ x in progress
mikerzz is offline
post #20 of 25 Old 04-22-2010, 12:08 AM
Looney
2011 WK
I love the look of that suspension. And those tires are beafy as h3ll.
Just because you are paranoid doesnt mean people arent following you!
Looney is offline
post #21 of 25 Old 10-06-2010, 06:43 AM Thread Starter
rmoonks
After a trip to Superlift ORV park in Hot Springs, Arkansas over Memorial weekend this year, I found that I bent the left rear axleshaft. Seems those big 35" tires put more stress on those axles than I anticipated. Since it needed replacing, I decided to upgrade to Superior Chromoly shafts. Even though they cost more, I'm glad I upgraded. Now that I have the rear done, I'm anxious to replace the frone before I bend or break them out on the trail. I'll probably wait and do the front this winter or next spring.
rmoonks is offline
post #22 of 25 Old 10-06-2010, 06:52 AM Thread Starter
rmoonks
During some routine maintenance this summer, I noticed a couple of tie rod end dust cover boots that needed replacing. The stealership wanted an arm and a leg for OEM replacement rubber boots. Since I plan to upgrade my tie rod and steering link next year to heavy duty Currie bars, and because I don't like getting raped by stealerships, I decide to replace the existing dust boots with some Energy Suspension poly boots. They were much cheaper ($4.00 for a set) and I believe the poly will outlast the rubber factory boots.
rmoonks is offline
post #23 of 25 Old 10-08-2010, 10:38 PM
jlpowell
great work! keep it up!!
jlpowell is offline
post #24 of 25 Old 12-27-2012, 06:30 AM
midnight_f150
How do you like that ARB rear bumper? Nice rubicon any updates?
midnight_f150 is offline
post #25 of 25 Old 12-27-2012, 08:43 PM Thread Starter
rmoonks
Thanks. I like both my front and rear ARB bumbers. I think I like the front better. The rear ARB with tire carrier is pretty expensive and over the years I've discovered others that are less expensive that are probably just as good. As far as other upgrades, I've got Chromoly shafts both front and rear, 4.88 R&P gears, swar bar disconnects, BDS Long Arm Suspension system, and had to put in a new rear locker this summer when I discovered I broke my factory OEM. I went with an ECTED electric for the replacement. In the summer I take the hard top off and run a BestTop Safari top and Duster. I have the wrap around Windjammer for the really cool days if I need it. I've invested in a PowerTank for airing up the tires and running impact tools if needed. In the next couple of months I'm going to upgrade the tie rod and drag link to a Currie heavy duty system. I also plan to put on some A to Z Rocksliders.
rmoonks is offline
87Warrior’s Rubi Build Sequence 87warrior Jeep Builds 53 09-25-2014 11:26 AM
04 Rubi Build Thread GDTIME Jeep Builds 68 04-13-2011 05:58 PM
2006 TJ Rubi Build from bone stock CRWDDYZ Jeep Builds 84 04-12-2010 01:03 PM
Rubi Red, a 99 XJ Build XJAl Jeep Builds 25 03-08-2010 09:48 PM
