02 WJ Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 02 WJ Build
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiWarn, Smitybilt, Engo, Rugged Ridge Winches at CCORIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-12-2014, 06:14 PM   #1
octablack
02 WJ Build
Just picked up this 2002 Grand Cherokee Overland for a steal. The guy before me put 2" pucks on the springs and 265/70's...highway queen'd her up real good. Gotta change that ASAP.
PHASE I
4" Lift
Dual HD Stabilizer
Adjustable Track Bar
IRO Track Bar Flex Joint
DT8000 Shocks
JKS Quicker Disconnect Sway Bar Links
New Coil Isolators
Coil Retainers
CFFL Halos
HID Conversion
LED Tail Lights
Logan's Metal Bumper
Addco HD Sway Bars
A Arm Spacer
ARB Diff Covers
Rock Sliders
Transfer Case/CAT Skid Plate
Helix Throttle Body Spacer
PHASE II
Exhaust Upgrade ~ Wheel and Tire Upgrade ~ Bushwacker Fender Flares ~ IRO Double Cardan CV Front Driveshaft ~ 30 Spline U-Joint CV Axles with ARB Lockers (or maybe an axle swap...who knows...i'm not too familiar with that though)
octablack is offline   Reply With Quote Quick reply to this message
Unread 12-12-2014, 06:16 PM   #2
octablack
Found these Spyder CFFL halos 1/2 off and went ahead and got em.
Unread 12-12-2014, 06:41 PM   #3
octablack
1.5" spacers
Unread 12-13-2014, 09:54 PM   #4
octablack
Nitro 8000's for a quick fix...the old shocks were way past their prime.
part_1418528790918_img_20141213_103623860.jpg   part_1418528801373_img_20141213_121438260.jpg
Unread 12-14-2014, 02:54 PM   #5
octablack
Had some spare wood from where I built this table so I decided to tinker with the idea of using it in my cargo area. It could be a lot better esthetically but I want it to be as light as possible. May spray it black and add some truck bed liner on top.
part_1418590242724_photogrid_1417558008618.jpg   part_1418590051885_img_20141214_144241056.jpg
Unread 12-14-2014, 06:17 PM   #6
Pedro7
Those are oem overland wheels.
KCCO
2000 WJ - Clayton, IRO, MileMarker, Custom Splice, JCR, Bilstein, Rola, Federal Tires
1997 TJ - Restoration completed thanks to: Cooper Tires, Rustys, Rough Country, and Quadratec.
Pedro7 is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 06:52 PM   #7
octablack
Good eye Pedro, thanks.
Unread 12-15-2014, 06:19 PM   #8
octablack
Looking at IRO lifts. Any input?
