02 TJ Build on a Budget - JeepForum.com
post #1 of 5 Old 01-30-2016, 01:48 PM Thread Starter
TJ_Dan
Here's my 02 TJ, Lucy Long. Shes my daily (for now) so my build won't be anything too crazy until I get something else as a daily and can keep ol Lucy as a toy. So far I've:
Hacked the stock exhaust off and replaced it with a Flowtech Redhot glasspack
Cut the front fender flares, removed bumper end caps, and added tow hooks and LED pods
Removed said LED pods and installed fog lights instead (KC Apollo pro 100w) and an Olympic 4x4 front bar
Attached a flag pole holder to the tire carrier, and a rugged ridge cb antenna mount behind the rear tail light for my 5' firestik firefly
I've also replaced my stock (and broken) swaybar links with a set of quick disconnects from Rubicon Express, bought a bikini top and windjammer for the summer, and removed the factory 3rd brake light.
TJ_Dan is offline
post #2 of 5 Old 02-01-2016, 04:39 PM Thread Starter
TJ_Dan
Got my new exhaust on order. Hopefully will be here by the end of the week. Also put together a mod list of the current things I want to do, as well as future things.
Current:
•Replace driver and passenger trialing arm frame sections.
•Rusty's 2" lift
•1" body lift
•Regear to 4.10
•33x10.50 General Grabber AT2'S
•Rear bumper/tire carrier with 2" reciever
•Replace passenger rear fender flare
Future:
•5.5" long arm lift
•35x12.50 M/T's
•Snorkel
•Roof rack
•LED flush mount tails
•SYE
•Tom Woods driveshaft
•D44 or build a super D35 rear diff
•D44 or build super D30 front diff
•Lockers front and rear
•Hard top
•Full steel doors
•Regear to 4.56
•High flow secondary cat
•ZJ steering upgrade
Sent from my SPH-L720 using Tapatalk
TJ_Dan is offline
post #3 of 5 Old 02-05-2016, 06:04 PM Thread Starter
TJ_Dan
Installed my new exhaust yesterday and my missing hanger today. Sounds awesome!
I think it's time for a new steering stabilizer, she likes to wander alot. I'll also check the rod ends to make sure they're still tight and top off my slightly leaky power steering system.
TJ_Dan is offline
post #4 of 5 Old 04-04-2016, 12:44 AM Thread Starter
TJ_Dan
As usual with all projects, plans change. My project is no exception! The previous build plans I posted are NOT what I will be doing to this Jeep. Instead, I'm going with a CJ7 throwback with my own little flare! I've never actually seen anyone do a decent CJ throwback with a TJ other than jscherb, though he used an LJ. I will be doing something COMPLETELY different! He replaced the front clip with custom fabbed parts, whereas I will be just modifying the stock TJ parts and panels to resemble the CJ, but still keeping the TJ styling. I'll be starting a new thread on this because my build plans have completely changed and dont exactly fit in with the "on a budget" theme.
TJ_Dan is offline
post #5 of 5 Old 06-09-2016, 08:26 PM Thread Starter
TJ_Dan
Hella 500FF driving lights installed
TJ_Dan is offline
