Calisdad's Reviews
Price: $300.00 Pros: sturdy, great finish Cons: hardware, needs wind deflection Recommended? Yes
Comments: If you install this before you start take the hardware package down to the hardware store and replace all the allen head bolts with hex head. It's impossible to torque the allen heads tight enough and the rack will squeak and rattle to the point of distraction. It's just fine with hexhead bolts. For the detail minded either find black ones or paint the ones you get.
Hardest part of install were the bolts that go through the windshield hinge. The speaker magnets want to pull the wrenches around.
A wind deflector is necessary to stop the howling that occurs at 55 mph.
Load it up. It's flexes a bit side to side but is quite sturdy.
