Safari Sport Rack 873 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Roof Racks & Cargo Areas Next Product
Rating:
Product Information
MSRP: $700.00
Average Price: $343.33
Manufacturer: Warrior Products
Recommended?
Yes: 3 / No: 0
Company Website: http://www.warriorproducts.com/catalog/TBL_SafariSportRack.html
From the Warrior Products Site:
"SAFARI SPORT RACK The ultimate in sport racks, the Safari Sport Rack is a semi-permanent, modular system. As its base, two independent crossbars mount at the vehicle's windshield and rear tub areas as supports for lights, small watercraft, and/or a cargo basket. Quick release snapper pin disconnects on each crossbar leg allows them to be easily removed from the vehicle (this feature is not available for the Cherokee application). When a cargo basket is not affixed, the crossbars create a canoe and/or sailboard carrier. As light supports, the crossbars have tabs for mounting four in the front and two in the back. Black powder-coated to prevent corrosion, this rack has a carrying capacity of 400 lbs highway or 150 lbs off road."
None
pat_ton69
pat_ton69's Reviews
06-30-2013, 10:19 AM
Price: $450.00
Pros: Easy install and solid build
Cons: Chrome manufacturer tags
Recommended? Yes
Comments: I didn't have OEM rack so this fit the bill with the rain gutter mounts.
Nick601
Nick601's Reviews
02-03-2012, 12:00 PM
Price: $80.00
Pros: good strongly built holds lots lots to tie too.Comes on and off easy.
Cons: Had to come up with rubber to go around roof rack so the mounts tie tend enough to stop it from moving.
Recommended? Yes
Comments: easy to put on looks good holds lots.
Fett
Mechanically Declined
Fett's Reviews
06-04-2009, 11:50 AM
Price: $500.00
Pros: Strong. Able to slide out hard top without removing the rack. Has mounting brackets for lights.
Cons: Must drill tub. Basket is smaller than competitors. Quick release pins rattle.
Recommended? Yes
Comments: I've had the rack for several years now. It's invaluable to me.
It is very strong and I'd feel confident putting the maximum weight up there. Assembly was a little bit of a challenge.
You have to drill into your tub and you have to get it right the first time. Definitely a two to three person job to get the rack properly installed.
There are four mounting brackets on the front and four on the back for lights or what ever you want.
I wish the basket was longer. It doesn't cover the entire top of my Jeep and that's just wasted space.
There are a few spots now where the powder coat is coming off and I'll have to sand/repaint soon, but it's been nearly four years now so that's not bad considering how much abuse/use it gets.
The quick release pins have a ring that rattles on the cage bars and it can be annoying.
I bought mine for under $500 from Desert Rat. I see they still go for $500+
ThreadForumRepliesLast Post
Bestop Safari Bikini Tops 73 01-04-2015 11:10 PM
Sport Rack Cargo Roof Basket 421030 + 421031 Roof Racks & Cargo Areas 2 02-25-2012 07:30 PM
Westin Safari Bar Exterior Accessories 9 10-15-2011 11:15 PM
Bestop Safari Doors Tops 1 04-03-2009 07:47 AM
Coleman Safari Roof Rack Roof Racks & Cargo Areas 1 01-29-2009 09:40 AM
