Custom Built By self or friend
Rating: |
Product Information
| MSRP: |
$10.00 |
| Average Price: |
$266.27 |
| Manufacturer: |
Custom Built |
| Recommended? |
Custom built rack for your Jeep
JRobes's Reviews
Price: $0.01 Pros: custom = awesome Cons: steel... might rust Recommended? Yes
Comments: love the basket... I can haul my bike and kayak anywhere now
94chb's Reviews
Price: $5.00 Pros: saved alot of money, and works great Cons: none Recommended? Yes
Comments: got it built for 5$ cant be any happier
Flat_Black_ZJ's Reviews
Price: $240.00 Pros: It completely changed the look of my ZJ Cons: None Recommended? Yes
Comments: Me and my girlfriends dad built it. It is made completely out of aluminum. It mad a really nice place to put an oversized spare and auxilary lights.
cj13
 Registered User |
cj13's Reviews
Price: $5.00 Pros: I only paid for the bolts used to attach it to my roof Cons: I used cheap paint and now the bars a rusting a bit Recommended? Yes
Comments: My Cherokee did not come with the crossbars, so I decided to weld some up. I knew a local teacher in a vocational school and he let me use the mig welder and some scrap stock. I used 2" angle welded to either end of 2" square tube stock. after 16 welds and some grinding I was done. To mount it I took some 1" bar stock and cut 2.5" - 3" sections and tapped them for 3/8" bolts. I used those bars and the bolts as a makeshift clamp to hold the bars onto my roof. I used rustoleum paint to coat it. After proper prep and priming it still chips off. The only thing I would do differently is to use a better paint.
spudnick639's Reviews
Price: $1.00 Pros: cheap Cons: cheap Recommended? Yes
Comments: cheap and effective. saves space
Price: $1.00 Pros: cheap, effective, and saves space. Cons: cheap Recommended? Yes
Comments: works very nice. holds lights and tire on roof. gives me plety of room inside.
NickyDaP's Reviews
Price: $757.00 Pros: N/A Cons: N/A Recommended? Yes
Comments: Sounds Expensive but when compared to the leading racks actually comes out cheaper. Built by Kevins Off Road or KOR for short. All welded construction. No peicing it together and no rust points. Only rack on the market with front removale floor section for sun roof. Highest side rails on the market. Only rack with rool over rating protection. Standard features include: brackets for mounting, welded shovel and axe brackets, welded high lift mounts, 6 welded light mounts(4 front, 2 rear), welded spare tire carier! Check them out!
Overdubbed's Reviews
Price: $90.00 Pros: everything I need and where i want it.. designed by me Cons: NONE Recommended? Yes
Comments: Spent 5 days designing it to make sure everything is where i want it.. has a locking tool box, locking tire carrier, lock for high lift jack.. 3 4x6 KC off road lights...
CallMeColt's Reviews
Price: $1,800.00 Pros: Best out there. Lot's or room and extras. Strong. Cons: If you live in the woods, do not use the mounts that put the stuff on the outer edge. They will get hit and bend, ect. Also, cost a lot of money! Recommended? Yes
Comments: They did not have the option for it, but this is the Gobi rack for the Jeep XJ. It is the most expensive, but I will say it is 100% worth it. I have hit trees with it and stuff, and nothing it wrong with it. Has a tone of room, and looks sick. I got all the extras with the Highlift jack mount, axe & shovel mount, and jerry can mounts. I ended up breaking the high lift mount because it got hung up on a tree. Has spots for 6 lights on it.
axel4488's Reviews
Price: $20.00 Pros: best thing ever built by me lol Cons: ugly Recommended? Yes
Comments: held over 250 lbs on it without bending. excellent line attachment points.
best 20 bucks i welded together.
CheapersJeepers's Reviews
03-04-2009, 08:16 PM |
Recommended? Yes
Comments: Installed the working prototype roof rack by BajaRack. I've worked with them to develope a rack for the JK - 03/09
SunroofJeepYj's Reviews
02-26-2009, 09:51 PM |
Price: $10.00 Recommended? Yes
Comments: Sunroof, 10 years no leaks.
Window is manually removeable, pulled from some car. about 3x2 feet, round edges, black trim.
Helps with light a lot.
I used a sawzall. The hard top fibreglass makes a mess.
