SWAG Offroad - Drop Down Tailgate Conversion Kit (HD hinges) Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Exterior Accessories Next Product
Rating: None
Product Information
MSRP: $199.95
Average Price: $250.00
Manufacturer: SWAG Offroad
Recommended?
Yes: 1 / No: 0
Company Website: http://www.swagoffroad.com/
I have wanted to do this install for a long time and finally got the time to do it. I love my jeep but feel that the swing-out tailgate is a bit annoying and being a pickup-kinda-guy a tailgate seems much more useful.
Enter the SWAG Offroad tailgate kit. I opted for the Heavy Duty hinge version which was a few bucks more than the standard kit, but in my opinion very worth it. I decided not to get the aluminum body panel, thinking that if I wanted it, I would just get it later. Having done the install, I am not sure I would want to attempt to install it afterwards, so if you feel you might want it, get it right off and do it all at once (will explain).
I got the kit in the mail and promptly tore it open. The hardware was neatly packaged in two boxes; one requiring painting, one not. After a lot of surface prep, about a million coats of primer, and a solid number of coats of black, my kit was painted and ready for install.
While the kit came with complete and thorough instructions, I feel they COULD have been just a bit more professional, however were complete and detailed everything for the install.
Now the fun part: installation!
The most risky part of this installation is removing the factory hinges. Of the eight Torx bolts holding the hinges on I had no issue getting seven of them to break free. That said, I had one bolt that decided to strip out. I drilled it and promptly broke off an easy-out in the bolt severely limiting my options. Luckily an old trick worked and using a punch and a hammer was able to "worry" the bolt out and could proceed with the install.
The hinge plate (bottom bar across the tailgate) went on without a hitch, drilling out the old small holes and re-tapping. I opted to drill through the tailgate for the last two bolts (on the drivers side) as mine did not have a plate I could tap into.
Once the plate is installed, I marked, center punched, and drilled the holes in the body for the lower hinges. The hardest part of the install was getting these bolted in place. You have to slip a nut-plate into a quarter-sized hole in the underside of the body. The instructions say to remove the rear four body mounts, but I had to take out the aft six to get enough clearance. To say this part was frustrating would be an understatement. I ended up using zip ties, string, and the "installation wire" to get the plates into place. It took using some extended bolts and two people to get the plate into place, then held, finally swapping the long bolts for the short ones, one at a time. Again, extremely frustrating! Once this part is done, it is DONE and this is the reason I recommend getting the bottom panel at the same time and not trying to install it later.
Once done with the lower hinges, the rest of the install is very straight forward. Install the support wire brackets in the tub, just make sure you put them in the same place, at an angle, and that you drill STRAIGHT. I managed to wallow out a hole on the drivers side and had to remove the gas filler cap and use a through-bolt (which worked very well) but was more work than it needed to be.
Once the hinges are installed, the rest of the install is pretty simple. Just bolt the other plates on when and where they say to and you're almost done! Last step is to adjust the backlash in the factory latch (the pin moves and you will need to move it) and adjust how much tension is on the pin mechanism with the kit.
Obviously you will have to adapt to your Jeep and your situation, but overall, the install was a lot of fun. Word of warning, you must be familiar and comfortable with drilling your tub, tapping holes, and removing stubborn bolts.
The install instructions call for some extremely specific drill bits and your local hardware store likely won't have them, but I was able to make do with my Dewalt drill set. Again, minor adaptations are the name of the game, but overall, this is a fun install (albeit frustrating at times) and the kit really is complete. I am EXTREMELY happy with it and get a ton of comments on it. Solid job on the part of Troy at SWAG...great great kit.
-Brice
None
wranglerfan89YJ
wranglerfan89YJ's Reviews
01-18-2015, 12:57 AM
Price: $250.00
Pros: Awesome for a workbench or to sit.
Cons: Didn't include all parts to install.
Recommended? Yes
Comments: Love having room to put tools on or to sit on the back of the tailgate. Installation was difficult, but well worth it.
ThreadForumRepliesLast Post
Rusty's Offroad TJ Wrangler 1" Body Lift Kit Body Lifts 9 03-03-2014 03:45 PM
Pilot 4" Offroad lights Lighting, Lenses & Bulbs 6 11-27-2013 11:53 PM
Zone Offroad - Zone Offroad 1.25" bodylift Body Lifts 9 09-09-2013 10:29 PM
Viking Offroad Fastback Tops 17 03-19-2012 05:56 PM
JCR Offroad - XJ Rear Lower 1/4 Panel Armor Exterior Accessories 1 05-23-2010 01:52 AM
