Go Back JeepForum.com > Reviews > Body > Exterior Accessories > Bondo Easy Finish Black Flexible Part & Bumper Repair
Steering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!Ruffstuff Axle Simple Swap Kit!
Bondo Easy Finish Black Flexible Part & Bumper Repair Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Exterior Accessories Next Product
Rating:
Product Information
MSRP: $5.00
Average Price: $5.00
Manufacturer: Bondo
Recommended?
Yes: 1 / No: 0
This is a two part epoxy formulated to cure rapidly, it has a 6 minute working time, and is solid in about 30 minute at 77 degrees Farenheit, longer if cooler. You can use this material to rejoin broken, cracked or seperated plastic, as well as gouges. It is black and cures black as well. It can be sanded, painted and worked. Where this material is different from other epoxies, or epoxies geared to hard plastics and metals, is that not only does it bond to the soft plastics but is also remains flexable as well so it iwll not break out or seperate as a harder epoxy otherwise would.
None
JaySpencer66
JaySpencer66's Reviews
11-10-2006, 10:08 PM
Price: $5.00
Pros: Easy to use
Cons: A little messy, but that is the nature of the product and really isn't a con
Recommended? Yes
Comments: Works as advertised which means that if you have a torn or ripped flare that you can repair it. Considerring that a new set of flares can be several hundred dollars, even with matching paint custom mixed you can referb your flares for about $75-$90 including primer, adhesion promoters ad strippers.
ThreadForumRepliesLast Post
KC HiLites 6" Black Daylighters Lighting, Lenses & Bulbs 25 04-27-2013 06:52 PM
Mopar Black Fuel Door Exterior Accessories 12 06-14-2012 10:55 AM
OMIX Black Headlight bezels 97-06 TJ Exterior Accessories 1 02-10-2009 05:34 PM
Pro Comp 100 Series Black - 5" X 7" Rectangular Lighting, Lenses & Bulbs 1 09-26-2008 11:52 PM
Krylon Semi-Flat Black Exterior Accessories 2 04-01-2008 10:01 PM
Jeep Parts at Andy's
