Vision X Solstice S1100 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Lighting, Lenses & Bulbs Next Product
Rating: None
Product Information
Average Price: $180.00
Manufacturer: Vision X
Recommended?
Yes: 1 / No: 0
The all new Solo s1100 in the Solstice Series of LED off road lamps. Equipped with Vision’s brand new 10 watt LED technology, with each 10 watt Solo producing 900 lumens making them the brightest LED off road lamp on the market in only a 2” x 2” square housing. Not only are they the brightest, they are the most efficient with the s1100 drawing only 0.75 amps due to their advanced electronic drivers which are also responsible for their 50,000 hour life span and variable 9 - 50 Volt DC input. The Solstice Solo’s main feature is the 4 sided channel design that allows you to interlink it on all four sides with another Solstice Solo pod or other various available mounting hardware for flat, tube or even helmet mount making it the only modular light with the ability to make any shape or length with the available spot, euro and flood beam patterns mixed throughout your custom configuration. No power on your ride, no worries; Vision X will also be releasing a line of rechargeable battery packs for any configuration of your Solstice Solo light pods.
Key features are as follows; rugged die-cast aluminum housing provides optimum durability and heat dissipation. The Solstice Solo series features an IP68 ingress protection rated housing making them impenetrable to dust and submersible under water up to 3 meters. The unbreakable polycarbonate lenses are housed by a 6061 aluminum face plate which doubles as a radiant heat sink to melt away snow and ice in frigid conditions. The Solstice Solo series has been subjected to a 14Grms vibration test to ensure their performance in high impact conditions. Built to last, this Vision X series features a lifetime warranty.
None
mc2065
mc2065's Reviews
12-31-2011, 05:35 PM
Price: $180.00
Pros: Small & Bright
Cons: Nada
Recommended? Yes
Comments: I purchased these to supplement the reverse lights. Tapped into the right side reverse light and I was in business. Attached the lights to third brake light. These are perfect for this application. Wide beam.
ThreadForumRepliesLast Post
Hella Vision Plus headlight conversion Lighting, Lenses & Bulbs 10 09-20-2015 01:54 AM
Vision X XIL-40 4" LED Xmitter Lighting, Lenses & Bulbs 1 05-26-2015 02:55 AM
Vision X Tantrum Rock Lights Lighting, Lenses & Bulbs 6 03-12-2014 10:52 PM
Vision X Offroad - Vision X LED BAR LIGHT 60 Lighting, Lenses & Bulbs 2 10-22-2013 11:25 AM
