Vehiclelight.com 4" Flanged LED Red 44 Led Stop/Tail /Turn Lamp Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Lighting, Lenses & Bulbs Next Product
Rating:
Product Information
Average Price: $150.00
Manufacturer: Vehiclelight.com
Recommended?
Yes: 3 / No: 0
Vehiclelight high count LED line
44 Super bright Red LED Diodes
Built in Flanged Housing
Sonically Sealed Polycarbonate Lens and Housing
Designed at 14 Volts
Industry Standard Connections and Pin Out
Circuitry Protected Against Voltage Surge and Spikes
$26.99
None
BvOjeep
BvOjeep's Reviews
02-05-2014, 03:53 PM
Price: $150.00
Pros: LED
Cons: Can't put guards over them
Recommended? Yes
Comments: Recon LED Front Turn Signal Lights
Jumphog
Jumphog's Reviews
01-01-2009, 12:13 PM
Recommended? Yes
Comments: Looks good, and is bright, where others can see them! These recess, so I have no problem with the custom tire carrier.
02tjsport
02tjsport's Reviews
12-02-2007, 12:46 AM
Pros: Easy to install, wiring easy as well
Cons: no instructions, no dimensions, no wiring diagram for pigtail
Recommended? Yes
Comments: Easy as pie to install, once you get over the fact that you have to cut your tub. I guessed on the wiring and got it the first try. It uses a 3 wire pigtail that comes with grease on the connections. Seems to be sealed from the elements very well. PIGTAIL WAS NOT INCLUDED. It was only like $5 or so though.
I used a 4.5" hole saw to cut the holes...It may have been 4.25"...I Cant really remember right now. I just took the light to home depot and matched up. I paid $34 for the hole saw though.
Stuck some RTV behind hte left light. I forgot to do it on the first one (passenger side.)
I used 1/8", 1/2" hold rivets, with washers on inside and outside of tub.
ThreadForumRepliesLast Post
Mopar Black Tail Light Guards Exterior Accessories 7 08-31-2014 08:31 AM
Off Road Only LiteDOTs™ LED Tail lights Lighting, Lenses & Bulbs 10 05-23-2014 08:01 AM
Pilot LED Tail Lights Lighting, Lenses & Bulbs 4 01-19-2012 09:28 AM
Off Road Only LiteDOTS LED Tail Lights Lighting, Lenses & Bulbs 12 09-14-2011 04:00 PM
Rugged Ridge Euro Tail Light Guards Lighting, Lenses & Bulbs 5 10-20-2010 07:17 PM
