KC HiLiTES Fog Light in Black for 97-04 Jeep Wrangler TJ & Unlimited Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Lighting, Lenses & Bulbs Next Product
Rating:
Product Information
MSRP: $140.00
Average Price: $88.42
Manufacturer: KC HiLiTES
Recommended?
Yes: 21 / No: 0
KC HiLiTES introduces a cool alternative to bland or broken original '97-'04 TJ fog lights. These replacement 55-watt fog lights will plug directly into the factory wiring harness with no splicing required! Available in Black or Chrome with matching stone guard. Sold Individually. 23 Year Limited Warranty
None
Page 1 of 2 1 2 > Last
ChadH
ChadH's Reviews
08-22-2015, 02:55 PM
Price: $100.00
Pros: Direct fit for factory fog lights
Cons: Seem weaker in brightness than factory
Recommended? Yes
Comments: KC factory replacement fog lights. I used these to replace my factory fog lights which were cracked. The housing seems to be a cheap plastic, but strong enough for the job. The lighting seems to be weaker than the factory fog lights; however, this is while using the new KC replacement head lights which are much brighter with a wider beam pattern than factory, so it is subjective. Regardless, these are a better option than the factory replacements which are more expensive. I painted the rock guards black, so the bright white KC wording is not apparent to help deter theft/damage.
RHINO965
RHINO965's Reviews
10-20-2014, 02:50 PM
Price: $105.00
Pros: complete set, 2 lights, mounting bracket, and wiring harness.
Cons: Standard bolts. Would have preferred the torq style anti theft bolts.
Recommended? Yes
Comments: Although small and compact the 4 LED lights are very powerful. Mounted at bottom side of my windshield, they are barely visible. Everything in the kit was included and the simple "How To " directions were good. Was amazed how much light is produced by these small lights. WELL DONE KC!
FaT00CaJuN
FaT00CaJuN's Reviews
03-17-2011, 02:34 PM
Price: $100.00
Pros: Looks good and direct fit
Cons: With the light covers on, the light has less range than stock
Recommended? Yes
Comments: looks good and easy install. light doesnt shine as far out as oem.
boeingxtreme
boeingxtreme's Reviews
01-14-2011, 09:44 AM
Price: $0.01
Pros: Good lights for plug and play
Cons: -
Recommended? Yes
Comments: Great Lights, plugged right into my jeep which is an X and did not come with fog lights.
boeingxtreme
01-09-2011, 08:58 PM
Price: $74.00
Pros: a piece, good lights for the price
Cons: none
Recommended? Yes
Comments: Purchased because my jeep was wired but did not have lights or turn signal switch, replaced both and run them all the time
TheSlowDown
TheSlowDown's Reviews
01-08-2011, 12:46 AM
Price: $98.00
Pros: The lights work. Have a plastic housing so no rust issues. Nice switch included.
Cons: Can't get mesh guards for these particular fog lights.
Recommended? Yes
Comments: I bought the KC Hilites Apollo 457 lights. I stuck with the 5" round versus standard 6" due to my bumper (didn't make sense for light to strike the bumper).
I like the plastic housing, but wish I could buy a some kind of mesh guard to protect them from brush. The fog lights do come with slip-on soft-sided covers though.
bdpowell3323
bdpowell3323's Reviews
06-12-2010, 11:38 PM
Price: $75.00
Pros: Nice for trail riding and, well, driving in fog
Cons: none
Recommended? Yes
Comments: Definitely recommend to anyone looking for exterior lights.
bs1946
bs1946's Reviews
05-17-2010, 03:31 AM
Price: $74.99
Pros: Easy replacement for damaged or missing factory fog lamps
Cons: Mounting bolt too big for factory mounting holes and no alignment tabs.
Recommended? Yes
Comments: I bought the 05/06 version for the TJ and Unlimited from Quadratec. My 05 Unlimited was wired for factory fog lamps but first owner took them off. The 05 and 06 TJs have a different wiring connector than 97-04 TJs so you need to be careful ordering. The factory lamps have a 5/16" mounting bolt and a tab that fits behind the mounting hole to align the light to the bumper. The Hella lamp uses a slightly larger metric bolt and has no alignment tab. Rather than drill out the holes in my bumper, I just hit the local hardware store and picked up a couple of stainless steel 5/16" bolts and nuts. Alignment was easy and the connectors mated perfectly with the ones under the fenders. Lights also come with plastic stone guards for protection.
r_unda
r_unda's Reviews
10-08-2009, 11:38 PM
Price: $180.00
Pros: These fog light are very bright
Cons: price
Recommended? Yes
Comments: Great fog lights, very bright
Tachy
Tachy's Reviews
08-16-2009, 12:52 AM
Price: $75.00
Pros: Bright 100w fogs, long bulb life, easy instal
Cons: they dont come with the nice shock mounts that the daylighters come with.
Recommended? Yes
Comments: Their great lights but I was disapointed that they didnt come with the shock mounts that the daylighters do. Nevertheless easy to install have have had them for several years now w/o any bulb replacements
Libtekguy
Libtekguy's Reviews
01-08-2009, 03:47 AM
Price: $59.99
Recommended? Yes
Comments: Brighter than stock and look way better. Had to drill the mounting hole out just a little bit bigger, but other than that, they mounted up very nicely.
robbyb413
robbyb413's Reviews
09-22-2008, 01:57 PM
Price: $68.00
Recommended? Yes
Comments: Extremely easy to install. Hardest part was removing the mounts from my old lights as they were bent, busted, and rusted. After they came out the KC HiLITES bolted on and plugged in.
The instructions said I'd have to drill the mounting holes out, but that was not needed on my rig.
Dannn
Dannn's Reviews
07-29-2008, 10:18 PM
Recommended? Yes
Comments: I have the 50 series lights. They work great and provide good light with 100w bulbs. I have no complaints
rick schwartz
rick schwartz's Reviews
06-05-2008, 06:08 PM
Price: $100.00
Recommended? Yes
Comments: all i have to say is "balls". those lights rock. they are bright as hell and look good mounted on my front bumper. plus my wift hated em wich makes it even better. great for flashing someone when they cut you off.
TJ_Jeeper91
TJ_Jeeper91's Reviews
06-03-2008, 10:41 PM
Price: $100.00
Recommended? Yes
Comments: Great fog lights!! VERY easy to install. Just plug em' right in. They do great!!!
johnnyw104
johnnyw104's Reviews
04-21-2008, 07:39 PM
Price: $100.00
Recommended? Yes
Comments: Added Daylighters and love them, they throw off a good amount of light
SkyHigh65th
SkyHigh65th's Reviews
04-21-2008, 06:41 PM
Price: $120.00
Recommended? Yes
Comments: work good for fog light
Romeo-Sierra
Romeo-Sierra's Reviews
03-31-2008, 04:30 PM
Price: $140.00
Recommended? Yes
Comments: Good fog lights
95_ZJ
95_ZJ's Reviews
03-22-2008, 03:18 PM
Price: $50.00
Recommended? Yes
Comments: I have 8 of these and i can see just about everything at night..
jodum23
jodum23's Reviews
07-26-2007, 10:16 PM
Pros: quick, easy installation
Recommended? Yes
Comments: The installation was very quick and easy. It took me maybe 20-30 minutes max. Not the brightest but i think they're better than the stock ones and they also look better.
ThreadForumRepliesLast Post
KC Hilites Slim Light - driving lights Lighting, Lenses & Bulbs 16 08-22-2015 12:50 PM
KC HiLites SlimLites--Long-Range Beam (Black) 130W Lighting, Lenses & Bulbs 58 05-09-2015 05:00 PM
Quadratec Headight Guards for 97-06 Jeep Wrangler TJ & Unlimited Exterior Accessories 10 03-30-2014 10:27 AM
KC HiLites 6" Black Daylighters Lighting, Lenses & Bulbs 26 08-24-2013 02:25 PM
Crown Clear Front Side Marker Lenses For 97-06 Jeep Wrangler TJ & Unlimited Lighting, Lenses & Bulbs 2 05-26-2012 08:50 PM
