Go Back JeepForum.com > Reviews > Body > Lighting, Lenses & Bulbs > IPF H4 Conversion Lens
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
IPF H4 Conversion Lens Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Lighting, Lenses & Bulbs Next Product
Rating:
Product Information
MSRP: $190.00
Average Price: $76.74
Manufacturer: IPF
Recommended?
Yes: 27 / No: 2
An upgrade for your conventional sealed beam headlamps.
Housings which allow the use of any H4 bulb.
Page 1 of 2 1 2 > Last »
JackTEOD
JackTEOD's Reviews
01-13-2012, 11:02 PM
Price: $67.99
Pros: none!
Cons: Does not fit 2012 models as advertised.
Recommended? No
Comments: Installed them on my 2007 JK and they fit great. Tried to on my 2012, did not fit, the rear black interior collar that the exterior silver collar bolts onto does not match up with the tabs on the IPF housing. I was under the impression nothing had changed in the lighting department but I guess I was wrong, as was Quadratec. Any suggestions?
SaxManClay
20 points!!
SaxManClay's Reviews
07-26-2011, 11:07 AM
Price: $160.00
Pros: Good quality, easy install
Cons: N/a
Recommended? No
Comments: I bought these two years ago because my old lights had fogged up and were not working. These are a glass lens as opposed to the OEM plastic, so they don't fog up at all. Great cut-off too.
gtnutz
gtnutz's Reviews
03-09-2011, 09:36 PM
Price: $125.00
Pros: much better then stock
Cons: not HID's
Recommended? Yes
Comments: These really help improve the poor stock lights. While they may not be as good as other lighting systems out there the price was righ.
3fifty
3fifty's Reviews
02-23-2011, 09:53 PM
Price: $1.00
Pros: Good cut off
Cons: None
Recommended? Yes
Comments: Installed when I bought the TJ.
I like the cut off they have a lot.
TheSlowDown
TheSlowDown's Reviews
01-07-2011, 11:38 PM
Price: $139.95
Pros: I can actually see at night while driving instead of guessing. High Beams are REALLY high, and great for many purposes.
Cons: expensive.
Recommended? Yes
Comments: I bought the H4 Conversion Lens + X51 Fatboy Bulbs KIT from northridge4x4 for the price I listed above.
Install was smooth, adjustment was easy but a bit time consuming. David Stern Lighting has an excellent guide on adjustment. DO NOT drive with these lights without the adjustment.
Oh, and I got the IPF wiring loom to hook up directly to the battery - didn't want any overheating cable or inefficient/insufficient stock cable related issues.
whatjeepthing
whatjeepthing's Reviews
12-24-2010, 04:29 PM
Price: $15.00
Pros: good way to convert from sealed units to brighter changeable bulb units
Cons: none
Recommended? Yes
Comments: good way to convert from sealed units to brighter changeable bulb units. They did wonders to my nighttime vision over the stock sealed beam units. I have since made the switch to true HID's
93ZJ_5.2_ca
93ZJ_5.2_ca's Reviews
08-10-2010, 02:30 PM
Price: $70.00
Pros: great easy install
Cons: none
Recommended? Yes
Comments: they do what they do.
Fox01V
Junior Member
Fox01V's Reviews
08-08-2010, 02:13 PM
Price: $75.00
Pros: -Lets you see where your going unlike the stock lights
Cons: -none
Recommended? Yes
Comments: Great lenses with a rubber water seal on the back
Nashirak
Nashirak's Reviews
01-18-2010, 09:37 PM
Price: $60.00
Pros: Awesome light output great beam pattern Easy to install Very well made
Cons: None
Recommended? Yes
Comments: This may easily be one of the best modifications done to my Jeep. You never really know how little light your factory sealed-beams are putting out until you compare with something like these.
Mayfair_Jeeper
Jack *** of All Trades
Mayfair_Jeeper's Reviews
11-26-2009, 10:13 AM
Price: $32.99
Pros: Bright e-code pattern
Cons: light scatter with HIDs
Recommended? Yes
Comments: Easy isntall, and much better light pattern than stock. However, are not ideal with HID bulbs
ktroth
ktroth's Reviews
10-08-2009, 03:31 PM
Price: $35.00
Pros: Great for the price
Cons: loose fit
Recommended? Yes
Comments: These work great with the ipf fatboy bulbs. they can be a little loose when installed. a little shim with the trim ring fixes the problem.
TJRUSSELL
TJRUSSELL's Reviews
09-23-2009, 09:33 PM
Price: $40.00
Pros: greater light output
Cons: feels cheep
Recommended? Yes
Comments: bought on ebay as a projector headlight works nice
Mayfair_Jeeper
04-01-2009, 02:08 PM
Price: $35.00
Recommended? Yes
Comments: Love the EURO cutoff. it keeps the light where I need it and out of other drivers eyes. It is fantastic
Bmel17
Bmel17's Reviews
01-15-2009, 08:14 AM
Price: $70.00
Recommended? Yes
Comments: quick easy install worth the cash; running them with silverstars and now I cab see
erickpl
erickpl's Reviews
11-24-2008, 11:23 AM
Price: $100.00
Recommended? Yes
Comments: Why do I need 75 characters to provide a review? I Just want to list em. Adding characters to shut this thing up.
Red_
Red_'s Reviews
09-14-2008, 03:52 PM
Price: $60.00
Recommended? Yes
Comments: You can finally see at night without running your highs and your fogs. 75 chars
distortedtj
distortedtj's Reviews
07-20-2008, 08:05 AM
Recommended? Yes
Comments: wouldn't have any other lenses............................................ ...............
valacech
valacech's Reviews
07-18-2008, 08:02 PM
Price: $55.00
Recommended? Yes
Comments: Bright as day. WILL NOT PASS STATE INSPECTION AND ARE NOT DOT CERTIFIED. Either way, they're awesome. Get them. You need them.
XTC Jpr13
XTC Jpr13's Reviews
05-08-2008, 09:12 PM
Price: $150.00
Recommended? Yes
Comments: These lenses combined with the Fatboy H4 bulb is very bright and a huge upgrade over stock
Jeepers76
Jeepers76's Reviews
05-05-2008, 08:34 PM
Price: $80.00
Recommended? Yes
Comments: They're Great!!!! 100X Better than stock.
ThreadForumRepliesLast Post
Hella Vision Plus headlight conversion Lighting, Lenses & Bulbs 6 03-02-2011 11:11 AM
Bosch H4 conversion Lighting, Lenses & Bulbs 2 09-29-2010 01:20 PM
Quadratec Clear Corner & Turn Signal Lens Kit Exterior Accessories 4 12-28-2009 01:50 PM
Harbor Freight Clear Lens Halogen Lights Lighting, Lenses & Bulbs 3 09-29-2009 03:20 PM
Hella 7" round H4 conversion Lighting, Lenses & Bulbs 8 06-13-2009 11:18 PM
Glock Forum
