IPF Fatboy H4 Bulbs Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Lighting, Lenses & Bulbs Next Product
IPF Fatboy H4 Bulbs
Rating:
Product Information
MSRP: $180.00
Average Price: $103.78
Manufacturer: IPF
Recommended?
Yes: 28 / No: 3
Powerful headlight upgrade for use with a seperate lense
None
Page 2 of 2 1 2
swedishdwarf
swedishdwarf's Reviews
10-06-2007, 05:54 AM
IPF Fatboy H4 Bulbs
Pros: Bright, clear, white light
Cons: Excessive heat generated
Recommended? Yes
Comments: I installed a pair of IPF h4 lenses today along with the fatboy bulbs. Headlight adjustment is critical as these bulbs are very bright. Striking a balance between being able to see and allowing oncoming traffic to see took a couple tries, but once I found the sweet spot they performed very well.
My only concern is the heat. Parking after a drive of about a half hour, I noticed the headlight switch was very hot. I'm kind of worried about the circuit overheating and I should probably rewire the system with a couple of heavy-duty relays. I, however, am very lazy, so I'll most likely buy a fire extinguisher and try not to think about it.
phillychondro
phillychondro's Reviews
06-14-2007, 09:34 AM
IPF Fatboy H4 Bulbs
Price: $79.99
Pros: Ultra Bright
Cons: None so far
Recommended? Yes
Comments: Use these bulbs combined with the IPF lenses in my TJ. Install took 20min. Great Mod!
2k3r1
2k3r1's Reviews
04-30-2007, 06:22 PM
IPF Fatboy H4 Bulbs
Pros: geat low beam output
Cons: pricey at first glance
Recommended? Yes
Comments: when i bought my jeep used one of the sealed beam headlights went out withint the week and i didnt want to spend money on a stock replacement... so i started researching. I found out about the fatboys and the ipf lenses and bought them ASAP. They are very bright and make night time driving much more enjoyable over the stock weak sealed beams. I seriously think this has been the cheapest upgrade and the best BANG FOR THE BUCK out of all my jeep upgrades.
jm708
jm708's Reviews
03-11-2007, 10:59 AM
IPF Fatboy H4 Bulbs
Pros: bright when properly aimed
Cons: a little expensive but worth the $
Recommended? Yes
Comments: I love the lights. Much brighter over stock lights. I think they are a little pricey but worth the upgrade. The install was simple and only took 10-15 min.
CDX74
CDX74's Reviews
01-21-2007, 05:00 PM
IPF Fatboy H4 Bulbs
Pros: great lights, good cut off, very bright
Cons: only lasted 10 months for me
Recommended? Yes
Comments: I loved these bulbs until the low-beam elements blew out on me the other night after just 10 months of use. But i liked them so much i will probably buy some more.
geoffgarcia
geoffgarcia's Reviews
01-02-2007, 01:13 PM
IPF Fatboy H4 Bulbs
Price: $85.00
Pros: Easy to Install -10 minutes with only a screwdriver
Cons: generates a LOT of heat
Recommended? Yes
Comments: The improvement over a 20$ set of Sylvania Halogen sealed beam lights was obvious
But at 8x the cost (with an IPF Lens Conversion kit) for a 10-15% increase in illumination this is much more of a luxury item than anything else.
jacala
jacala's Reviews
11-09-2006, 06:14 AM
IPF Fatboy H4 Bulbs
Pros: great cut-off, great lowbeam for around town.
Cons: none.
Recommended? Yes
Comments: Used by "jacala" around Brisbane, Queensland ,Australia.
stevensinger
stevensinger's Reviews
11-03-2006, 10:37 AM
IPF Fatboy H4 Bulbs
Price: $80.88
Pros: SUPER BRIGHT! Very easy install.
Cons: Other think you have high beams on and flash you.
Recommended? Yes
Comments: Buy them, easy install. Just be careful some people think they are your high beams and flash you with theres.
dieselcrackel
dieselcrackel's Reviews
08-12-2006, 09:40 AM
IPF Fatboy H4 Bulbs
Pros: Super easy to install. Way brighter then silver stars.
Cons: none
Recommended? Yes
Comments: As mentioned b4 may have to re-aim so you don't blind on coming traffic. High beams are almost like having spot lights.
I was using silver stars and replaced those twice at $20 a peice=$80 in less then a year. This set up only cost $135 shipped to my door and installed in 15 minutes.Highly recommend these without spending alot of money!
#20 Home Depot
Frequent flyer
#20 Home Depot's Reviews
08-06-2006, 10:02 PM
IPF Fatboy H4 Bulbs
Pros: Great light output and easy to install.
Cons: None
Recommended? Yes
Comments: I highly recommend this light upgrade.
MattTheMudder
Ask Mr. Owl
MattTheMudder's Reviews
08-01-2006, 11:20 PM
IPF Fatboy H4 Bulbs
Price: $83.00
Pros: Very powerful, affordable compared to HID upgrades, whiter light, long range
Cons: May or may not be street legal in your area
Recommended? Yes
Comments: Awesome bulbs, I used these in combination with IPF's Lense upgrade. They're very bright and powerful, but need to be properly aimed so that they dont blind oncoming drivers. I installed heavy duty wiring (also from IPF) so that the increased electrical draw didnt overload the factory wiring
Page 2 of 2 1 2
ThreadForumRepliesLast Post
hella headlight upgrade h-4 bulbs Exterior Accessories 2 06-11-2015 02:25 PM
