IPF Fatboy H4 Bulbs
Rating: |
Product Information
| MSRP: |
$180.00 |
| Average Price: |
$102.68 |
| Manufacturer: |
IPF |
| Recommended? |
Powerful headlight upgrade for use with a seperate lense
ktroth's Reviews
Price: $95.00 Pros: Very Bright Cons: $$$ but you get what you pay for Recommended? Yes
Comments: They really shed some light on night time driving. They are bright enough to blind oncoming drivers. Some readjustments were needed to avoid having everyone flash their high beams at me. almost never have to use my high beams.
rabidcoyote97's Reviews
05-27-2009, 12:07 AM |
Price: $79.00 Pros: Bright!! Cons: Don't last nearly long enough Recommended? No
Comments: Disappointing lights for the money. Sure, they are bright. However, to last less than two years at that kind of price is a ridiculous.
Good luck even getting a question answered from IPF's "customer service" department. They were useless, in telephone or e-mail form.
06TJX's Reviews
04-01-2009, 02:08 PM |
IPF Fatboy H4 Bulbs
Price: $88.00 Recommended? Yes
Comments: Love them. Can not believe how much difference there is in visablity. it is like night and day
Zakman's Reviews
01-23-2009, 03:03 PM |
IPF Fatboy H4 Bulbs
Price: $140.00 Recommended? Yes
Comments: Very easy to install. Did have to adjust the aiming, no issues. Product and installation was as expected by all other reviews out there.
Danegerous's Reviews
08-07-2008, 09:49 AM |
IPF Fatboy H4 Bulbs
Price: $180.00 Recommended? Yes
Comments: Amazing. Totally awesome lights. These things really do the trick, I mean really.
valacech's Reviews
07-18-2008, 08:03 PM |
IPF Fatboy H4 Bulbs
Price: $55.00 Recommended? Yes
Comments: Bright as day. WILL NOT PASS STATE INSPECTION NOT DOT CERTIFIED. They are totally worth it though. Get them, you need them. Awesome.
Ichabod1960's Reviews
07-03-2008, 11:55 PM |
IPF Fatboy H4 Bulbs
Price: $150.00 Recommended? Yes
Comments: I can't believe that I put up with the stock wiring harness and Silverstar headlights for the past couple of years. These lights are phenomenal.
unsung's Reviews
06-13-2008, 09:28 PM |
IPF Fatboy H4 Bulbs
Price: $100.00 Recommended? Yes
Comments: Work great, very bright. I did need to adjust them down quite a bit though and I have heard that this is common.
mortalenema's Reviews
05-05-2008, 06:15 AM |
IPF Fatboy H4 Bulbs
Price: $80.00 Recommended? No
Comments: These produce some truly awesome light. The low beams are almost too bright. My main beef with these is they cost 80bux and will last maybe one year. I can't afford to replace these every year!
dippert's Reviews
05-02-2008, 12:35 AM |
IPF Fatboy H4 Bulbs
Price: $95.00 Recommended? Yes
Comments: These bulbs are AMAZING. I used to run 130watt KC driving lights to compensate for the Silverstar headlights i had that didn't light up very much. After I installed the Fatboys w/ IPF lenses, I can't even tell if my 130w lights are even on. The packaging says this combo gives an optical equivalent of 190w (but only uses 60w low beams), and I believe it based on my experience with them. I did not replace my wiring harness either.
SkyHigh65th's Reviews
04-21-2008, 05:38 PM |
IPF Fatboy H4 Bulbs
Comments: I upgraded the headlights with the IPF housings and bulbs. amazing light output and ease of installation. no condensation and no problem. should have done these before anything
Panici's Reviews
04-18-2008, 09:08 AM |
IPF Fatboy H4 Bulbs
Price: $85.00 Pros: Bright, Easy to install. Cons: An aftermarket HD harness should be used with the Fatboy Bulbs Recommended? Yes
Comments: I've got the IPF lenses with the fatboys, and a HD harness.
I still have to aim them down some, but let me tell you, they are BRIGHT! IMHO headlights are a safety item, not a place to skimp.
I can't even tell the difference when my factory fogs are on or not. Both lowbeam and highbeam settings have a very nice beam pattern, and the lowbeam cutoff is perfect.
thejafe's Reviews
04-14-2008, 12:11 AM |
IPF Fatboy H4 Bulbs
Price: $75.00 Recommended? Yes
Comments: Huge improvement over stock! Highly recommended.
socaltj's Reviews
03-20-2008, 06:19 PM |
IPF Fatboy H4 Bulbs
Price: $130.00 Recommended? Yes
Comments: So much better that stock it is unbelievable! Bright White!
distortedtj's Reviews
03-11-2008, 11:57 PM |
IPF Fatboy H4 Bulbs
Price: $120.00 Recommended? Yes
Comments: got the IPF E code light housings and the fatboy bulbs. Huge improvement, recommed to anyone with factory headlamps. paid 120 for the lenses and bulbs
swedishdwarf's Reviews
10-06-2007, 04:54 AM |
IPF Fatboy H4 Bulbs
Pros: Bright, clear, white light Cons: Excessive heat generated Recommended? Yes
Comments: I installed a pair of IPF h4 lenses today along with the fatboy bulbs. Headlight adjustment is critical as these bulbs are very bright. Striking a balance between being able to see and allowing oncoming traffic to see took a couple tries, but once I found the sweet spot they performed very well.
My only concern is the heat. Parking after a drive of about a half hour, I noticed the headlight switch was very hot. I'm kind of worried about the circuit overheating and I should probably rewire the system with a couple of heavy-duty relays. I, however, am very lazy, so I'll most likely buy a fire extinguisher and try not to think about it.
phillychondro's Reviews
06-14-2007, 08:34 AM |
IPF Fatboy H4 Bulbs
Price: $79.99 Pros: Ultra Bright Cons: None so far Recommended? Yes
Comments: Use these bulbs combined with the IPF lenses in my TJ. Install took 20min. Great Mod!
2k3r1's Reviews
04-30-2007, 05:22 PM |
IPF Fatboy H4 Bulbs
Pros: geat low beam output Cons: pricey at first glance Recommended? Yes
Comments: when i bought my jeep used one of the sealed beam headlights went out withint the week and i didnt want to spend money on a stock replacement... so i started researching. I found out about the fatboys and the ipf lenses and bought them ASAP. They are very bright and make night time driving much more enjoyable over the stock weak sealed beams. I seriously think this has been the cheapest upgrade and the best BANG FOR THE BUCK out of all my jeep upgrades.
jm708's Reviews
03-11-2007, 09:59 AM |
IPF Fatboy H4 Bulbs
Pros: bright when properly aimed Cons: a little expensive but worth the $ Recommended? Yes
Comments: I love the lights. Much brighter over stock lights. I think they are a little pricey but worth the upgrade. The install was simple and only took 10-15 min.
CDX74's Reviews
01-21-2007, 04:00 PM |
IPF Fatboy H4 Bulbs
Pros: great lights, good cut off, very bright Cons: only lasted 10 months for me Recommended? Yes
Comments: I loved these bulbs until the low-beam elements blew out on me the other night after just 10 months of use. But i liked them so much i will probably buy some more.
