Baja Designs Lights
Rating: |
Product Information
DirtyMo's Reviews
Price: $150.00 Pros: They are very bright, can take a beating and not to expensive. Cons: None so far. Recommended? Yes
Comments: I love these lights they were not to expensive very bright (like stock high beams) and look good.
BlackDaddyZJ's Reviews
Price: $35.00 Pros: Looks Great, Easy to Install if you know what you are doing. Cons: None Recommended? Yes
Comments: I thought the lights looked amazing and mounted relatively easily. I just have to wire them to the new headlight switch so the whole job will be super clean and pretty close to factory.
kmk108's Reviews
Price: $29.00 Pros: no wiring into oem lighting, fairly bright Cons: the screws and bolts have rusted. Recommended? Yes
Comments: They are good, cheap lights that can be bought at the local autoparts store or even walmart. It comes with all the wiring needed, including a fuse and a switch. All the wiring plugs into the other wiring so there is no soldering or splicing. easy install.
ElGuapoBond's Reviews
04-06-2009, 11:35 PM |
Baja Baja Lights
Price: $18.00 Recommended? Yes
Comments: Great looking lights, check the screws, they are probably loose and will allow water to get inside the lights. 100 watt seems to be great around here and 6 of them mounted is quite a light show, I purchased an additional Mopar fog light switch and wired it in. Price was great at 18.00 per light at Auto Zone and 5.00 per spare bulb at Pep Boys makes these an affordable solution if you cannot afford better lights. Chrome is god and wire flex tubing is aluminum so it holds up fine.
bspillane30's Reviews
04-06-2009, 06:12 PM |
Baja Baja Lights
Price: $25.00 Recommended? Yes
Comments: I recently mounted two 4x6 inch fog lights on my front bumper and they look and work mint. They are very bright and just add as nice touch on the front of the jeep.
tupton's Reviews
02-10-2009, 09:18 PM |
Baja Baja Lights
Price: $35.00 Recommended? Yes
Comments: Picked up a pair of these at Walmart and so far they have been great. One of the first mods I did to the jeep.
Nightdrv's Reviews
01-08-2009, 07:50 PM |
Baja Baja Lights
Price: $45.00 Recommended? Yes
Comments: Mounted 3 on top, to the front cross bar.... work just fine for 55w's. If you don't know already, the lighting power of a KK is garbage. So, these help. Especially when going through back roads, and you can't have your fogs and highbeams on all the time. So, you need something like these!
keaton's Reviews
01-02-2009, 12:49 AM |
Baja Baja Lights
Price: $25.00 Pros: Increased lighting, easy install, all wires included Cons: cheap switches Recommended? Yes
Comments: Good lights..light the road up. CHEAP and easy to install.
thetrashman's Reviews
10-07-2008, 07:56 PM |
Baja Baja Lights
Comments: they are the 55 halogen lights,
i mounted them on the bumper,
they are quite bright and worth the cash
GettingDirty's Reviews
10-06-2008, 10:54 PM |
Baja Baja Lights
Price: $20.00 Recommended? Yes
Comments: Great lights. Paid $20 from a local Autozone. Installed and mounted in less than three hours. Works like a charm.
