Product Information
Softopper Bowless / Frameless Soft Tops
Important: If you are checking out the competition before you buy a bowless / frameless soft top you will see that our soft tops are the best value on the market. We supply the Windshield Header Bar and a Rear Tailgate Bar plus our tops are 100% made in the USA and come in 3 colors.
If considering a top from a competitor that may appear less expensive keep in mind that most do NOT furnish all the hardware needed to install their tops.
This is a soft top package that uses the Jeep's roll bars to support the canopy. It comes complete with everything you need, including a No-drill windshield header and a rear window panel retaining bar . It also includes an overhead window storage panel so you can quickly and easily stash all 3 window panels overhead.
This TJ02 model is designed to fit 1997 to 2006 Jeep Wranglers that already have the plastic factory door surrounds. (04 - 06 LJ Unlimited excluded)
Clear windows are standard. Dark tint is available for an additional $45.
Built with the same core characteristics as our industry leading Softopper truck tops.
Lightweight frameless / bowless design.
Industry leading Sailcloth Fabric with unbeatable durability and colorfastness.
Converts from full top to a bimini/safari Style top in a minute or two.
Removable Side and rear panels are easily removed and re-installed. Rain starts and you can be buttoned back up in a couple of minutes
Quickly and easily store all three window panels overhead with included overhead kit.
Includes hidden structural crossbar above rear window that holds the shape and prevents stretching and sagging.
Better visibility than factory tops.
Easy installation. Comes complete.
Heat Sealed crystal clear DOT approved windows.
Not too tight like factory tops!
Now uses a belt strip system instead of snaps
More adjustable to allow for temperature changes
Rear window can also be rolled up in place or removed
YKK zippers, Sunguard industrial thread, Industrial hook and loop.
All Softopper Jeep soft top parts can be replaced individually, extending the value of your purchase.
Industry leading warranty. We stand behind our products.
Made in Boulder Colorado, USA
This top works with all Hard doors and most half soft doors and soft upper doors however if there is not adequate pressure against the door surrounds you may experience some water entry around the doors. This is normal with most soft top installations.
Important Note: This is not a replacement top that uses factory top hardware.
Softopper is a US based company and has been the leader in retractable pickup truck soft tops for over a decade. Our Jeep top division will focus on bringing new and innovative products to Jeep owners.
Shipping costs are $35.95 within the continental USA via UPS Ground.
I love this top! Quiet, clean and easy to install. I wish I could make the rating work, I'd give it 5 stars.
Price | $469 |
Rating | 4 |
Average Price | $350 |
Manufacturer | Softopper |
Recommended | Yes: 1 / No: 0 |
Company website | www.softopper,com |
