Rampage - Factory Replacement Top Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Tops Next Product
Rating:
Product Information
MSRP: $399.99
Average Price: $335.00
Manufacturer: Rampage
Recommended?
Yes: 1 / No: 0
Company Website: http://rampageproducts.com
Jeep Wrangler applications '88-'06
Replace aging, worn out factory soft-top and gain some additional storage space inside the driving compartment. All the features of the original factory top with exclusive Rampage additions two zippered storage pockets. Produced in original factory specifications and colors, the Rampage replacement top easily installs over factory framework, and attaches to factory mounting points and Original Equipment belt rail attachment System. Fits all factory applications and includes the top fabric, clear or tinted windows and, where applicable, includes upper door skins that slip over the OE upper doorframes.
Soft Top produced to OE Specs - factory grade 18 oz materials & colors & Belt Rail installation system
DOT Compliant Windows (30 mil) - available in factory clear vinyl or dark privacy tint (35%)
Weatherproof Heat Sealed Seams & Windows and Marine grade molded tooth zippers
Replaceable Components including side& rear windows with heavy duty molded tooth zippers front window frames and Door Skins
Two Year limited warranty
Fade resistant marine grade, wick-stop thread - Seals the stitch holes to repel moisture, longer life without color fade
Self correcting zippers on all door windows. Marine grade molded tooth zippers run smoother and last longer
Rear windows zip out completely
Door panels have a double adjusting system that ensures a snug, tight fit
Kits include fabric/glass only. Original equipment soft top hardware and door frames required for installation
None
ClimbStuff
ClimbStuff's Reviews
10-12-2012, 12:56 AM
Price: $335.00
Pros: Nicely packaged, tight fitting skins, easy to read instructions, tinted windows, heavy zippers on the rear windows, uses factory bow system, great value for money.
Cons: Header fitment is rough. Snaps for rear bow don't line up 100%.
Recommended? Yes
Comments: Bought from ebay. It came all rolled up in a single box. There was tissue paper between each piece of plastic to prevent damage during shipping. There were not one but two sets of instructions in the box. The door skins fit is super tight, almost too tight. I thought I was in danger of messing them up while installing them over the factory frames. The top itself has a nice finish, snaps for the rear bar of the factory bow, and 3 different hook and loop wraps for the middle bow. The driver side snaps lined up just fine, but the passenger side snaps were too far center. The top is designed to be used with the factory drill header, but does not come with any hardware so you have to reuse the factory screws. The plastic trim has precut slots, and so does the back side of the top it's stitched too, but they don't quite line up, but you can work it into place if you really try.
