Notices
Bestop 2-Piece Hardtop Without Upper Doors Black Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Tops Next Product
Rating:
Product Information
MSRP: $2,518.99
Average Price: $1,821.00
Manufacturer: Bestop
Recommended?
Yes: 4 / No: 0
* Made of resilient, fiberglass-reinforced plastic for long life.
* In-mold gel coat color reduces fading for unsurpassed appearance.
* Automotive-grade, washable headliner reduces noise and increases insulation for a more comfortable ride.
* Grooves in cockpit cover channel water away from doors to better protect the interior.
* Rear window defroster melts snow and ice for an unobstructed view (Jeep applications only)
* Rear vents increase airflow for better ventilation.
* Gas charged shocks support rear window for easy open/close and loading.
* Overhead dome light illuminates the interior on Jeep models.
* Interior mesh pockets store CD's, cell phones, and garage door openers.
* 22% tinted tempered glass windows provide safety and comfort.
* Hardtops available in both 1-piece and 2-piece models with one-year limited warranty.
* 2-piece model features removable cockpit cover, which neatly stores on optionl Rear Shell Roof Rack.
* Available with or without matching upped doors, which feature dual sliding windows and handy armrests.
* Optional Cockpit Cover and Rear Shell Roof Racks allow installation of Universal Rack Tray (sold seperately).
* Hardtop kits include installation hardware.
None
scottystj
scottystj's Reviews
10-21-2012, 05:23 PM
Price: $400.00
Pros: Able to easily remove front half of top
Cons: A bit squeaky
Recommended? Yes
Comments: Awesome top, I was a bit concerned buying a used one but it turned out great. I have nothing to complaine about. Carpeted interior will be toasty warm this winter!
liv24wheel
liv24wheel's Reviews
05-09-2011, 10:00 AM
Price: $2,500.00
Pros: Great fit - interior carpeting does wonders for temp control and sound. Readily available vs. the factory freedom tops that were on year long backorders when I went to order.
Cons: The front removable piece is a pain with a 2 door because you cannot fit the top piece inside the vehicle - I think you may be able to fit it in a four door but as far as pulling it off while out driving around - not happening.
Recommended? Yes
Comments: The carpeting on the inside is phenominal - the sound deadening and the temp control is WAY better than the freedom tops I rode in.
The bummer about this top is the removable piece over the front seats. Because it is one long piece (not two like the freedom top) you cannot pull it off while out driving around because the sun came out. I drive a 2 door and the removable piece will not fit inside the jeep - I am thinking it may fit in the 4 doors, but not positive.
Leaks - when I first got the top I did have leaks over the doors. I found, however, that if you put a small 1.5" section of the supplied weather stripping in between where the front section lays over the rear section (specifically, at each of the back corners) the leaks stopped completely.
This top works great - the interior is much better done than the factory; however, the removable front section, IMO, is less convenient than the factory.
Bevers
Bevers's Reviews
01-01-2010, 06:50 PM
Price: $1,884.00
Pros: Insulated, freedom of a soft top, price, security
Cons: Finicky fitment, leaks if not set right.
Recommended? Yes
Comments: Got an excellent price on the top. The only fault with it I have is that you are required to continually mess with it to get it to seal properly to make it leak free.
jeepsurf
jeepsurf's Reviews
08-16-2008, 04:36 PM
Bestop 2 pc TJ hard top (Black)
Price: $2,500.00
Recommended? Yes
Comments: Rear window glass screws rusted in like 6 months. Upper hard sliders only open 8", sucks if your goin thru a dive-thru.
ThreadForumRepliesLast Post
bestop Upper Door Sliders Tops 4 03-15-2015 06:30 PM
Best Top Bestop Supertop® with 2-piece Soft Doors for CJ5 Tops 8 08-14-2014 02:49 AM
Bestop 2-Piece Doors forJeep Wrangler 97-06 Part Number 51789 Tops 5 02-29-2012 06:52 PM
Bestop 2 Piece Hard Top Tan Tops 2 10-22-2010 01:05 AM
Bestop Bestop 2-Piece Doors in Khaki Diamond Exterior Accessories 2 01-19-2009 07:51 PM
