Go Back JeepForum.com > Reviews > Body > Fender Flares > T&T Customs TJ Full Replacement Tube Fenders
SALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
T&T Customs TJ Full Replacement Tube Fenders Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Fender Flares Next Product
Rating:
Product Information
MSRP: $600.00
Average Price: $833.71
Manufacturer: T&T Customs
Recommended?
Yes: 10 / No: 0
Company Website: http://www.tntcustoms.com/
T&T Customs' Tube Fenders are a unique way to beef up your stock front clip and add some style to your jeep at the same time. They've become popular because a stock fender becomes junk once it's touched by a foreign object where the tube fender can handle the abuse that a jeep owner typically dishes out.
There are now many choices for tube fenders. Some come in kits that you have to assemble, some re-use the stock fender as the foundation for the tube fenders, and others are a hybrid of the two. The last and most favorable solution for tube fenders is a direct bolt-on replacement. At this time we are one of two companies who offer such a solution and the only company who manufactures our entire product in the United States. We're just too proud to do it any other way.
# Advantages to a Full Replacement Fender: Stock Fenders can be sold or saved for a later time (trade in?)
# 100% bolt-on install
# No special tools or talents necessary
# Features: Stretched wheel well allows running one size larger tire on the same lift
# Fenders jig welded and assembled
# 3", 4.5", or 6" of wheel coverage
# Fenders ship with new battery mounting bracket
# Integrated inner fender has room for mounting all accessories
# Requires AirAid (or similar) aftermarket filtration system
Our full replacement fenders do allow for the use of all stock under-the-hood accessories. Once the fenders are installed the components will almost tell you where they need to go. Every popular model (base to Rubicon) has been tested and can be done with no more than simple hand tools and a drill.
When installing these fenders you will be required to remove and replace your stock battery mounting bracket as it will no longer fit on the new fenders. We supply you with a new battery mounting bracket with the order of each set of tube fenders.
Weelz
Weelz's Reviews
06-09-2011, 11:05 AM
Price: $800.00
Pros: Tough. Good welds. Relatively easy install. Tons of room in the wheel well. Fit well against the tub--looks almost like OEM stuff.
Cons: Less engine compartment space. Fenders arrive as raw steel. Instructions could use some work.
Recommended? Yes
Comments: Got the hylines. They look very cool--I get comments all the time. TONS of room for big meats. I run 35x12.5x15Rs, with a 1" body lift, and I could probably run 37s without any fit problems. Relatively easy install: I'm no mechanic, and was able to do it all in my back yard. Even cutting the hood wasn't a big deal, just measure twice, cut once, I used a cutting wheel/angle grinder. Installation instructions were okay, with a few minor issues--they didn't address how to cut the hood properly, or even give any advice along those lines. The directions also didn't describe how to properly use the included TnT battery box--had to figure that out myself (just use an Optima--its fits right in the TnT battery box, though you'll need your own hold-down strap/mechanism).
rstolz
rstolz's Reviews
03-22-2011, 11:53 PM
Price: $595.95
Pros: Increased clearance
Cons: none
Recommended? Yes
Comments: These flairs are great. The install was trickier than suggested by TNT though - relocating everything on the driver's side fender was a project.
boarder15675
boarder15675's Reviews
09-22-2010, 08:17 AM
Price: $650.00
Pros: Very complete highline fenders, no cutting of the original fenders required. No more rubbing 35's
Cons: price may seem a bit high, but the product you get is well worth it. instructions for under-hood accessory mounting is vague at best.
Recommended? Yes
Comments: The overall quality of workmanship is excellent as is evident by just looking at the fenders. Although it took entirely too long (2 months) to get my tube fenders, they were willing to throw in their led marker light kit for free, which saved me the time of finding one that would look good on my jeep, and the ones that they offer just look bada**.
TinBadge
TinBadge's Reviews
03-27-2010, 01:08 AM
Price: $1,335.00
Pros: Tough as nails and look great. Best route to take if you need even to replace just the front fenders. The price I listed was for Feb of 08 and I did all four corners for what it was going to cost me in two new factory fenders not including what I would have had to spend on new flares that were just going to get tore off again. This is the best route to take to get the most bang for you buck.
Cons: On the inner fender both inside and out where they over lap it is hard to get this area sealed up. But other than that still a great product
Recommended? Yes
Comments: Very tuff stuff. You will have to have some good C-Clamps and a couple of strong friends to help you fit everything into place to drill your holes, bolt them on and I would also recomend doing this before you have them painted. Everything pretty much went right into place. Also would recommend getting all stainless steel hardwear. Not that there is anything wrong with bolts they supply but stinless steel bolts will cause you less problems down the road and make instilation a lot easier. These have been on my rig since Feb 08 and the only issues I have encoutered is where the inner and outer fenders overlap I did not get these areas sealed up as I had mine powder coated and moister gets in there and it has caused surface rust to form on the edges. I need to have them sand blasted and either weld these areas up or just have them painted and use a good seam sealer on these areas. Other than this they are still a great product and if i would ever have to do another Jeep I would buy another set of them. Very good stuff.
Volacious
Volacious's Reviews
07-02-2009, 04:51 PM
Price: $569.99
Pros: tough, and made out of quality heavy gauge steel
Cons: need some tweeking before you paint and mount them.
Recommended? Yes
Comments: I love the look and the durability; however, you will definitely need to pre-fit them before you paint and mount them. There are some small adjustments needed
TJRubicon06
TJRubicon06's Reviews
05-27-2009, 10:15 PM
Price: $550.00
Pros: Full replacement fender, no need to cut your stockers. A TON more clearence
Cons: None.
Recommended? Yes
Comments: Full replacement tube fenders, fits properly, easy enough install. I would recomend thses to anyone looking for full replacement fenders.
lostsheep
lostsheep's Reviews
03-26-2009, 11:52 AM
T&T Customs T&T Customs TJ Full Replacement Tube Fenders
Pros: Lots of Beef, look good
Cons: small gap on inner fender
Recommended? Yes
Comments: They went on fairly easy but they are not bolt on (bolt on is a myth) . I don't care for the gap on the inner fender but surprisingly, the engine compartment stays dry so I'll live with it. I love em
chappy84
chappy84's Reviews
04-23-2008, 07:37 PM
Pros: Vary beefy and good looking
Cons: didn't pre-drill mounting holes
Recommended? Yes
Comments: I really like being able to literally seperate two trees with these fenders so that I can pass through (on private land) They went right on.
Lostj
Lostj's Reviews
10-24-2007, 10:05 PM
Recommended? Yes
Comments: Im putting these on my jeep now. they are very beefy compared to the stockers. ill post pictures and a better review when I finish
ThreadForumRepliesLast Post
Offroad Utopia: TJ front Tube Fenders Fender Flares 4 04-24-2010 12:33 AM
Full Circle Fabrication - Tube Doors Exterior Accessories 0 01-22-2010 02:13 AM
Poison Spyder Customs Trail Corners Exterior Accessories 4 08-28-2009 11:16 AM
DirtyFab Tube Fenders Fender Flares 1 07-09-2008 02:51 AM
Aluminum Customs Cyclone Hood Panel Insert Exterior Accessories 1 04-24-2008 07:52 AM
Glock Forum
