Omix-Ada 7" Extended Fender Flares (97-06 TJ)
Rating: |
Product Information
| MSRP: |
$179.00 |
| Average Price: |
$138.17 |
| Manufacturer: |
Omix-Ada |
| Recommended? |
7" Extended Fender Flares for 1997-2006 Jeep Wranglers.
OEM Construction
cbandit's Reviews
Price: $180.00 Pros: clean stock look, got my jeep to inspection due to wheel/tire set up Cons: haven't found any yet, have had for 9 months Recommended? Yes
Comments: Stock look with the extended flares for large wheel / tire set-ups. Great product for the buck!
donny-d's Reviews
01-27-2009, 10:04 PM |
Price: $169.00 Recommended? Yes
Comments: Went on real nice...though i just about wore my fingertips off putting those plastic nuts on behind the fender liners and/or sheet metal.
Ghost00TJ's Reviews
10-10-2008, 09:23 AM |
Price: $179.00 Recommended? Yes
Comments: These were an easy and complete kit to install, all hardware parts were replaced.
They have held up to some tree bumping.I did crack one on a tree but it was hit fairly hard so I dont blame that on the flare at all. For $180 shipped its great.
erichapman's Reviews
07-28-2008, 08:37 PM |
Price: $150.00 Recommended? Yes
Comments: they do what they're meant to do.
and you get used to the looks.
pretty easy to instal, too.
Hawke's Reviews
01-13-2007, 05:56 AM |
Pros: Very Rugged for extreme wheelin, and very affordable Cons: Not the best for the pretty boy jeeps... Recommended? Yes
Comments: I have these flares on my 94 YJ. I have had them smashed flat against the body, even though the sheet metal recieved dents the flares snapped right back into shape with a few scratches, but that matches the rest of my rig. I would assume that very cold temperatures would make them brittle. However if and when I need flares again, Omix will be my choice
cheesycook's Reviews
08-17-2006, 05:45 PM |
Pros: Covers almost any tire at a great price. Hard to hurt. Cons: I got teased that I had park bench seats. Recommended? Yes
Comments: If you need a flare this large it's hard to beat for the money. If I did bash them in I just got a white coloring on them that paint would fix. They were tough enough for my little girl to jump on.
XTC Jpr13's Reviews
07-31-2006, 05:10 PM |
Pros: Cheap, wide enough to cover all tires, Keeps you legal Cons: looks funny if your tire does not fill it out Recommended? Yes
Comments: If you want a stock style flare that is large enough to cover 12.5" wide tires, this is the flare for you! Very durable, i dented mine in against a tree, then flipped it ove and hammered the dent back out, and now it is barely noticeable. easily painted, and straight forward install!
digitalcox's Reviews
07-31-2006, 12:36 PM |
Price: $150.00 Pros: Coverage for your tires if your state has laws against exposed tires, inexpensive, complete bolt on Cons: Looks goofy with the wrong tire / wheel combination, fade fairly easy Recommended? Yes
Comments: I got these flares just because of the state I live in (Pennsylvania) the law requires full tire coverage. They are kind of nice because the Jeep doesn't get as dirty as it use to when going off-roading, but they do fade really easy and look really goofy.
I must say though, they are pretty durable when it comes to coming into contact with trees or other obstacles. They took a couple nice hits and haven't cracked.
My girlfriends dad runs the same flares but has a 33x12.50 tires on a 15x10 wheel and it gives it a nice wide, aggressive stance.
-Justin
