Put 35s comfortably on a stock TJ/LJ, with NO LIFT KIT...
SAVE TIME & MONEY...
Our Front Flares and Fenders are BOLT-ON. No grinding or cutting of our product or your rig to "make it fit"! That means you can install these dynamic fenders from the comfort of your own garage with a few standard
No need to cut your stock fenders or wheel well, just unbolt them, so you can resell your pair and SAVE $$$!
ADDITIONAL INFORMATION:
Installation Difficulty Easy - Bolt On
Time to Install 4 - 6 hours
Body Modification None
Easy to install, Easy to paint, Good Functionality
Cons
None yet
Recommended
yes
Comments: I purchased these a few weeks ago directly from Metal Cloak. The guys there treated me very well and put together and shipped out my order very quickly. All the components arrived in good shape, and were easy to prep to put on my vehicle.
Product bolted right in with no problems and worked out perfect. I am running 33" tires with 2" to spare and could have ran 35" tires.
Cons
The product took away the stock look of the jeep.
Recommended
yes
Comments: The product worked out perfectly. The product claimed to bolt right in and it did, it took me about 4 hours to install both of the fenders. The customer service was amazing even after I purchased the product.
Rear fender flare should have a bit more metal cut out to allow for even better performance
Recommended
yes
Comments: The rear flares offer another inch of clearance if the wheel well would be trimmed back apx 1", this would allow for more clearance and could be easily done. I'm not complaining, just offering constructive criticisim...THIS IS A GREAT PRODUCT...VERY VERY HAPPY GO OUT AND GET SOME!!!
Clears 35s stock. Well built, bokt on. Quick to remove flairs
Cons
Not cheap.
Recommended
yes
Comments: Fast shipping, great customer service.
Their textured powder coat is sooooo nice, if your debating on getting it or not just spend the money you won't be disappointed. I got mine bare steel for cost savings, but I kinda regret it now.
Beefy, truly bolt-on, superior clearance, look great
Cons
The Price
Recommended
yes
Comments: Where to start with the praise? Man let's start with the customer service and shipping. Matson and the boys and MC are awesome. Every time I called they were friendly and helpful. They shipped extremely fast and the fenders were packed so well, they could have survived a tornado.
On to the fenders themselves: the install was a breeze with only a couple hand tools needed. The fenders were truly bolt on. The welds are beautiful, everything fit together w/o modification, and the powder coating was superior. Lastly, the instructions supplied by MC were phenomenal with illustrations/pictures for EACH step.
I run 35s with a 3.5" SL and 1.25" BL and would stuff the tires at full articulation. With the arched tubes from MC, it looks like I am running 33s on the same setup.
If you are on the fence about purchasing these, go ahead and get em. You won't be sorry.
heavy duty, easy to install, great inner and outer clearance, easily modified inner fender,
Cons
price, edges are sharp i would recommend beveling them before paint.
Recommended
yes
Comments: great heavy duty fenders with amazing functional clearancing. easy to attach accessories. the edges of the steel are sharp, should be beveled before painting.
Comments: The installation was not difficult. This product was a true bolt on. I installed the arched fenders with 6 inch flares in the front and mod cuts in the rear with flares to match. I also installed the rocker rails to match. The whole install was very straight forward.
Bolt on, looks B.A., great quality, excellent service.
Cons
none
Recommended
yes
Comments: While planning my YJ, I saw a build on a forum with amazing fenders :drool: Those bad boys bridged the gap between running large tires with room to flex and a low center of gravity, in short, they needed to be mine. I sent the poster a PM and he introduced me to Metalcloak :wolverine:. I soon ordered a complete set with overline fenders, rockers, mod cut rears and 4" flares, all powdercoated black. Metalcloak does a great job updating the 'My Account' page, so you can see progress and shipping. Everything came in perfectly labeled packages, wrapped very well, so as not to damage the powdercoat, before a trail does. Everything went on so easy, it was refreshing. If other kit manufacturers had such thoroughly detailed instructions I could've saved so much time, frustration learned a lot less curse words while updating the rest of her :brickwall. Metalcloak truly makes a bolt on kit, the only snafu for me was that a couple of bolts were missing from the rocker hardware package, a quick call to Matson, and they were overnighted the next day, with a long sleeve Metalcloak shirt thrown in! :thumbsup: Overall product quality is outstanding, looks are amazing and customer service sets the bar to where every Jeep vendor in our community should aspire to achieve. Thanks guys, awesome stuff!
Oh I'm running a RE 2.5" with 35s and still have a boatload of clearance.
Excellent customer service, very nice product, fits perfect and looks perfect.
Cons
none i can see
Recommended
yes
Comments: Been waiting quite some time to get these, they are kind of expensive but worth every penny to me. The fit and finish on these fenders is outstanding. I didnt get these painted from metalcloak but wish i would have. I was trying to save some money. The do a great job on there powder coat too. I have the rocker guards and front bumper as well. Same great quality.
Comments: roughly $1100 with the innerfenders too, i relocated the turnsignals from where they intended for them to be mounted, but other than that, i love this product!
Comments: Install was easy and I'm not the best mechanic. Makes room for my 33's on stock suspension and allows it to breath and work the way it's supposed to. I get more articulation now with factory components than I could imagine.
Comments: I originally bought these because i loved the look and like the idea of them being about the size of an overline kit but without the price of an overline kit. The look great and allow great flexing.
Looks awesome, not hard to install. Also came with a more expensive, aluminum option.
Cons
Side markers are harder to see than I like, hood is catching on the flares/hood latches.
Recommended
yes
Comments: Customer service was awesome, Got on Free shipping sale. Order got here pretty quick. Only thing I can complain about is my hood not fitting right with the fenders.
Comments: I ordered in raw metal and I had a hard time painting them. awkward. Unless you plan on taking them to a paint shop or have your shop get them already powder coated. They installed easily but instructions are not too clear. They look great and have complete clearance.
Comments: Took roughly 2 weeks after ordering to receive my shipping notice, arrived at my doorstep in 3 days. These were easy to install and do not require cutting or welding. There are some things such as wiper reservoir that may need to be relocated but the aluminum inner fender allows easy relocation, just drill out a new hole where you need it. I have not put flares onto it yet but from the looks of it they just bolt into two holes on the fender. Seems super legit. I spoke with customer service multiple times, Will is an outstanding guy. If you feel you have any questions do not hesitate to call as they will readily be happy to help. I ordered Raw Material and painted them myself so I cannot comment on the quality of Powder Coating.
great instructions, easy to install cutting required, fits nicely
Cons
None found
Recommended
yes
Comments: I bought both front and rear 8" Metalcloak fenders. Mine were unpainted as I wanted to paint my the same white of my Jeep. After removing all the connected items in the engine area that was attached to the inner fenders and removing the old fenders, the installation of the new fenders went smoothly. The instruction show you were to install these items on the new fender wall plus they supply plenty of bolts, washers, and nuts plus a few small brackets to use for windshield bottle and horn mounting. I purchased the dual LED marker light kit which was easy to install with the downloadable instructions.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
