Bushwacker 6" pocket style fender flares
Rating: |
Product Information
| MSRP: |
$700.00 |
| Average Price: |
$6,578,947,701.97 |
| Manufacturer: |
Bushwacker |
| Recommended? |
They lasted about 3 months.
vanek11's Reviews
Price: $1.00 Pros: look good Cons: n/a Recommended? Yes
Comments: Work great for me, love the styling they provide.
shiftclick's Reviews
Price: $200.00 Pros: Easy to install and great quality. Cons: Not very good instructions and there was only enough rubber tape for the flares, not rock guards. Recommended? Yes
Comments: These aren't Bushwhacker branded, but they are an identical knock off from eBay. I think the manufacturer is Prestige. The eBay seller was HeavyDutyTrucks.
Hellions's Reviews
Price: $400.00 Pros: Solid construction. Good tire coverage. Look great! Cons: A real pain to install; especially the front flares due to the odd curves on the fender. Recommended? Yes
Comments: Although I really love these flares, the installation took WAY to long. The instruction are detailed enough it's just time consuming. Since drilling into the body is required you have to double a triple check before you commit to the hole. As much time as I took, I still miss-drilled one of the holes into a seam. This meant repositioning the entire flare and re-drilling the hole. The good thing about the install is that it is very easy to transfer the hole location measurements from one side of the Jeep to the other which really makes the second half of the installation a breeze.
Another issue is with the stainless hardware supplied with the kit. I realize SS is softer than many metals, but I had two of the screws strip when screwing them into the sheet metal. The threads basically peeled away.
Nonetheless, the effort is well worth it and there's no denying how good they look.
Side Note: I suggest trimming the rear sheet metal a little more aggressively than the instructions suggest.
moshmont's Reviews
Price: $377.00 Pros: Durable & a perfect fit. Cons: Side marker holes don't line up. Recommended? Yes
Comments: I bought these flares to fit with the wider tires I had put on & to keep the slop from throwing up the sides of the Jeep.
Easy to install & they look real good. The only problem I had was to trim the side marker holes to fit the lenses.
The price is a little high, but what do you expect from Bushwacker ?
dscabra's Reviews
Price: $250.00 Pros: Good quality and fit Cons: PITA to install. Take away quite a bit of tire clearence compared to flat style flares. Recommended? Yes
Comments: The rubber seal is a pain to get right during install. Also, if your old factory flares have been on for a while you may have some paint damage that will need to be fixed before installing these.
JPaulson923's Reviews
Price: $275.00 Pros: look great and I was able to paint them to the color of my jeep. Cons: break a little easier than expected but not to bad. Recommended? Yes
Comments: These fender flares can look great on pretty much any jeep because of their style and different look they stand out compared to the oem flares. Also they can be painted the color you want as long as you do it the right way. I highly recommend these if going to after market flares.
s_beckerle's Reviews
Price: $125.00 Pros: Added protection from the toss of stuff from my tires. Cons: Not very flexible, but I know thats not really a trait of these. Recommended? Yes
Comments: Added protection from the toss of stuff from my tires.
87yellowyj's Reviews
Price: $499.99 Pros: nice looking Cons: kinda cheap plastic Recommended? Yes
Comments: love em
roughrider's Reviews
Price: $550.00 Pros: looks great Cons: a little hassle to get to fit perfectly Recommended? Yes
Comments: great add on to my jeep.. look great and really add to the tough look. kind of a pain to get to fit perfectly on my jeep and a little expensive but very much so worth it!
TurboDave's Reviews
Price: $450.00 Pros: Work well Cons: Expensive Recommended? Yes
Comments: Had Bushwhackers on previous '99 TJ and feel they are superb.
TJLove's Reviews
Price: $450.00 Pros: Add such a great look to the Jeep body! Cons: Nothing major, just prevent mud from getting on the jeep while off-roading :) Recommended? Yes
Comments: This is the first thing I look at when I see my Jeep! Adds meatiness to the body and if you're replacing the old OEM flares, it makes it look like a whole new Jeep!
thelastcj's Reviews
Price: $350.00 Pros: look good and legal with oversized tires Cons: Not as durable as they say all of mine are cracked from wheeling. Recommended? No
Comments: Not worth the money 2 me, if your building a street princess and want the look then get them, if u wheel like i do u will just end up breaking them.
johnboy68's Reviews
Price: $150.00 Pros: Covers wider tires and rims with more backspacing. Adds room for more flex and bigger tire. Cons: Scratches easy, but doesn't look bad with scratches. You have to drill all new holes. Only attaches with sheet metal screws. Hasn't been a problem yet. Recommended? Yes
Comments: I DID NOT GET Bushwacker brand flares. They are eBay TAG fender flares and perfect if you like the Bushwacker style flares and a reasonable price. They do require drilling but are easy to install. They seem rigid but I have ran mine up against trees and they have flexed and not cracked. Also, they do scratch easy but don't look bad when scratched. I would buy them again.
robob280's Reviews
Price: $130.00 Pros: Great for 31x10.5x15 tires and look awesome on black Cons: Great except for they don't cover the existing holes or scratches from the old flares too well Recommended? Yes
Comments: Great except for they don't cover the existing holes or scratches from the old flares too well
95YJohn's Reviews
Price: $350.00 Pros: extra coverage Cons: scratch easily Recommended? Yes
Comments: I Love 'em!
keeps cops off my tail!
they cover most my tire and easily clean up
allhungup's Reviews
Price: $450.00 Pros: look real nice Cons: none Recommended? Yes
Comments: Easy install, very sharp looking. Gives the jeep a bigger stance. Traded my stock flares to another forum member for the bushwackers. Great deal huh
jeeping74's Reviews
Price: $450.00 Pros: easy install Cons: none Recommended? Yes
Comments: When it comes to fender flares the hardest thing to do is getting your old ones off. I bought the Bushwacker 4 3/4" pocket fender flares. The great thing is there is no modifying to install the flares, along with they look great. Bushwacker provides all the hardware needed to install the new flares. Remember to check and see how much tire coverage you need. Trust me you don't want flares that are going 2 or 3 inches past your tires, it wont look good at all. I will add one more thing. I don't see this and a con but more of something you need to understand before ordering. Bushwacker flares have a down slop to them. So if you don't have a lift and you plan on taking it off road there is a good chance you are going to rub tires with the flares.
YJWarrior's Reviews
Price: $399.00 Pros: Easy Install and very durable Cons: Expensive Recommended? Yes
Comments: They look great and keep my windows clean enough to see out of!
