Zone Offroad - Zone Offroad 1.25" bodylift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts Next Product
Rating:
Product Information
MSRP: $94.95
Average Price: $159.99
Manufacturer: Zone Offroad
Recommended?
Yes: 12 / No: 1
Company Website: http://zoneoffroad.com/product?ki=189&gr=-1
Good BL for the price. Comes with EVERYTHING YOU NEED,from radiator brackets, transfer case linkage bracket, steering shaft raise brkt, to locktite...
Plus comes with ALL grade 8 bodybolts. Instructions, customer service,and product are excellent, I cant be happier
# IF YOU LIVE IN THE RUST BELT< spray All bolts that have to come out every day begenning 1 week before installation with a penetrating spray (PB Blaster,WD40,ect.) and putting the BL on will go ALOT SMOOTHER!!!!
* Zone Offroad give FREE SHIPPING to Jeepforum members on orders over $100
None
EricD
EricD's Reviews
07-06-2016, 10:15 PM
Price: $529.99
Pros: Easy to install, part of combo lift that included SL/BL and MML.
Cons: Can't think of any yet.
Recommended? Yes
Comments: Part of combo kit, economical, easy to install.
thetolleyman
thetolleyman's Reviews
12-02-2015, 10:24 PM
Price: $100.00
Pros: Does what it is supposed to, complete kit.
Cons: None
Recommended? Yes
Comments: Complete kit, no issues.
MarkC73
MarkC73's Reviews
10-16-2015, 01:29 PM
Price: $95.00
Pros: Items as described
Cons: none
Recommended? Yes
Comments: Good body lift for the buck. Easy to install.
mudb0x
mudb0x's Reviews
03-20-2014, 01:04 PM
Price: $100.00
Pros: I have the Savvy 1.25" aluminum body lift. Love it! did not see it as an option from the provided list
Cons: non that I'm aware of
Recommended? Yes
Comments: Savvy body lift was not an option from the list. Aluminum 1.25"
noleyy
noleyy's Reviews
09-10-2013, 12:29 AM
Price: $110.00
Pros: bigger hight easier to install cheap
Cons: gave me no problems all
Recommended? Yes
Comments: i had to do was turn the rubber shifter boot a 180 degrees to make my shifts normal again so shiftier wont hit it
easy to install
Nadamamasboy
Nadamamasboy's Reviews
07-14-2013, 03:41 PM
Price: $99.00
Pros: Tire clearance!
Cons: Increased body - frame gap. Use bed liner to disguise it where you see your body color paint.
Recommended? Yes
Comments: Thorough instructions. I used a pair of ratchet straps to pull the body back into proper alignment. Be careful not to pull it too far forward (to get rad support bolt in) or you'll have shifter interference.
SilverKitten
SilverKitten's Reviews
11-15-2012, 04:25 PM
Price: $94.95
Pros: Easy install
Cons: None
Recommended? Yes
Comments: Delivered quickly. Easy to install with good directions. Gives perfect life for what I need.
W4rch1ld
W4rch1ld's Reviews
03-21-2012, 09:58 AM
Price: $529.99
Pros: Purchased as part of the Zone TJ 4.25 combo lift. Easy to install, durable components.
Cons: None.
Recommended? Yes
Comments: This was purchased as part of the Zone TJ 4.25" combo lift kit. Installation was simple with all included hardware. This is the first lift I have done and would recommend it to anyone interested in giving their Jeep a more aggressive stance and extra ground clearance for moderate off-roading.
Diverdown87
Diverdown87's Reviews
03-03-2012, 06:29 PM
Price: $1.00
Pros: simple to install
Cons: none yet
Recommended? Yes
Comments: Just put it on. Went from 3" body lift to this. Very odd getting in to the jeep now...But will have better input after using for a while..Next will be the 3" Zone suspension lift and MML.
Ironhead
Ironhead's Reviews
05-08-2011, 11:45 AM
Price: $95.00
Pros: easy installation, tons of extra parts
Cons: may have paid a bit extra for unnecessary parts do to doing MML lift at the same time
Recommended? Yes
Comments: Worth the money for the extra body clearance
Instructions were very easy to follow
Do yourself a favor and do the MML at the same time to avoid lots of additional work
ZJtothaTJ
ZJtothaTJ's Reviews
04-04-2011, 07:32 PM
Price: $150.00
Pros: Great instructions
Cons: None really
Recommended? Yes
Comments: It's a tually the 3" Body lift. The kit came complete and needed nothing. Very satisfied!
lkostenbader
lkostenbader's Reviews
03-09-2011, 08:28 PM
Price: $80.00
Pros: comes with all the hard ware you need.
Cons: directions were very bad and when I ordered the 2'' they gave me two 3'' lift blocks instead of 2'' body blocks.
Recommended? No
Comments: * New longer grade 5 body mount bolts are included
* Shifter Extension included
* Radiator relocation included
* Auto Shifter Adapter
* Indestructible body blocks are supplied
* Complete and easy to follow instructions make this body lift an easy "do-it-yourself" install
EricsGreen98Tj
EricsGreen98Tj's Reviews
11-25-2010, 10:02 PM
Price: $94.95
Pros: Comes with ALL grade 8 bodybolts. well thoughout kit. even comes with steering shaft relocation block
Cons: NONE
Recommended? Yes
Comments: I put this BL and a set of BrownDog 1" motormounts on at the same time. Doing this i didnt have to mess with the transfer case linkage OR the radiator brackets
This is one COMPLETE Bodylift
I also got a steering stablizer too so i DID get the JF member FREE SHIPPING
Instructions were good. I'd give em a 9 outta 10
All in all i cant be happier with the results
ThreadForumRepliesLast Post
Pilot 4" Offroad lights Lighting, Lenses & Bulbs 6 11-27-2013 11:53 PM
Iron Rock Offroad 2" Budget Boost Body Lifts 3 02-17-2013 03:42 PM
Viking Offroad Fastback Tops 17 03-19-2012 05:56 PM
Kevin's Offroad Spare Tire Carrier ZJ Roof Racks & Cargo Areas 3 10-16-2010 09:33 AM
stu-offroad Factory Fog Lights with High Beams Lighting, Lenses & Bulbs 1 07-08-2008 03:51 PM
