Go Back JeepForum.com > Reviews > Body > Body Lifts > Terra Flex One inch body puck
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Terra Flex One inch body puck Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts Next Product
Rating:
Product Information
MSRP: $4,500.00
Average Price: $576.44
Manufacturer: Terra Flex
Recommended?
Yes: 7 / No: 2
The puck inserts between the frame and uni-body of the vehicle with new bolts to hold in place.
bbail016
bbail016's Reviews
01-07-2012, 03:22 PM
Price: $100.00
Pros: budget
Cons: budget
Recommended? No
Comments: its a budget boost...I didn't put it on. guy i bought it from had it.
Tblack
Tblack's Reviews
03-22-2011, 06:26 PM
Price: $99.00
Pros: I like the material
Cons: none.
Recommended? Yes
Comments: Its a body lift, and thats what it did, lifted the body.
GruntMarine
GruntMarine's Reviews
12-21-2010, 07:00 PM
Price: $1.00
Pros: nothing special, average
Cons: nothing special, average
Recommended? Yes
Comments: nothing special, average
rocko-n-miss
rocko-n-miss's Reviews
11-25-2010, 05:03 AM
Price: $105.00
Pros: Very easy install, Very complete
Cons: Still looking, I don't give up easy. I'll find something dang it! lol
Recommended? Yes
Comments: These are once again a stand up product from Tera-flex. From right out of the box with great easy to follow instructions ( can't say the same for the photos, a bit over photocopied.) all the way to complete kit. I would buy it again and again.
charlope
charlope's Reviews
10-28-2009, 03:04 PM
Price: $1.00
Pros: 1
Cons: 1
Recommended? Yes
Comments: .
nelsonlandworks
nelsonlandworks's Reviews
07-05-2009, 09:06 PM
Price: $200.00
Pros: Easy install
Cons: Aluminum corrodes
Recommended? No
Comments: This product has a great idea behind it, but the aluminum ends up corroding, I will end up replacing it with polyurethane setup soon
xantasm
Cav scout
xantasm's Reviews
06-07-2009, 05:04 AM
Price: $117.00
Pros: Aluminum spacers, steel frame mounted radiator supports, transfer shifter relocation brackets provided
Cons: none
Recommended? Yes
Comments: For a 1" body lift this is perhaps the strongest body lift on the market. The aluminum spacers are machined and contoured to fit the curve of the upper side of the factory rubber body bushings to aid in seating during installation. The bolts provided are grade 8 quality and have larger size heads than the OEM bolts. The radiator support brackets are side frame mounted with bolts making for easier installation than weld in supports like most other kits. The transfer shifter relocation brackets are included in the TJ kit for pre 04 and 05-06 although both brackets can be used if the BL is being installed on a vehicle with suspension or tranny plate modifications. Unlike most other kits using polyurethane spacers, the aluminum spacers in this kit are well thought out and very durable.
visa
visa's Reviews
01-10-2009, 10:44 PM
Price: $4,500.00
Recommended? Yes
Comments: full galvy body from 94 so no rust wish you had that dont you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!
WhtRd
WhtRd's Reviews
11-19-2008, 05:36 PM
Price: $65.00
Recommended? Yes
Comments: Nice product to raise unibody for tire clearance. Went on easily just remember to do one side at a time. The only hard area to get to was the bolts at the back of the vehicle.
ThreadForumRepliesLast Post
truck light 4 inch led Lighting, Lenses & Bulbs 3 07-13-2011 02:06 PM
JKS 1.25" Body Lift Body Lifts 44 05-24-2010 06:34 PM
Preformance Accesories 3 inch lift Body Lifts 13 01-15-2010 09:46 AM
Performance Accessories 3 inch body lift3 inch body lift Body Lifts 14 02-22-2009 02:01 PM
Summit Racing 6 inch Off-Road Light - 100 watts Lighting, Lenses & Bulbs 1 02-10-2009 08:39 PM
Glock Forum
