Performance Accessories 3 inch body lift3 inch body lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts Next Product
Rating:
Product Information
MSRP: $325.00
Average Price: $141.14
Manufacturer: Performance Accessories
Recommended?
Yes: 21 / No: 3
3 inch body lift
None
Page 1 of 2 1 2 > Last
armyguard90
armyguard90's Reviews
06-05-2016, 05:55 AM
Price: $1.00
Pros: Looks nice!
Cons: N/A
Recommended? Yes
Comments: Came with the jeep, looks nice, gives some clearance.
mudwieser1
mudwieser1's Reviews
06-06-2015, 11:36 PM
Price: $100.00
Pros: Cheap and fairly easy
Cons: Rides rougher and higher center of gravity
Recommended? Yes
Comments: Body lift is easy to put on in the driveway with basic tools. You will have more body roll when driving on the roads though.
DarkBakedMuddy
DarkBakedMuddy's Reviews
02-15-2015, 04:16 PM
Price: $150.00
Pros: Easier to clean the frame,easy to install
Cons: Weakens the body mounts, may break bolts when flexing abusively
Recommended? Yes
Comments: It is a good product but I would recommend changing the hardware for stronger grade. Make sure when installing that your body mount nuts (in the cab) are not all rusty if so, I suggest that you spray alot of oil onto the nuts to try to eliminate most of the rust. In wich case that your nuts are too much rusted, I have another suggestion for you! Go from the inside of the cab and cut little doors right where the old nuts are, then remove them and try weld a new nut onto a plate of metal and then now weld the plate with the nut into the tub. Do that for all of them.
iamjustbill
iamjustbill's Reviews
02-04-2015, 12:51 PM
Price: $500.00
Pros: Great product
Cons: none
Recommended? Yes
Comments: Hard to review being that I had mechanic install. So far it has performed well. Would recommend this lift.
djleathal7
djleathal7's Reviews
02-26-2012, 05:47 AM
Price: $229.99
Pros: Looks good. Easy to install. Ha Ha had someone else do it!
Cons: None so far. Will update.
Recommended? Yes
Comments: Ordered from Quadratec. Fast delivery to Northern Ontario, Canada. 4 hours to install. Great product, so far so good.
jrayjeepcj2a
jrayjeepcj2a's Reviews
02-13-2011, 12:25 AM
Price: $90.00
Pros: holds up well after years of water and mud
Cons: nothing
Recommended? Yes
Comments: Haven't had any problems with the longer bolts or the bushings. Everything's in tact still!
gne100
gne100's Reviews
12-06-2010, 01:38 AM
Price: $100.00
Pros: Increased available tire size Higher driving height
Cons: Haven't noticed any yet, except for all the people that don't like them
Recommended? Yes
Comments: I have had no problem with my lift, I put it on because I snapped 3 bolts when I was putting on my rock crawlers. I found a guy that had the kit available, so I bought it and threw it on.
JasonRumler
JasonRumler's Reviews
06-15-2010, 05:39 PM
Price: $100.00
Pros: Lift!!
Cons: Don't really like body lifts. Just don't like the way they look.
Recommended? Yes
Comments: Personally I'm not a huge fan of body lifts. I just don't like the way they look, but if your looking for some inexpensive lift for your ride this is a good lift. It will definitely get you the extra clearance your after.
KennedyYJ
KennedyYJ's Reviews
04-03-2010, 02:47 PM
Price: $40.00
Pros: Its an inexpensive way for more lift and tire clearance.
Cons: Risk of greater stress on the bolts that can cause them to snap so be sure to keep an eye on them.
Recommended? Yes
Comments: I have no complaints with it. It works great but I'd have to say i wouldn't have gone this big in body lift if I didn't get it for the price I did just due to the risk but oh well.
Ged4th
Ged4th's Reviews
02-22-2009, 03:01 PM
Price: $250.00
Recommended? Yes
Comments: What can say about this, my jeep body is 3 inches higher than when it started so iI guess it works really good.
04wrangler221
04wrangler221's Reviews
01-04-2009, 11:39 PM
Price: $90.00
Recommended? Yes
Comments: I was going for big and my friends pick on me but with the body lift i was able to get the big tires without spending alot lifting my jeep!
southernss
southernss's Reviews
12-31-2008, 01:45 PM
Recommended? No
Comments: looks like crap previous owner put it on and i will be taking it off. 3" body lift is just wat to much for a jeep.
firefighter315
firefighter315's Reviews
12-12-2008, 12:40 PM
Recommended? No
Comments: Installed by PO. Coming off and being replaced by Daystar 1" body bushing replacements......
RedWind
RedWind's Reviews
11-02-2008, 08:36 AM
Recommended? Yes
Comments: What can I say its a body lift it came on my YJ when I bought it I am not even sure if this is the correct brand I just wanted it listed
bigredjeep95
bigredjeep95's Reviews
11-01-2008, 10:13 AM
Price: $105.00
Recommended? Yes
Comments: I installed this body lift 3.5 years ago, bolts have held tight, and lift blocks are still in one piece. Caution, I snapped two body mount bolts off in the body when installing this lift. All in all this lift works great.
Aparkhillp
Aparkhillp's Reviews
10-23-2008, 08:22 PM
Price: $50.00
Recommended? Yes
Comments: This came with my Jeep and helps to give me plenty of clearance for my 32's until I get a suspension lift.
Frstman
Frstman's Reviews
10-22-2008, 11:42 AM
Price: $250.00
Recommended? Yes
Comments: Has really enhanced the "mean" look of the jeep. Showing off more of the guts under the jeep
splash676
splash676's Reviews
09-22-2008, 09:44 AM
Price: $85.00
Recommended? Yes
Comments: it was a easy to install. no problems. it take roughly four hours to install. the hardest part was the the shifter for the transfer case.
cmandes13
cmandes13's Reviews
08-27-2008, 08:33 PM
Price: $100.00
Recommended? Yes
Comments: makes the body shake and hit hard rather just have a higher suspension give a nice look though
Dmax5er
Dmax5er's Reviews
07-18-2008, 11:43 PM
Price: $89.00
Pros: Better tire clearence
Cons: its a body lift.
Recommended? Yes
Comments: Ok for a body lift, dont really like the looks of them but i had no choice with the cj conversion to be done right, made better room for the 35" tires. Ended up cutting it down some.
ThreadForumRepliesLast Post
JKS 1.25" Body Lift Body Lifts 113 12-23-2016 04:32 PM
Performance Accessories 1" Body Lift Body Lifts 36 07-11-2014 08:58 PM
Performance Accessories 2" Body Lift - BL932 Body Lifts 43 03-27-2014 05:32 AM
Terra Flex One inch body puck Body Lifts 10 05-24-2012 07:47 AM
Preformance Accesories 3 inch lift Body Lifts 15 05-12-2012 09:19 PM
