Go Back JeepForum.com > Reviews > Body > Body Lifts > Performance Accessories 2" Body Lift - BL932
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full
Performance Accessories 2" Body Lift - BL932 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts Next Product
Rating:
Product Information
MSRP: $400.00
Average Price: $132.66
Manufacturer: Performance Accessories
Recommended?
Yes: 36 / No: 2
2" body lift kit
Page 1 of 2 1 2 > Last »
ivester1992
ivester1992's Reviews
01-31-2012, 11:41 AM
Price: $120.00
Pros: simple to install
Cons: noticeable gaps
Recommended? Yes
Comments: any diy mechanic can install this
mackcs212
mackcs212's Reviews
10-22-2011, 08:54 PM
Price: $700.00
Pros: stays strong in front end
Cons: rear sags after time
Recommended? Yes
Comments: looks great, cheap, just enough to raise body up, good idea to add hockey pucks to front coils to keep from topping out over big bumps
geyo
geyo's Reviews
10-09-2011, 09:34 AM
Price: $1.00
Pros: Better look and fit bigger tires
Cons: throws off fan alignment, Fueling tube and shifting. Have to make some upgrades and changes to get back normal operation.
Recommended? No
Comments: By the time you buy, instal and adjust everything (fan, shifter, Fuel system) Would just go with a suspension lift.
Natejeep
Natejeep's Reviews
08-02-2011, 08:25 AM
Price: $154.00
Pros: Gave me the added height
Cons: People on here don't like them, and they all let you know..
Recommended? Yes
Comments: For staters if gives you what you want. Then you can add the tire set up and down the road add your suspension you need and remove the DL
FanelliT
FanelliT's Reviews
04-26-2011, 01:05 PM
Price: $99.95
Pros: lifts jeep easily
Cons: its just a body lift
Recommended? Yes
Comments: great lift kit for someone whos not off roading a lot, or doesnt have the money for a full suspension lift
WildChild46
WildChild46's Reviews
03-16-2011, 10:28 PM
Price: $150.00
Pros: clearance between body and frame
Cons: Needed longer bolts
Recommended? Yes
Comments: Fits well. Captured nuts were shot so had to get longer bolts and drill holes for body swap
southerngirl
southerngirl's Reviews
12-28-2010, 09:38 AM
Price: $84.99
Pros: Adds tire clearance
Cons: None.
Recommended? Yes
Comments: ...
rexford71
rexford71's Reviews
11-13-2010, 08:43 PM
Price: $95.00
Pros: helped clear 31's
Cons: had to cut shifter opening and extend shifter
Recommended? Yes
Comments: I've had the body lift for 10 years and it still feels like stock, no squeaks or shifting of the body. Launched the poor jeep a few times in Glamis and it held up well.
gman99tj
gman99tj's Reviews
08-16-2010, 10:56 AM
Price: $129.00
Pros: easy
Cons: none
Recommended? Yes
Comments: good kit easy to install
RodrigoC
RodrigoC's Reviews
07-21-2010, 01:53 PM
Price: $105.00
Pros: Good quality and easy installation
Cons: None so far
Recommended? Yes
Comments: I have a Zone BL but the options don’t have this brand.
These body lift blocks are capable of holding up to 60,000 lbs or at least that’s what they say…….
New longer body bolts are included, unlike some other products when a run to the hardware store is needed. Everything you need to properly lift the body is included with detailed instructions for an easy installation.
Fuel filler extension is included, radiator relocation system is included to ensure proper air flow, transfer case linkage relocation is included to avoid binding the shifter, steering carrier bearing relocation bracket is included to correct the steering linkage angles.
Overall is a good product at an unbeatable price $105
SnowdogMarc
SnowdogMarc's Reviews
03-26-2010, 12:43 AM
Price: $80.00
Pros: easy install
Cons: none
Recommended? Yes
Comments: gives me clearance for the 31's at full flex
inkpen00
inkpen00's Reviews
02-24-2010, 04:31 AM
Price: $120.00
Pros: Easy to install!!
Cons: n/a
Recommended? Yes
Comments: Very easy to install!! Very quick to install!!
Recommended for a little bit of extra tire clearance!
subzer008
subzer008's Reviews
01-26-2010, 11:51 AM
Price: $1.00
Pros: cheap, easy install
Cons: its a body lift
Recommended? Yes
Comments: Easy install and helped fit some bigger tires. Seem like they are pretty solid blocks.
UltimateCC
UltimateCC's Reviews
07-02-2009, 08:12 PM
Price: $11.00
Pros: 0
Cons: 0
Recommended? Yes
Comments: 0
rjsbow
rjsbow's Reviews
06-12-2009, 10:00 AM
Price: $99.99
Pros: good instructions
Cons: none
Recommended? Yes
Comments: very easy install. Took about 2 hours. Did not need to move radiator
smoke52458
smoke52458's Reviews
05-11-2009, 08:02 AM
Price: $109.00
Pros: Tire Clearance
Cons: Installation
Recommended? Yes
Comments: This body lift has all the correct hardware for installation. It comes with good instructions and deviations were required for assembly. It takes approximately 6- 8 hours to install correctly. Some modification are required for the clutch rod to accommodate the 2" lift.
MassRedneck
MassRedneck's Reviews
03-30-2009, 03:10 PM
Price: $100.00
Recommended? Yes
Comments: Installation should have been simple, but rusty bolts took sime time. Directions are very clear, an dnow my jeep goes straight down the road when i let go of the wheel.
Irockatgms
Irockatgms's Reviews
03-21-2009, 10:45 PM
Price: $400.00
Recommended? Yes
Comments: love the body lift, wish I would've gotten a 3" but 2" will do fine I mean after you hit a threshold of 10+ inches...whats another inch?
abbottg
Junior Member
abbottg's Reviews
02-28-2009, 10:10 PM
Recommended? Yes
Comments: Never thought the jeep would be too tall, but with the 4" lift, it seems a little overkill. May remove BL and go back to stock bushings.
wojo4780
wojo4780's Reviews
02-23-2009, 12:12 PM
Price: $100.00
Recommended? Yes
Comments: not sure what kind of body lift it was got it from 4wd.com it came with everythang easy to do took more time drinking beer
ThreadForumRepliesLast Post
JKS 1.25" Body Lift Body Lifts 44 05-24-2010 06:34 PM
Performance Accessories 1" Body Lift Body Lifts 29 09-20-2009 10:58 PM
Prothane 87-95 YJ 1`` Body Lift Body Lifts 2 09-05-2009 08:56 PM
Performance Accessories 3 inch body lift3 inch body lift Body Lifts 14 02-22-2009 02:01 PM
Mopar Mopar Performance Body Kit Exterior Accessories 1 10-01-2008 08:18 AM
Glock Forum
