Performance Accessories 2" Body Lift - BL932
Rating: |
Product Information
| MSRP: |
$400.00 |
| Average Price: |
$135.84 |
| Manufacturer: |
Performance Accessories |
| Recommended? |
mrmark's Reviews
Price: $100.00 Pros: n/a Cons: n/a Recommended? Yes
Comments: Just put it in today so no opinion of ride, was easy to install
booked101's Reviews
Price: $99.00 Pros: Easy way to add a little lift to old ZJ. Looks like it should have stock. Cons: none Recommended? Yes
Comments: These spacers were a breeze to install (for the most part). After unbolting the sway bar links and pushing the axle down as far as possible on one side to get the coil spring out we realized that spring compressors would be so much easier. So after using the spring compressor it was smooth sailing.
67Camaro's Reviews
Price: $249.00 Pros: solid product to purchase Cons: little harder to install, but good for the money Recommended? Yes
Comments: Good product for the money...directions are not as easy to follow, but with some patience it can be done...
CamJeep77's Reviews
Price: $200.00 Pros: Well thought out & everything required lots of instructions Cons: some steps not super detailed Recommended? Yes
Comments: The kit arrived within 2 days. Came with everything required to complete job. Very good / detailed instructions
ivester1992's Reviews
Price: $120.00 Pros: simple to install Cons: noticeable gaps Recommended? Yes
Comments: any diy mechanic can install this
mackcs212's Reviews
Price: $700.00 Pros: stays strong in front end Cons: rear sags after time Recommended? Yes
Comments: looks great, cheap, just enough to raise body up, good idea to add hockey pucks to front coils to keep from topping out over big bumps
geyo
 Registered User |
geyo's Reviews
Price: $1.00 Pros: Better look and fit bigger tires Cons: throws off fan alignment, Fueling tube and shifting. Have to make some upgrades and changes to get back normal operation. Recommended? No
Comments: By the time you buy, instal and adjust everything (fan, shifter, Fuel system) Would just go with a suspension lift.
Natejeep's Reviews
Price: $154.00 Pros: Gave me the added height Cons: People on here don't like them, and they all let you know.. Recommended? Yes
Comments: For staters if gives you what you want. Then you can add the tire set up and down the road add your suspension you need and remove the DL
FanelliT's Reviews
Price: $99.95 Pros: lifts jeep easily Cons: its just a body lift Recommended? Yes
Comments: great lift kit for someone whos not off roading a lot, or doesnt have the money for a full suspension lift
WildChild46's Reviews
Price: $150.00 Pros: clearance between body and frame Cons: Needed longer bolts Recommended? Yes
Comments: Fits well. Captured nuts were shot so had to get longer bolts and drill holes for body swap
rexford71's Reviews
Price: $95.00 Pros: helped clear 31's Cons: had to cut shifter opening and extend shifter Recommended? Yes
Comments: I've had the body lift for 10 years and it still feels like stock, no squeaks or shifting of the body. Launched the poor jeep a few times in Glamis and it held up well.
gman99tj's Reviews
Price: $129.00 Pros: easy Cons: none Recommended? Yes
Comments: good kit easy to install
RodrigoC's Reviews
Price: $105.00 Pros: Good quality and easy installation Cons: None so far Recommended? Yes
Comments: I have a Zone BL but the options don’t have this brand.
These body lift blocks are capable of holding up to 60,000 lbs or at least that’s what they say…….
New longer body bolts are included, unlike some other products when a run to the hardware store is needed. Everything you need to properly lift the body is included with detailed instructions for an easy installation.
Fuel filler extension is included, radiator relocation system is included to ensure proper air flow, transfer case linkage relocation is included to avoid binding the shifter, steering carrier bearing relocation bracket is included to correct the steering linkage angles.
Overall is a good product at an unbeatable price $105
SnowdogMarc's Reviews
Price: $80.00 Pros: easy install Cons: none Recommended? Yes
Comments: gives me clearance for the 31's at full flex
inkpen00's Reviews
Price: $120.00 Pros: Easy to install!! Cons: n/a Recommended? Yes
Comments: Very easy to install!! Very quick to install!!
Recommended for a little bit of extra tire clearance!
subzer008's Reviews
Price: $1.00 Pros: cheap, easy install Cons: its a body lift Recommended? Yes
Comments: Easy install and helped fit some bigger tires. Seem like they are pretty solid blocks.
rjsbow's Reviews
Price: $99.99 Pros: good instructions Cons: none Recommended? Yes
Comments: very easy install. Took about 2 hours. Did not need to move radiator
smoke52458's Reviews
Price: $109.00 Pros: Tire Clearance Cons: Installation Recommended? Yes
Comments: This body lift has all the correct hardware for installation. It comes with good instructions and deviations were required for assembly. It takes approximately 6- 8 hours to install correctly. Some modification are required for the clutch rod to accommodate the 2" lift.
