Go Back JeepForum.com > Reviews > Body > Body Lifts > M.O.R.E (Mountain Off Road Engineering) Lift for TJ's: BLTJ97
Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFGSALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30
M.O.R.E (Mountain Off Road Engineering) Lift for TJ's: BLTJ97 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts Next Product
Rating:
Product Information
MSRP: $150.00
Average Price: $102.82
Manufacturer: M.O.R.E (Mountain Off Road Engineering)
Recommended?
Yes: 13 / No: 0
M.O.R.E. invented the one inch body lift "Puck" over 13 years ago. With the need to keep increasing tire sizes and the new generation of flexible suspension systems, it has become a necessity to move the body away from the frame for increased tire clearance. One inch doesn't sound like much, however in most cases it will give you the extra clearance you need, without making your Jeep® look like it has a body lift. Our "Pucks" are made out of 6061-T6 aluminum. Were talking about aircraft quality stuff here! They will not crush, break or slip around once bolted in place. Natural aluminum color looks great under your rig. No plastic to break or look "cheap".
BODY LIFT "PUCKS" are available separately if you want to make up your own body lift.
BODY LIFT "KITS" consist of enough "Pucks" for your Jeep®, longer grade 5 bolts, flat washers, misc. brackets and instructions.
BODY LIFT "SYSTEMS" come with everything the KITS come with in addition to new polyurethane body mounts. You save time and money when you install the SYSTEM under your rig.
lupinsea
lupinsea's Reviews
07-19-2011, 07:02 PM
Price: $100.00
Pros: Very complete body lift including the front grill spacers (either side of the grill body mount) and a spacer for the steering shaft bearing on the driver's side frame rail. Also, spacer pucks machined out of aluminum.
Cons: A little pricey vs others
Recommended? Yes
Comments: This body lift has worked very well for 6 years now. I liked the fact that it seemed more complete than other lifts with the inclusion of a spacer for the steering shaft bearing (midway between the firewall and grill on top of the driver's side frame rail) and spacers for the two rubber grill mounts (either side of the front body mount). The aluminum body spacers are also holding up very well. Zero sign of crushing or corrosion. The lift was also installed with M.O.R.E.'s 1" motor mount lift.
petegall79
petegall79's Reviews
04-16-2010, 10:05 PM
Price: $100.00
Pros: compensaites for the MML
Cons: shiny "silver" pucks.
Recommended? Yes
Comments: Straightforward install, no complaints in that category.
Not easy to get urethane grill "bumps" (what are they called?) mounted well. Lubed up and got the elbow grease flowing, but still 1/2 hour of effort. Actually I'm not quite sure yet if they're fully inserted...
Would have appreciated t-case bracket relo to be included... I shredded rubber on tub-mounted bracket after loosening bolts and then pulling each out. At least Quadratec got me the AA bracket in 2 days for cheapo UPS ground.
Complete kit for it's approach. Directions contain reminders and are logically designed (even if they don't spell out WHY you do certain things before others).
TheHeilis
TheHeilis's Reviews
02-18-2010, 10:19 AM
Price: $130.00
Pros: Aluminum pucks and ALL needed brackets and hardware.
Cons: None
Recommended? Yes
Comments: Great product, very straight forward installation with good instructions and pictures. Installed this on a Saturday afternoon. An angle drill makes life much easier when re-locating fan shroud.
2003X
2003x
2003X's Reviews
01-24-2009, 07:16 PM
Price: $100.00
Recommended? Yes
Comments: Excellent quality. Gave me the extra lift I needed. Strong product.
tjtone
tjtone's Reviews
06-11-2008, 06:28 PM
Price: $1.00
Recommended? Yes
Comments: Very straight forward install excellent instructions took me by myself about 3 hrs. BTW i havwe no right hand.
Twitchy
Twitchy's Reviews
05-02-2008, 11:23 PM
Price: $150.00
Recommended? Yes
Comments: Workds for me, has given my TJ a nice aggressive stance. Quite pleased with the results.
rescueTJ
rescueTJ's Reviews
04-28-2008, 05:13 PM
Price: $100.00
Recommended? Yes
Comments: Simple install. Pucks are Aluminum. I would also highly recommend doing the 1" torsion rubber motor mount lift at the same time.
RubiRock
RubiRock's Reviews
04-16-2008, 11:21 AM
Price: $100.00
Recommended? Yes
Comments: high quality pucks and hardware and extra attention to detail, as evidenced with the inclusion of the steering shaft spacer.
Wheels4186
Wheels4186's Reviews
04-09-2008, 03:53 PM
Price: $100.00
Recommended? Yes
Comments: Works great, love the metal spacers.
Rubikahn
Rubikahn's Reviews
03-16-2008, 08:48 PM
Price: $130.00
Recommended? Yes
Comments: Very easy to install.
JeepRocks86
Some Call me RockDog
JeepRocks86's Reviews
08-30-2006, 11:11 AM
Pros: easy install.
Recommended? Yes
Comments: easy install
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Reviews
08-03-2006, 08:16 PM
Recommended? Yes
Comments: The grille spacers on my kit are rusting, but otherwise no complaints. The kit has everything you need and my t/case shifter worked perfectly with no adjustments needed after I installed the included bracket.
BlueJ
BlueJ's Reviews
08-03-2006, 05:50 PM
Price: $120.00
Pros: Made of aluminum not products made of Dino Juice. Has transfer case drop and steering correction plates included. Great for the price.
Cons: None at all other then metal color, but that was easily painted.
Recommended? Yes
Comments:
ThreadForumRepliesLast Post
Black Mountain 2" Body Lift Body Lifts 3 01-25-2012 05:32 PM
Off Road Only LiteDOTS LED Tail Lights Lighting, Lenses & Bulbs 12 09-14-2011 05:00 PM
Off Road Only LiteDOTs™ LED Tail lights Lighting, Lenses & Bulbs 7 01-20-2011 09:35 PM
JKS Engineering PN 9904 Body Lifts 60 04-01-2009 02:05 PM
Durango4x4 Mountain Basket for Warn Tire Carrier Exterior Accessories 1 09-06-2008 09:19 AM
Glock Forum
