JKS Engineering PN 9904 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Body Lifts Next Product
Rating:
Product Information
MSRP: $1,000,000.00
Average Price: $21,850.72
Manufacturer: JKS Engineering
Recommended?
Yes: 60 / No: 1
The B1 Body Lift by JKS offers an economical solution to tire clearance problems, without affecting center of gravity, spring rate or steering geometry like suspension modifications. Unlike universal designs commonly used by our competitors, JKS B1 Body Lifts are specifically designed to work in conjunction with the OE body mounts.
Our B1 Body Lifts actually provide 1.25" of additional tire clearance, as opposed to the standard 1" provided by other manufacturers. The Jeep® specialists at JKS have found this to provide the ideal amount of tire clearance without exceeding the safe working parameters for severe off-road use. Furthermore, no modifications are required to the fuel tank, air conditioning, radiator, or brakes, unlike taller body and suspension lifts.
Manufactured from premium Dura-Thane™ poly material with a hardness of 94 durometer, JKS B1 Body Lifts are designed to easily exceed the demands of four wheeling.
None
Page 4 of 4 1 2 3 4
LoneJeeper
i wear foil underwear too
LoneJeeper's Reviews
07-31-2006, 08:54 AM
Price: $89.00
Pros: get your fenders out of the way, cheaply.
Cons: ugly gap between body and frame
Recommended? Yes
Comments: An easy cheap lift. I highly recommend the BL & MML combo.
With a 1" kit, you don't need to do much at all.
1) Install the new "poly pucks." (Do one side at a time!)
2) Install the Radiator Grill Spacers.
3) Relocate the Fan Shroud by cutting slots where the existing holes are and moving the shroud down ~1".
4) Install the Transfer Case Linkage Drop Bracket to re-align the linkage.
Doing a 1" Motor Mount Lift at the same time makes Steps 3 and 4 unnecessary; and it helps align the drivetrain if you are doing a substantial suspension lift or Belly-Up skid plate.
Write-Ups: (Not necessarily for the JKS body lifts)
http://www.jeepbrokers.com/jeep_project_1_body_lift.htm
http://4x4xplor.com/bl.html
lj
Page 4 of 4 1 2 3 4
ThreadForumRepliesLast Post
M.O.R.E (Mountain Off Road Engineering) Lift for TJ's: BLTJ97 Body Lifts 15 12-23-2015 07:58 PM
