Notices
JKS Engineering PN 9904 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Body Lifts Next Product
Rating:
Product Information
MSRP: $1,000,000.00
Average Price: $21,850.72
Manufacturer: JKS Engineering
Recommended?
Yes: 60 / No: 1
The B1 Body Lift by JKS offers an economical solution to tire clearance problems, without affecting center of gravity, spring rate or steering geometry like suspension modifications. Unlike universal designs commonly used by our competitors, JKS B1 Body Lifts are specifically designed to work in conjunction with the OE body mounts.
Our B1 Body Lifts actually provide 1.25" of additional tire clearance, as opposed to the standard 1" provided by other manufacturers. The Jeep® specialists at JKS have found this to provide the ideal amount of tire clearance without exceeding the safe working parameters for severe off-road use. Furthermore, no modifications are required to the fuel tank, air conditioning, radiator, or brakes, unlike taller body and suspension lifts.
Manufactured from premium Dura-Thane™ poly material with a hardness of 94 durometer, JKS B1 Body Lifts are designed to easily exceed the demands of four wheeling.
None
Page 3 of 4 1 2 3 4 > Last »
Mista Toad
Mista Toad's Reviews
04-12-2008, 03:09 PM
Price: $145.00
Recommended? Yes
Comments: Great cheap way to clear 33's w/ only a BB. I will keep these when I move up to a LA.
Islidur
Islidur's Reviews
04-07-2008, 01:51 AM
Price: $130.00
Recommended? Yes
Comments: Just what I needed to fit the 35s
cowpie
cowpie's Reviews
04-03-2008, 09:52 PM
Pros: easy to install/good instruction/good quality
Recommended? Yes
Comments: I dabbed a bit of motoroil from an empty oil bottle in the garage and grabbed them wiyh a 18'' pair of channel locks and the radiator bumps snapped right in!!!
RubiCrawler_LJ
RubiCrawler_LJ's Reviews
03-17-2008, 10:45 AM
Price: $124.99
Recommended? Yes
Comments: Works as advertised.
GringoLoco
GringoLoco's Reviews
03-16-2008, 11:36 AM
Price: $125.00
Recommended? Yes
Comments: Good quality.
turbovelocity
turbovelocity's Reviews
03-13-2008, 09:04 AM
Pros: Easy install , extra .25 over the others , nice quality kit
Cons: None !
Recommended? Yes
Comments: I installed this kit along with their 1" motor mounts and everything lined up perfect !
distortedtj
distortedtj's Reviews
03-12-2008, 12:55 AM
Price: $125.00
Recommended? Yes
Comments: great bodylift. came with everything needed.
pinkeye
pinkeye's Reviews
02-24-2008, 10:37 AM
Pros: like how they fit over OEM mount-easy install
Cons: Grill support are a PITA, took as long as whole lift to install!
Recommended? Yes
Comments: Installed w/JKS MML--instructions said I did not need TC linkage bracket, but they were wrong. Could not get into 4Lo. Ended up with AA linkage bracket to divorce TC from body alltogether.
boriqua97
boriqua97's Reviews
02-23-2008, 05:58 PM
Price: $90.00
Recommended? Yes
Comments: EASY INSTALL AND CHEAP.
Shag
Shag's Reviews
02-16-2008, 11:12 AM
Price: $123.25
Recommended? Yes
Comments: Easy to install, hard to mess up a body lift.
Kulae
Kulae's Reviews
12-19-2007, 11:28 PM
Price: $120.00
Pros: Easy to install with well written instructions.
Cons: Body bolt torque amounts a little too high.
Recommended? Yes
Comments: Installed with a JKS 1" MML. Very easy install. Recommended torque values a little too much (30-40 ft-lbs). I found 15-20 ft-lbs is best to keep the dreaded pop/clunk/rattle out of the picture.
02tjsport
02tjsport's Reviews
10-21-2007, 09:20 PM
Pros: Easy to install, Great instructions
Cons: None
Recommended? Yes
Comments: Installed in conjunction with a 1" MML. Went on easily. Did not run into any problem. Installed in about an hour and some change. The use of an impact gun helps alot. I loosened all bolts by hand then ran them off with a gun. Went very smooth.
06flex
06flex's Reviews
10-08-2007, 08:26 PM
Pros: easy install, clearance for a belly up
Cons: gap between body and frame..but a needed gap
Recommended? Yes
Comments: Install went really easy untill the grill supports those where a pain. I ended up taking the whole head light out to get them in but other than that it was pretty easy to install....about hour
Lostj
Lostj's Reviews
09-30-2007, 01:07 AM
Price: $123.00
Pros: Good price
Recommended? Yes
Comments: I bought mine from www.northridge4x4.com
The install was easy and it's a great way to go 1" higher
FarFire70
FarFire70's Reviews
09-24-2007, 09:01 PM
Pros: 1.25" lift instead of the typical 1"
Cons: None
Recommended? Yes
Comments: Very easy install. As everyone else says, the radiator bump stops are a pain but freezing them before install helps as well as taking the headlight out and pulling with pliers.
SoCoYJ
SoCoYJ's Reviews
09-08-2007, 04:58 PM
Pros: 1.25" and ease of install.
Cons: None.
Recommended? Yes
Comments: I have owned and installed both this kit and the PA 1" kit (on my old YJ) and I prefer this kit. It gives the extra .25" over most others and the parts were great quality. Took less than an hour for the install.
mudmonkey2400
mudmonkey2400's Reviews
04-23-2007, 02:21 PM
Pros: Gets you 1.25" higher at the fenders and rockers.
Cons: None.
Recommended? Yes
Comments: I did a 1" MML when I did mine, so the install for the BL was less than an hour.
Even if you've never turned a wrench before.. this should still be an easy install.
c_gilbert
c_gilbert's Reviews
08-22-2006, 04:52 PM
Pros: Not a lot of parts to mess with. Pretty basic install.
Recommended? Yes
Comments: Great product...gives the perfect amount of lift without the hassle of messing with brake lines, fuel filler and so on. It really helped to hear what other people had to say about the install. The directions are fair, but the input that everyone on this site gives is EXTREMLEY helpful.
Ichabod1960
Have Jeep, Will Travel
Ichabod1960's Reviews
08-11-2006, 12:21 AM
Pros: Easily installed, Good instructions.
Cons: None.
Recommended? Yes
Comments: Very happy with the JKS Body Lift. The Radiator Bump stops are a pain to install. Liquid soap helps. Also the body mounts nearest the rear tires are much more easily accessed with the rear tires removed from the axle.
ChristopherJ
Resident Physician
ChristopherJ's Reviews
08-03-2006, 04:40 PM
Price: $85.00
Pros: Raises the body by 1.25", just as advertised.
Cons: none
Recommended? Yes
Comments: This is a great body lift. I have no comparison to others, but it has done exactly what I wanted. The only part I had trouble with on install was that I did not notice the differing lengths of bolts. I had the wrong length bolts in some of the holes and had to uninstall them. No trouble at all.
The quality of the components was excellent and I have no question of the safety of these parts.
ThreadForumRepliesLast Post
M.O.R.E (Mountain Off Road Engineering) Lift for TJ's: BLTJ97 Body Lifts 14 12-29-2012 11:36 PM
