JKS Engineering PN 9904 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Body Lifts Next Product
Rating:
Product Information
MSRP: $1,000,000.00
Average Price: $21,850.72
Manufacturer: JKS Engineering
Recommended?
Yes: 60 / No: 1
The B1 Body Lift by JKS offers an economical solution to tire clearance problems, without affecting center of gravity, spring rate or steering geometry like suspension modifications. Unlike universal designs commonly used by our competitors, JKS B1 Body Lifts are specifically designed to work in conjunction with the OE body mounts.
Our B1 Body Lifts actually provide 1.25" of additional tire clearance, as opposed to the standard 1" provided by other manufacturers. The Jeep® specialists at JKS have found this to provide the ideal amount of tire clearance without exceeding the safe working parameters for severe off-road use. Furthermore, no modifications are required to the fuel tank, air conditioning, radiator, or brakes, unlike taller body and suspension lifts.
Manufactured from premium Dura-Thane™ poly material with a hardness of 94 durometer, JKS B1 Body Lifts are designed to easily exceed the demands of four wheeling.
None
Page 2 of 4 1 2 3 4 > Last »
kevincctx
kevincctx's Reviews
08-07-2008, 11:36 PM
Price: $125.00
Recommended? Yes
Comments: Easy to install, instructions werent too bad. installed myself in less that 2hrs
Unlimited04
This post/info=my opinion
Unlimited04's Reviews
07-01-2008, 11:50 PM
Recommended? Yes
Comments: Great product so far. Paid for the install, so no comments on that. Works great with 1" MML.
sherp89
sherp89's Reviews
06-29-2008, 09:37 AM
Recommended? Yes
Comments: Finished yesterday, easy install way too early to review, but so far GREAT... need to put on the T-case shifter bracket to be able to get it back in 4-lo... All the parts seem to be of high quality and went in painlessly used in conjunction with a 1" MML
jdarg
jdarg's Reviews
06-27-2008, 05:21 PM
Price: $100.00
Recommended? No
Comments: I think this kit is marginal. Lack of compensation for steering has ruined my bearing in the middle of the shaft. By the time you get the mounts torqued back down properly it isn't 1.25". Bolts rusting after two WI winters...but none of the other stock bolts underneath are. Go M.O.R.E. if you need a BL.
Godholio
Godholio's Reviews
06-07-2008, 02:44 PM
Price: $1,000,000.00
Recommended? Yes
Comments: Piece of cake to install. Some of the bolts were a little too long (in particular the one for the front (under grille) mount, and the mounts under the bed/backseat. Trim them down a bit with a dremel or grinder, otherwise I had no issues at all. Over a year with no problems.
njsjeep
njsjeep's Reviews
06-03-2008, 08:55 PM
Recommended? Yes
Comments: I added the 1.25" JKS body lift in order to add a belly up and heavier gas tank skid pan.
VZEHLER
VZEHLER's Reviews
06-03-2008, 05:46 PM
Price: $120.00
Recommended? Yes
Comments: Love it. Easy Install in about an hour. Use some good lube and a pry bar to make quick work of the snubbers. Must have for most tummy tucks.
thedirt
thedirt's Reviews
05-23-2008, 03:30 AM
Price: $110.00
Recommended? Yes
Comments: Good, well thought out body lift. Gives you 1/4" more than other body lifts also, which is a plus.
BM20
BM20's Reviews
05-18-2008, 08:16 PM
Price: $123.00
Recommended? Yes
Comments: Easy install, did it myself in about 3 hours. Gains 1.25" without looking terrible.
Panici
(O|||||||O)
Panici's Reviews
05-15-2008, 07:03 PM
Recommended? Yes
Comments: Installed the JKS 1.25" BL on my TJ today.
Like everyone said, the rad supports were a pain to get in. The whole install went pretty easy.
I'll be installing a 1" MORE Bombproof MML tomorrow, so I can't comment on the T-case bracket that came with the BL, since hopefully I won't have to use it.
slate210
slate210's Reviews
05-05-2008, 02:56 PM
Price: $110.00
Recommended? Yes
Comments: Time will tell about longevity, but right now....woooohoooo! Installation was easy and relatively quick. JKS ROCKS!
CoRubicon
CoRubicon's Reviews
05-03-2008, 02:36 PM
Price: $120.00
Recommended? Yes
Comments: 1.25" Body lift. Just enough lift for a tummy tuck and high clearance gas tank skid. Looks good, not goofy.
distantdog
distantdog's Reviews
05-01-2008, 01:56 PM
Price: $100.00
Recommended? Yes
Comments: 1.25" BL. love it! i hate that you have to write reviews of 75 char. its stupid.
bman9089
bman9089's Reviews
04-29-2008, 03:35 AM
Price: $125.00
Recommended? Yes
Comments: Great kit. Easy to install. Good quality parts and the included grill bumpstops are a plus that not many other kits offer.
asa
asa's Reviews
04-23-2008, 08:24 PM
Price: $145.00
Recommended? Yes
Comments: easy to install and cheap
ElConq
ElConq's Reviews
04-23-2008, 12:04 PM
Price: $85.00
Recommended? Yes
Hrothgar
Hrothgar's Reviews
04-22-2008, 02:32 PM
Price: $120.00
Recommended? Yes
Comments: good product. easy install. no issues with install
stangman68inftc
stangman68inftc's Reviews
04-19-2008, 10:02 PM
Price: $50.00
Recommended? Yes
Comments: Hopefully the part number is right, this is a 1.25 inch body lift. Easy to install, doesn't look ugly.
Trombino
Trombino's Reviews
04-19-2008, 01:10 PM
Price: $125.00
Recommended? Yes
Comments: Very please with this product. No problems with the install and the supplied bracket helped out with T-Case linkage binding after the install.
silverjeep
silverjeep's Reviews
04-14-2008, 06:38 PM
Price: $150.00
Recommended? Yes
Comments: Good so far. No complaints. The instructions did not match my TJ when it came to the fan removal. I had to improvise.
ThreadForumRepliesLast Post
M.O.R.E (Mountain Off Road Engineering) Lift for TJ's: BLTJ97 Body Lifts 15 12-23-2015 07:58 PM
