Go Back JeepForum.com > Reviews > Body > Body Lifts > JKS Engineering PN 9904
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
JKS Engineering PN 9904 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Body Lifts Next Product
Rating:
Product Information
MSRP: $1,000,000.00
Average Price: $22,333.62
Manufacturer: JKS Engineering
Recommended?
Yes: 59 / No: 1
The B1 Body Lift by JKS offers an economical solution to tire clearance problems, without affecting center of gravity, spring rate or steering geometry like suspension modifications. Unlike universal designs commonly used by our competitors, JKS B1 Body Lifts are specifically designed to work in conjunction with the OE body mounts.
Our B1 Body Lifts actually provide 1.25" of additional tire clearance, as opposed to the standard 1" provided by other manufacturers. The Jeep® specialists at JKS have found this to provide the ideal amount of tire clearance without exceeding the safe working parameters for severe off-road use. Furthermore, no modifications are required to the fuel tank, air conditioning, radiator, or brakes, unlike taller body and suspension lifts.
Manufactured from premium Dura-Thane™ poly material with a hardness of 94 durometer, JKS B1 Body Lifts are designed to easily exceed the demands of four wheeling.
Page 1 of 3 1 2 3 > Last »
Mayfair_Jeeper
Jack *** of All Trades
Mayfair_Jeeper's Reviews
04-01-2009, 02:05 PM
Price: $90.00
Recommended? Yes
Comments: A+ product. Not much else to say. Easy to install came with all necessary parts
mrosseker
mrosseker's Reviews
03-29-2009, 04:38 PM
Price: $160.00
Recommended? Yes
Comments: Great install, high quality parts. I decided to go with the option that is the most popular, and I can see why. The only issue that I had was the fuel filler lines, but loosening all of the clamps and some massaging made it all work out without extra parts or surgery. Check out the "Rokmen" video on YouTube for a great walkthrough.
JohnyPro
JohnyPro's Reviews
03-22-2009, 09:56 PM
Price: $126.00
Recommended? Yes
Comments: So far so good! Make sure you realize that the screw brackets over the rear shocks are floating, use a thin rod to center them over the hole before trying to screw in new bolt.
Scurvy
Scurvy's Reviews
03-16-2009, 03:52 PM
Price: $129.00
Recommended? Yes
Comments: Installed along with a JKS budget MML. Watch your fan as you lift the body to install pucks (directions say not to loosen shroud if you are also installing MML). Easy install.
jrb470
jrb470's Reviews
02-25-2009, 09:04 PM
Price: $110.00
Recommended? Yes
Comments: Fairly Easy Install. Had to install te TC shifter relocation bracket even though I also installed the 1' BMML.
spittindurt
spittindurt's Reviews
02-17-2009, 12:49 PM
Price: $1.00
Recommended? Yes
Comments: Great body lift, easy instal. Did exactly what I needed it to do. Not to big not to small. Allowed me to start off running 33X10.50 boggers with only a 2'' BB and I had full flex with no rubbing.
jamesmp319
jamesmp319's Reviews
02-14-2009, 01:46 PM
Price: $180.00
Recommended? Yes
Comments: great body lift took me an hour to install at work. I am tech so i have a lift whenever i want it. also have the jks 1inch motor mount lift
RJV
RJV's Reviews
02-10-2009, 09:19 PM
Price: $100.00
Recommended? Yes
Comments: easiest body lift I have done, but thats because it was a small lift and a jeep kit
mtr5360
mtr5360's Reviews
01-18-2009, 01:19 AM
Price: $124.99
Recommended? Yes
Comments: Great product. Does the extra .25" matter? Who knows, but the company has a great rep and excellent quality cotrol.
850GLT
850GLT's Reviews
12-23-2008, 07:43 AM
Price: $125.00
Recommended? Yes
Comments: Easy install, high quality pucks! The hardest part was adjusting the fan shroud (and it wasn't that bad).
alvinl
alvinl's Reviews
12-13-2008, 08:36 PM
Price: $80.00
Recommended? Yes
Comments: Great product. The install is straight forward and fairly simple.
HowIRoll
HowIRoll's Reviews
12-09-2008, 10:59 PM
Price: $125.00
Recommended? Yes
Comments: Works as advertised. Installation was a breeze with no problems at all. Had it on for 6 months now with no problems.
erickpl
erickpl's Reviews
11-24-2008, 11:24 AM
Price: $100.00
Recommended? Yes
Comments: Why do I need 75 characters to provide a review? I Just want to list em. Adding characters to shut this thing up.
TJTRUBL2006
TJTRUBL2006's Reviews
11-06-2008, 10:17 AM
Recommended? Yes
Comments: Great Body lift easy to install no issues at all. I would recomment this lift with out a doubt...
ForestGreen
ForestGreen's Reviews
10-24-2008, 09:03 AM
Price: $124.75
Recommended? Yes
Comments: Great product, easy installation. I just needed a little lift and this was the perfect solution.
TJRubicon06
TJRubicon06's Reviews
10-17-2008, 07:06 PM
Price: $125.00
Recommended? Yes
Comments: What can you really say about a body lift? It was easy to install, no issues with the rubber snubbers, i just took the headlights out and ran a piece if twine down, through the snubber and back up. 1 quick tug and they were in place.
BlackBellamy
BlackBellamy's Reviews
09-30-2008, 09:47 AM
Price: $50.00
Recommended? Yes
Comments: Got this lift only because of the extra quarter inch. Otherwise all body lifts are pretty much the same.
NMLJ
NMLJ's Reviews
09-20-2008, 08:35 AM
Price: $150.00
Recommended? Yes
Comments: Easy upgrade that gives you just a tad more room and opens your choices up for future mods like belly up and gas tank skid.
0utback
0utback's Reviews
08-12-2008, 09:58 PM
Price: $124.00
Recommended? Yes
Comments: Easy install, effective product. Be careful with the grille snubbers though. The mounting nipple can tear easy if being pulled into place rather than shoved. It's a frustrating procedure with many possible ways to insert. Best advice - be patient, very patient.
kevincctx
kevincctx's Reviews
08-07-2008, 10:36 PM
Price: $125.00
Recommended? Yes
Comments: Easy to install, instructions werent too bad. installed myself in less that 2hrs
ThreadForumRepliesLast Post
M.O.R.E (Mountain Off Road Engineering) Lift for TJ's: BLTJ97 Body Lifts 11 02-18-2010 10:19 AM
Glock Forum
