JKS 1.25" Body Lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts Next Product
JKS 1.25" Body Lift
Rating:
Product Information
MSRP: $150.00
Average Price: $105.39
Manufacturer: JKS
Recommended?
Yes: 112 / No: 1
The B1 Body Lift by JKS offers an economical solution to tire clearance problems, without affecting center of gravity, spring rate or steering geometry like suspension modifications. Unlike universal designs commonly used by our competitors, JKS B1 Body Lifts are specifically designed to work in conjunction with the OE body mounts.
Our B1 Body Lifts actually provide 1.25" of additional tire clearance, as opposed to the standard 1" provided by other manufacturers. The Jeep® specialists at JKS have found this to provide the ideal amount of tire clearance without exceeding the safe working parameters for severe off-road use. Furthermore, no modifications are required to the fuel tank, air conditioning, radiator, or brakes, unlike taller body and suspension lifts.
Manufactured from premium Dura-Thane™ poly material with a hardness of 94 durometer, JKS B1 Body Lifts are designed to easily exceed the demands of four wheeling.
None
Page 5 of 6 1 2 3 4 5 6 > Last »
Kris B Krunch
Kris B Krunch's Reviews
12-20-2009, 06:28 AM
Price: $135.00
Pros: easy install (if you don't break the head off any of the stock bolts)
Cons: None
Recommended? Yes
Comments: great product. Install is really easy, unless you're like me and broke one of the stock heads off during removal.
zanash2
zanash2's Reviews
12-19-2009, 09:08 AM
Price: $115.00
Pros: height
Cons: stick shift issues
Recommended? Yes
Comments: This lifts the body but causes other issues.
UCTJ
UCTJ's Reviews
11-29-2009, 04:48 PM
Price: $150.00
Pros: Its JKS!
Cons: Nope
Recommended? Yes
Comments: I have JKS BL and MML awesome stuff.
UCTJ
UCTJ's Reviews
Price: $150.00
Pros: Its JKS!
Cons: None
Recommended? Yes
Comments: I have JKS BL and MML again great product. Super strong.
Mayfair_Jeeper
Mayfair_Jeeper's Reviews
11-26-2009, 11:11 AM
Price: $75.00
Pros: Easy Install
Cons: None
Recommended? Yes
Comments: Great and easy way to get extra lift on a LCG build.
JVRuby
JVRuby's Reviews
11-18-2009, 12:31 PM
Price: $125.00
Pros: Easy Install
Cons: None
Recommended? Yes
Comments: Installation of body lift took about an hour, installation of final bolt (of four) for Motor Mount lift took about three hours! Although it proved to be a difficult installation, I consider the Motor Mount lift to be necessary. No modifications need to be made to the fan shroud or transfer case bracket.
Air tools were a big help, especially the low profile air ratchet wrench.
A big block of wood (6"x6") and floor jack were also helpful in the install. Front snubbers were simple using the weed wacker string through the headlight cavity and a bit of WD40.
Post install, the Jeep was noticibly smoother over minor bumps.
JVRuby
JVRuby's Reviews
11-18-2009, 12:30 PM
Price: $125.00
Pros: Easy Install
Cons: None
Recommended? Yes
jmcgonig
jmcgonig's Reviews
10-29-2009, 06:34 PM
Price: $100.00
Pros: Simple
Cons: Rather have 1 component than slip unders
Recommended? Yes
Comments: Here we go with a review again, not sure why I need to fill this in to do my profile.
Disco69
Disco69's Reviews
10-24-2009, 07:14 PM
Price: $140.00
Pros: Easy to install, great instructions, quality
Cons: None
Recommended? Yes
Comments: Simple and it added that extra clearance I needed.
acrijos
acrijos's Reviews
10-04-2009, 08:24 PM
Price: $120.00
Pros: Easy installation, best when installing JKS MML, low costo
Cons: None
Recommended? Yes
Comments: Easy installation, best when installing JKS MML. Good value for money
rockymntedition
rockymntedition's Reviews
09-30-2009, 03:55 PM
Price: $150.00
Pros: Mostly easy to install
Cons: radiator bump stops suck to put in
Recommended? Yes
Comments: I need a little more gap between the fender and the tire it di the job
drozd_ws6
drozd_ws6's Reviews
09-29-2009, 11:59 PM
Price: $120.00
Pros: clearance for tummy tucker
Cons: a little ugly
Recommended? Yes
Comments: no issues
backgroundnoise
backgroundnoise's Reviews
09-26-2009, 10:46 PM
Price: $130.00
Pros: Gives just a little more lift.
Cons: none yet
Recommended? Yes
Comments: I installed this to give myself a little extra room for a future tt. I also broke a motor mount and wanted a MML so I could take out my T-case drop. Install took about 30 min by myself.
Radar_Sweden
Radar_Sweden's Reviews
08-27-2009, 03:27 PM
Price: $122.00
Pros: Easy installation.
Cons: None
Recommended? Yes
Comments: To early to say anything about the product.
Donkeyboy28
Donkeyboy28's Reviews
08-13-2009, 12:00 PM
Price: $60.00
Pros: went on super easy
Cons: looks kindof funky like anu other body lift
Recommended? Yes
Comments: The lift was very easy to install. There is a video on youtube that walks you through the entire process. I did it by myself in like 45 minutes.
Mystifire
Mystifire's Reviews
07-31-2009, 07:33 PM
Price: $115.00
Pros: Quick and easy clearance
Cons: T-case linkage binding
Recommended? Yes
Comments: The instructions say that no t-case drop bracket is needed when installed with a 1" MML. My linkage was binding and couldn't get it into 4-Lo. I installed the drop bracket so that the linkage was in the middle hole. Still binding and I can get it into 4-Lo, but it pops out as soon as I move. I have an Advance Adapters bracket coming to mount it to my transmission, hopefully that'll fix it.
jhunt87
jhunt87's Reviews
07-22-2009, 03:33 PM
Price: $120.00
Pros: Combined with BB can Clear 33's
Cons: None really
Recommended? Yes
Comments: I got this kit and a 2.25" budget boost for 3.5" overall. Let my tj clear my 33's.
dumped
dumped's Reviews
04-05-2009, 01:19 PM
JKS 1.25" Body Lift
Price: $100.00
Recommended? Yes
Comments: Very straightforward install. Helps my 2.5" suspension to clear 33x12.50s. Not too much body/frame gap.
JBarton
JBarton's Reviews
04-05-2009, 01:26 AM
JKS 1.25" Body Lift
Price: $90.00
Recommended? Yes
Comments: Gave enough clearance for the 33s. cant really complain any other way its too new for a full review.
attackcammel
attackcammel's Reviews
03-11-2009, 09:31 PM
JKS 1.25" Body Lift
Price: $100.00
Recommended? Yes
Comments: does what ist supposed to do only problem was getting the grill bumpers in thats about it........................
ThreadForumRepliesLast Post
Performance Accessories 3 inch body lift3 inch body lift Body Lifts 23 06-05-2016 03:55 AM
Rough Country 1.25" body lift for JK Body Lifts 17 05-11-2015 07:44 PM
Prothane 87-95 YJ 1`` Body Lift Body Lifts 8 06-08-2014 06:35 PM
Black Mountain 2" Body Lift Body Lifts 10 10-28-2013 11:00 AM
Prothane 76-79 CJ7 1" body lift Body Lifts 3 06-10-2011 05:58 PM
