JKS 1.25" Body Lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts Next Product
JKS 1.25" Body Lift
Rating:
Product Information
MSRP: $150.00
Average Price: $105.39
Manufacturer: JKS
Recommended?
Yes: 112 / No: 1
The B1 Body Lift by JKS offers an economical solution to tire clearance problems, without affecting center of gravity, spring rate or steering geometry like suspension modifications. Unlike universal designs commonly used by our competitors, JKS B1 Body Lifts are specifically designed to work in conjunction with the OE body mounts.
Our B1 Body Lifts actually provide 1.25" of additional tire clearance, as opposed to the standard 1" provided by other manufacturers. The Jeep® specialists at JKS have found this to provide the ideal amount of tire clearance without exceeding the safe working parameters for severe off-road use. Furthermore, no modifications are required to the fuel tank, air conditioning, radiator, or brakes, unlike taller body and suspension lifts.
Manufactured from premium Dura-Thane™ poly material with a hardness of 94 durometer, JKS B1 Body Lifts are designed to easily exceed the demands of four wheeling.
None
Page 4 of 6 1 2 3 4 5 6 > Last »
Jdiz
Jdiz's Reviews
07-17-2010, 05:37 PM
Price: $120.00
Pros: Easy install, Fair price.
Cons: None.
Recommended? Yes
Comments: Good price and easy install. Did 1'' MML at the same time.
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Reviews
07-11-2010, 03:42 PM
Price: $100.00
Pros: easy install, everything you need.
Cons: none
Recommended? Yes
Comments: Great body lift at a reasonable price. Easy install. I suggest doing this in conjunction with a MML.
NYGLT56
Your Local Body Builder
NYGLT56's Reviews
06-10-2010, 03:32 AM
Price: $0.01
Pros: easy intsall
Cons: none
Recommended? Yes
Comments: best 0 dollars spent, this actually is the RC lift and it came with my 3.25 kit thanks to jeff
jpin321
jpin321's Reviews
05-24-2010, 07:34 PM
Price: $149.50
Pros: Decently easy to install. Quality pucks. Fixed my drive-line vibrations from 2" BB.
Cons: Some problems with the install.
Recommended? Yes
Comments: Easy install in conjunction with the motor mount lift kit.
Problems I had was the gas tank filler tube. It was far from log enough but was corrected with a quick adjustment of the hose. The radiator bump stops went in easier for me than most people. Some WD-40 on the tips and a 2' pry bar on the sway bar and they popped right in. My shifter hit the console after the lift as well. But I corrected this by moving the console back about an inch. Also the vent tube for the rear end ended up getting worn into from being pulled tight from the lift. But 3" fuel line 2 barbs and 4 hose clamps and all is well again.
My biggest complaint is that the instructions say that with the MML that the t-case linkage drop bracket wouldn't have to be used but after the install my linkage was all bound up and when i drove down the road it made a popping sound. So installed the drop bracket and fixed it all. Your t-case shifter will also have to be adjusted before it will work correctly.
All in all awesome product as usual from JKS. Just wish they had told me about the problems I would face and possible solutions prior to the install.
I tried calling their tech support but could never get them on the phone and they never returned my voice mails.
IH8PEPL
IH8PEPL's Reviews
05-12-2010, 08:23 PM
Price: $125.00
Pros: Good quality, Improves looks and clearance
Cons: A bitch to install without a Motor Mount Lift!!!!! <--- Seriously get one!!!!!!!!!!!!
Recommended? Yes
Comments: My jeep alread had a 3.5 Inch lift but I decided I wanted a little more. I went with JKS because I have installed a few of their products and liked the quality.
Pros; The Pucks go in nice and smooth, no issues getting them on.
Cons; The Radiator bumpers are an absolute nightmare, at least they were for me. I spent 4 hours trying to get them to fit into the stock holes, pulling on them with vice grips, twisting, turning and forcing them to go in place. I ended up taking a dremel and cutting away some material to get them to go in and stay in. They arent as "squishy" as the original rubber but still maintain the same measurments making them seemingy impossible to get installed.
If you didnt get the motor mount kit - SAVE YOURSELF A LOT OF TIME AND GET IT!!!! IM BEGGING YOU!I decided not to, what a mistake! I spent another few hours dicking around with the fan shroud and transfer case shifting bracket. Only to find its not shifting properly... which will need adjusting.
Overall : If you get the MML in conjunction with the body lift you will be fine. The 1.25 inches really dramatically changed the look of the Jeep. Now my jeep looks nice and aggressive, best of all, I dont have to worry about tearing my fender flares off - I have plenty of room to flex.
heapashifter
heapashifter's Reviews
04-28-2010, 08:31 PM
Price: $121.50
Pros: Increased lift, Looks good, easy install
Cons: none
Recommended? Yes
Comments: Quality product. Came with good directions. Only took about an hour to install by myself with all the proper tools. I see no downside to it.
robert_hollis
robert_hollis's Reviews
04-13-2010, 01:33 AM
Price: $125.00
Pros: relatively quick and easy to install.
Cons: Installed at same time as JKS 1" MML, and still had t-case linkage issues. Had to shim entire transmission and t-case to fix issue. Doesn't use grade 8 bolts.
Recommended? Yes
Comments: These seem pretty good, so far.
Installed at same time as JKS 1" MML, and still had t-case linkage issues. Had to shim entire transmission and t-case to fix issue. That was mildly annoying. I also wish the kit came with grade 8 bolts, and used the same size head for ALL of the bolts like the factory bolts do.
JDePietro
JDePietro's Reviews
03-29-2010, 07:54 PM
Price: $125.00
Pros: Cupped pucks mount securely onto the existing body mounts. Bolts are thick stainless, high quality poly.
Cons: Instructions are a bit lacking.
Recommended? Yes
Comments: Couldn't be happier. All the hardware and pucks are of high quality, the pucks actually cup the mounts so it makes for an easier install. I had gotten these as a gift, I wanted the currie lift but I am glad I got theses instead.
iceman123187
iceman123187's Reviews
03-06-2010, 02:29 PM
Price: $120.00
Pros: great look
Cons: none
Recommended? Yes
Comments: Gives it that extra lift for cheep
Filthy-Beast
Filthy-Beast's Reviews
03-03-2010, 04:28 PM
Price: $115.00
Pros: good quality, everything needed is included.
Cons: none
Recommended? Yes
Comments: This made doing my TT so much easier. I got it from Rokmen and their install video has time saving tips.
MaulCrawler
MaulCrawler's Reviews
02-12-2010, 06:36 PM
Price: $120.00
Pros: lifts the body?
Cons: ugly gap
Recommended? Yes
Comments: It does what its supposed to do.....lift the body.Got my moneys worth
NOBLACKTOP
NOBLACKTOP's Reviews
01-21-2010, 11:07 PM
Price: $100.00
Pros: Easy Install
Cons: None
Recommended? Yes
Comments: REMOVE HEADLIGHT TO INSTALL SNUBBERS. THIS IS NOT IN THE INSTRUCTIONS.
NOBLACKTOP
01-21-2010, 11:04 PM
Price: $100.00
Pros: Easy install
Cons: Snubbers
Recommended? Yes
Comments: Easy install. REMOVE HEADLIGHTS FOR THE SNUBBERS.......................................... .................................................
CsKWarEd
CsKWarEd's Reviews
01-20-2010, 04:03 PM
Price: $99.99
Pros: Easy to install
Cons: None
Recommended? Yes
Comments: Really easy to install, seems to be a great product. Holding up just fine thus far.
bobdog
bobdog's Reviews
01-18-2010, 04:56 PM
Price: $99.00
Pros: easy install
Cons: smallish pucks, could be larger round;
Recommended? Yes
Comments: Actually it is an RC BL. The instructions should discuss the need to adjust the fuel filler neck. Other than that it was straight forward.
jeeptj333
jeeptj333's Reviews
01-16-2010, 06:59 PM
Price: $99.00
Pros: came with my rough country 2.5 coils
Cons: none yet
Recommended? Yes
Comments: works great with my coils couldnt be happier with it and easy to install
ritjobbie
ritjobbie's Reviews
01-09-2010, 11:53 PM
Price: $100.00
Pros: Cheap, easy, durable.
Cons: Body mount bolts can be a PITA to remove.
Recommended? Yes
Comments: The pucks in this body lift are contoured to fit exactly over the existing rubber mounts. The kit comes with grade 5 bolts which is probably waaay more than plenty strong enough, but I replaced mine with grade 8. I love Fastenal.
There isn't much else you can say about a BL. It's a bunch of spacers and some bolts. This one gives you 1/4" more lift than most. Installation depends on the condition of your Jeep.
Mayfair_Jeeper
Mayfair_Jeeper's Reviews
01-06-2010, 11:23 PM
Price: $25.00
Pros: Ebay rocks. Easy install gives lots of room for other mods
Cons: None
Recommended? Yes
Comments: Easy to isntall.
hawkguy
hawkguy's Reviews
12-22-2009, 04:34 PM
Price: $125.00
Pros: great workmanship
Cons: can't really think of any
Recommended? Yes
Comments: My only complaint is that I had a bear of a time getting the BL spacer on the body mount under the radiator to match up. Might have just been me, but I love the way the spacers conform to the OE body spacers.
ibkushman320
ibkushman320's Reviews
12-20-2009, 09:50 PM
Price: $120.00
Pros: solid hardware easy to install
Cons: none that i can think of
Recommended? Yes
Comments: product is straightforward and easy to install, took me about an hour, hour and a half. biggest pain was having to move the fan shroud.
ThreadForumRepliesLast Post
Performance Accessories 3 inch body lift3 inch body lift Body Lifts 23 06-05-2016 03:55 AM
Rough Country 1.25" body lift for JK Body Lifts 17 05-11-2015 07:44 PM
Prothane 87-95 YJ 1`` Body Lift Body Lifts 8 06-08-2014 06:35 PM
Black Mountain 2" Body Lift Body Lifts 10 10-28-2013 11:00 AM
Prothane 76-79 CJ7 1" body lift Body Lifts 3 06-10-2011 05:58 PM
