Notices
JKS 1.25" Body Lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts Next Product
JKS 1.25" Body Lift
Rating:
Product Information
MSRP: $150.00
Average Price: $105.39
Manufacturer: JKS
Recommended?
Yes: 112 / No: 1
The B1 Body Lift by JKS offers an economical solution to tire clearance problems, without affecting center of gravity, spring rate or steering geometry like suspension modifications. Unlike universal designs commonly used by our competitors, JKS B1 Body Lifts are specifically designed to work in conjunction with the OE body mounts.
Our B1 Body Lifts actually provide 1.25" of additional tire clearance, as opposed to the standard 1" provided by other manufacturers. The Jeep® specialists at JKS have found this to provide the ideal amount of tire clearance without exceeding the safe working parameters for severe off-road use. Furthermore, no modifications are required to the fuel tank, air conditioning, radiator, or brakes, unlike taller body and suspension lifts.
Manufactured from premium Dura-Thane™ poly material with a hardness of 94 durometer, JKS B1 Body Lifts are designed to easily exceed the demands of four wheeling.
None
Page 3 of 6 1 2 3 4 5 6 > Last »
Idwheelthat
Idwheelthat's Reviews
09-04-2011, 01:55 PM
Price: $165.00
Pros: lifts jeep, insulates against harsh vibration
Cons: instructions lacking clarity, quality bolts not included
Recommended? Yes
Comments: install was kinda straightforward, was not easy jacking up jeep body for clearance to install pucks. When you realize the body mount nutserts are floating in the body, you will have stripped a bolt. you must line up the nutsert with a screwdriver and carefully install bolt. factory bolts have a unthreaded nose to do this alignment with and they are nitrided so they don't rust. I went around and coated all bolts with undercoating in case I ever have to service mounts.
Fuzzcheek1
Fuzzcheek1's Reviews
08-14-2011, 03:00 PM
Price: $120.00
Pros: Easy to install. Comes with all the hardware.
Cons: None yet.
Recommended? Yes
Comments: Product comes with all the necessary hardware and instructions.
Siegreicher
Siegreicher's Reviews
08-09-2011, 10:54 PM
Price: $150.00
Pros: Little bit of clearance
Cons: Be prepared to deal with broken body bolts
Recommended? Yes
Comments: What you'd expect from a body lift. Would not recommend if you live in the rust belt and have an older jeep, unless you are more than prepared cutting up your tub, in which case have at!
Coop02x
Coop02x's Reviews
07-20-2011, 02:25 AM
Price: $1.00
Pros: None
Cons: None
Recommended? Yes
Comments: I got it as a part of a package deal so there is no definitive price that I paid for it.
It's your typical body lift for the most part! You really can't stray too far from the norm. Accomplished what I needed to accomplished by using it! People at JKS were pretty good to deal with!
U-turn
U-turn's Reviews
07-03-2011, 10:46 AM
Price: $100.00
Pros: It works
Cons: NA
Recommended? Yes
Comments: Easy install and it works.
Shiguy
Shiguy's Reviews
06-21-2011, 09:16 AM
Price: $100.00
Pros: East install
Cons:
Recommended? Yes
Comments: Very east install. Can be done in a few hours. Recommend installing MML because it negates the need to relocated the radiator and both jobs can be done over a weekend.
man44a
man44a's Reviews
04-24-2011, 06:42 PM
Price: $100.00
Pros: .
Cons: .
Recommended? Yes
Comments: This was part of my lift kit. Seems to be stable. Does lift the body. No problems with this kit.
robbijer
robbijer's Reviews
03-28-2011, 01:33 PM
Price: $90.00
Pros: quick and easy
Cons: none
Recommended? Yes
Comments: Great quality and instructions from JKS. The main difference I chose this kit is the front grille supports are replaced with longer ones with this kit, others I looked at used spacers which required drilling a hole the frame.
dwish
dwish's Reviews
03-16-2011, 07:27 PM
Price: $120.00
Pros: Raising your ride! Helps with aftermarket skids, increased tire clearance. No squeaks (yet).
Cons: A little more body roll than stock.
Recommended? Yes
Comments: Installation was a breeze. The radiator supports were a little bit of a pain. I took out the headlights to install them, as recommended by Rokmen on their Youtube video. All the pieces fit perfectly, and seemed like they were of good quality. I only really bought this so I could raise my Savvy gas tank skid plate a little higher, but have been impressed overall. Oh yeah, if I do get a tummy tuck, this would be one less thing that needs to be done! Just Empty Every Pocket... :-)
caztj
caztj's Reviews
02-24-2011, 02:25 PM
Price: $125.00
Pros: simple instructions/Rokmen video helped alot
Cons: Not with the product but I had two bolts snap getting the old ones out.
Recommended? Yes
Comments: nice quality and was a good first step at modification of my jeep.
3fifty
3fifty's Reviews
02-23-2011, 10:52 PM
Price: $112.00
Pros: It works
Cons: None
Recommended? Yes
Comments: They do what they are supposed to do.
Dutra177
Dutra177's Reviews
02-12-2011, 11:16 AM
Price: $156.00
Pros: Lifts the body comes with good hardware
Cons: None
Recommended? Yes
Comments: Easy to install, had to do some twinking to get bolt holes to line up.
Weelz
Weelz's Reviews
01-19-2011, 02:54 PM
Price: $125.00
Pros: Relatively easy install.
Cons: Installation instructions didn't warn about the need to disconnect the fuel bezel from the fuel filler tube to preclude the possibility of damaging it during installation of the lift.
Recommended? Yes
Comments: Instructions were pretty good. Install was pretty easy. Luckily, I watched the JKS body lift installation video from Rockmen on Youtube.com, which recommends disconnecting the fuel bezel from the fuel filler tube to preclude damaging them during installation of the body lift. The JKS instructions that came with the body lift didn't include that warning.
TheDirtyGeneral
TheDirtyGeneral's Reviews
01-16-2011, 02:48 PM
Price: $1.00
Pros: Solid Complete Kit
Cons: Wish it would replace stock bushings
Recommended? Yes
Comments: Dont have an exact price came as a part of a combo kit with my SL. Overall, was a very easy to follow install, I used this along with an OME lift to replace the 3" BL on my Jeep, my Jeep now rides like buttttter
dbupp
dbupp's Reviews
01-14-2011, 11:33 PM
Price: $120.00
Pros: it does what it's suppose to
Cons: none
Recommended? Yes
Comments: no problems!
deerassassin22
deerassassin22's Reviews
01-07-2011, 08:09 PM
Price: $1.00
Pros: Great Product Easy to install
Cons: none
Recommended? Yes
Comments: Great product
turbovelocity
turbovelocity's Reviews
12-23-2010, 09:27 PM
Price: $100.00
Pros: easy to install , quality product
Cons: none
Recommended? Yes
Comments: The B1 Body Lift by JKS offers an economical solution to tire clearance problems, without affecting center of gravity, spring rate or steering geometry like suspension modifications. Unlike universal designs commonly used by our competitors, JKS B1 Body Lifts are specifically designed to work in conjunction with the OE body mounts.
Gruneun
Gruneun's Reviews
09-28-2010, 12:32 PM
Price: $121.99
Pros: Easy install, great quality
Cons: Instructions need improvement, lacks fuel filler tube extension
Recommended? Yes
Comments: I highly recommend watching the YouTube videos by Rokmen that go over the install for this lift and the corresponding motor mount lift. For my '98 TJ, the gas tank filler tube is not long enough to reach the filler neck and would have cracked the plastic had I not removed the four screws behind the gas cap and the instructions for the body lift did not address this. Also, the instructions direct you to torque down the replacement bolts before installing the extended bumpers under the grill (making it impossible to get them positioned). Once I had these oversights worked out, the mild body lift was exactly what I wanted. If you're considering this kit, get the motor mount kit, too. You don't have to modify the fan shroud at all and there's no transfer case dropping or adjustments, so it becomes a short, one-evening project.
UncleWilson
UncleWilson's Reviews
08-16-2010, 10:05 AM
Price: $128.25
Cons: None
Recommended? Yes
Comments: Went in smoothly
Fox01V
Fox01V's Reviews
08-08-2010, 03:10 PM
Price: $120.00
Pros: -Adds some more room for flex -Needed for future mods
Cons: none
Recommended? Yes
Comments: This was very easy to install
ThreadForumRepliesLast Post
Rough Country 1.25" body lift for JK Body Lifts 16 05-11-2015 07:44 PM
Performance Accessories 3 inch body lift3 inch body lift Body Lifts 20 02-15-2015 02:16 PM
Black Mountain 2" Body Lift Body Lifts 10 10-28-2013 11:00 AM
Prothane 87-95 YJ 1`` Body Lift Body Lifts 7 08-11-2013 06:58 PM
Prothane 76-79 CJ7 1" body lift Body Lifts 3 06-10-2011 05:58 PM
