Notices
JKS 1.25" Body Lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts Next Product
JKS 1.25" Body Lift
Rating:
Product Information
MSRP: $150.00
Average Price: $105.39
Manufacturer: JKS
Recommended?
Yes: 112 / No: 1
The B1 Body Lift by JKS offers an economical solution to tire clearance problems, without affecting center of gravity, spring rate or steering geometry like suspension modifications. Unlike universal designs commonly used by our competitors, JKS B1 Body Lifts are specifically designed to work in conjunction with the OE body mounts.
Our B1 Body Lifts actually provide 1.25" of additional tire clearance, as opposed to the standard 1" provided by other manufacturers. The Jeep® specialists at JKS have found this to provide the ideal amount of tire clearance without exceeding the safe working parameters for severe off-road use. Furthermore, no modifications are required to the fuel tank, air conditioning, radiator, or brakes, unlike taller body and suspension lifts.
Manufactured from premium Dura-Thane™ poly material with a hardness of 94 durometer, JKS B1 Body Lifts are designed to easily exceed the demands of four wheeling.
None
Page 2 of 6 1 2 3 4 5 6 > Last »
Flyboy161
Flyboy161's Reviews
04-15-2013, 11:25 AM
Price: $148.00
Pros: Easy/ Great Quality
Cons: None
Recommended? Yes
Comments: Super easy install and definitely not too much lift at all! Works perfectly with my Undercover Fab Works Tummy tuck
Cptjeeves
Cptjeeves's Reviews
04-04-2013, 04:34 PM
Price: $100.00
Pros: easy install
Cons: none so far
Recommended? Yes
Comments: no problems with them at all had them installed by a mechanic who is stoked on my jeep visions, did them at the shop cuz it is heated
Matt Graham
Hater of Debt
Matt Graham's Reviews
03-06-2013, 12:35 PM
Price: $73.11
Pros: love it
Cons: none
Recommended? Yes
Comments: Everything was great except I had to drill out two of the spacers on each side to allow for the mounting of my rocker guards. Other than that I am very happy with it.
Found the best deal on Amazon.
olysteve
olysteve's Reviews
02-27-2013, 10:37 PM
Price: $120.00
Pros: Completely painless install
Cons: None
Recommended? Yes
Comments: I ordered this lift from Quadratec after a bit of looking around at different options.
Nicely put together kit all in all.
Install was a complete no brainer. Though I would recommend doing a motor mount lift at the same time.( more on that elsewhere)
FKemp3
FKemp3's Reviews
02-23-2013, 05:40 PM
Price: $121.00
Pros: Easy install
Cons: piggy backs OEM mounts
Recommended? Yes
Comments: Would have prefered full replacement pucks
Empir3x
Empir3x's Reviews
02-21-2013, 06:53 PM
Price: $120.00
Pros: Looks great, excellent price
Cons: slight gearshift modification needed on a 6 speed w mml
Recommended? Yes
Comments: Be prepared when you do the 1.25" bl with the 1" MML on a 6 speed TJ to modify the shifter. It will not go into the even gears or reverse if you do not exaggerate the bends. Ask me if you have questions.
CWgauge
CWgauge's Reviews
02-10-2013, 12:15 AM
Price: $70.00
Pros: Great product,exactly as advertised.
Cons: None
Recommended? Yes
Comments: It gives the Jeep that little extra bit!
Remko
Remko's Reviews
01-04-2013, 01:28 PM
Price: $118.00
Pros: Urethane construction
Cons: None so far
Recommended? No
Comments: I bought this because the 1" currie lift I'd installed years ago the plastic pucks split. I decided on this one due to it being Urethane and it had the extra 1/4" to help clear my flipped t-case. Looks and works good so far. I didn't use the shifter brackets so can't comment on those, as I have cable shifters.
CharlieHo
CharlieHo's Reviews
11-20-2012, 10:38 PM
Price: $135.00
Pros: easy to install
Cons: none
Recommended? Yes
Comments: The hardest part of the install on this product was the rubber bumbers for the grill.
Pierce the tits on the bumpers and run a piece of weed eater string through the hole.
Remove headlight bezel.
Feed the string up into the hole the bumper goes in, and reach down through the headlight and pull the string until the bumper seats
theorvs
theorvs's Reviews
09-09-2012, 02:36 AM
Price: $1.00
Pros: Great easy to put on
Cons: NONE
Recommended? Yes
Comments: JKS Nice Job
EJ018451
EJ018451's Reviews
07-24-2012, 11:56 AM
Price: $1.00
Pros: gets the body up
Cons: ?
Recommended? Yes
Comments: great value added the lift that I needed for my tires works great
IrishDude
IrishDude's Reviews
05-27-2012, 09:21 AM
Price: $1.00
Pros: works
Cons: none
Recommended? Yes
Comments: easy install, came with kit from dirk
dezertdirt
dezertdirt's Reviews
04-23-2012, 10:14 PM
Price: $100.00
Pros: Nicely made product than installs as directed.
Cons: None
Recommended? Yes
Comments: This BL installed exactly as directions state. I wish the directions would have told me about the fuel filler tube and it's bezel. I had to move the fuel filler hose at the gas tank to accommodate the spacing change, which I didn't expect. However all said and done, pretty easy to install and a well made product.
ColdWeatherTJ
ColdWeatherTJ's Reviews
04-13-2012, 07:41 PM
Price: $100.00
Pros: good quality
Cons: none
Recommended? Yes
Comments: very easy to install
jp3276
jp3276's Reviews
04-04-2012, 07:38 AM
Price: $85.00
Pros: Easy to install. Clear directions
Cons: none
Recommended? Yes
Comments: Great product. Was easy to install in the driveway with limited tools. Would rec'd to anyone looking for a good, small, body lift.
JuniorUSN
JuniorUSN's Reviews
03-09-2012, 03:02 AM
Price: $75.00
Pros: Works as intended.
Cons: None
Recommended? Yes
Comments: Works as intended.
MJ12
MJ12's Reviews
03-01-2012, 10:42 AM
Price: $80.00
Pros: Complete and simple to install kit. Due to them using polyurethane as the spacer, it may have an damping effect on body vibrations aiding the stock rubber isolators.
Cons: No cons noted.
Recommended? Yes
Comments: Body lift was installed in about 20 minutes. Rockmen has a video on the installation of this lift.
olaverty
olaverty's Reviews
01-06-2012, 10:07 PM
Price: $100.00
Pros: Complete kit, easy install, no problems
Cons: None
Recommended? Yes
Comments: It's a body lift. Not much more to say, no issues on install.
jmess
jmess's Reviews
12-19-2011, 05:44 PM
Price: $100.00
Cons: N/A
Recommended? Yes
Comments: Was easy to install and does exactly what it is made for.
nwaxtreme
nwaxtreme's Reviews
09-05-2011, 01:25 AM
Price: $70.00
Pros: Polyurethane instead of black craplastic
Cons: None
Recommended? Yes
Comments: 1.25 is as much bl as I wanna go so JKS fit perfect on the TJ.
They are they only ones I found that didnt make their body spacers out of hard plastic.
ThreadForumRepliesLast Post
Rough Country 1.25" body lift for JK Body Lifts 16 05-11-2015 07:44 PM
Performance Accessories 3 inch body lift3 inch body lift Body Lifts 20 02-15-2015 02:16 PM
Black Mountain 2" Body Lift Body Lifts 10 10-28-2013 11:00 AM
Prothane 87-95 YJ 1`` Body Lift Body Lifts 7 08-11-2013 06:58 PM
Prothane 76-79 CJ7 1" body lift Body Lifts 3 06-10-2011 05:58 PM
