GenRight - Body Mount Lift Kit, TJ/LJ Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts
Rating:
Product Information
MSRP: $99.99
Average Price: $100.00
Manufacturer: GenRight
Recommended?
Yes: 1 / No: 0
Company Website: http://www.genright.com/ProductInfo.aspx?productid=BMT2001
GenRight's mounts are Laser cut from Heavy Duty 3/16" thick plate steel and move the entire mount up on the frame.
FEATURES:
- 6 piece kit (3 for each side).
- Complete replacement mounts.
- Allows you to remove the 1" body lift puck.
- Mounts higher on the frame so it is less likely to get hit.
- Laser cut & formed from Heavy Duty 3/16" thick plate steel.
- 30% thicker material than stock mount.
- Sold as a set (two front, middle and rear mounts).
None
Sahara Surfer
Sahara Surfer's Reviews
08-11-2012, 09:41 AM
Price: $100.00
Pros: Improves clearance, by removing snag points. Gets rid of the ugly pucks. Beefy, 3/16" thick steel.
Cons: Actual lift difference in my set was not 1 inch as advertised but rather a little over 1.25 inches. Manual makes no reference to this discrepancy.
Recommended? Yes
Comments: I was doing a frame extension when I decided this would be a great alteration to do while the tub was out of the way. My Jeep has a 1" body lift already and this made sense. Not only would the mounts be less likely to get smacked while on the trails, but I had some ready made mounts to replace the mounts I would be cutting off.
When I received the mounts, I was impressed with their stoutness and what seemed like a precision cut construction. I was in for a bit of a surprise as far as the precision thing...
After I cut the first of my mounts off, I placed the Genright mount in its location and noticed that the gap between the tub and the top of the mount seemed really small. Note that I had not removed the bolts on the five other side body mounts and the tub was still at ride height.
I took some measurements and it seemed like the bracket offset was more like 1.25" rather than the advertised 1". I checked the other mount locations and they were all around the same range. At first, I thought it was my Jeep that was the oddity or that maybe I was not seating them properly to make accurate measurements. But it just so happens, that I have section of another TJ frame with their mounts still on them. I clamped the corresponding Genright mount on one and took some measurements:
As you can see from the images, it is closer to 1 3/8" this time.
On this image, you can verify that I compared it with the correct corresponding mount... look how the holes line up.
This is really not a big deal. It was no problem to grind off the extra material and after it was installed, it got the job done. I don't know if I just got a goofed up set or if they are all like that. If I had to guess, maybe they did that to accommodate all those 1.25" body lifts out there for the Rubicon owners. If this is the case, I wish they had made this clear in all their literature. I can see someone lifting the tub, rushing through this, and then being surprised when the other five mounts have gaps in them.
Needless to say, I do like these mounts and they have saved me fabrication time, which is why I would still recommend them.
ThreadForumRepliesLast Post
JKS 1.25" Body Lift Body Lifts 113 12-23-2016 04:32 PM
Performance Accessories 3 inch body lift3 inch body lift Body Lifts 23 06-05-2016 03:55 AM
Prothane 87-95 YJ 1`` Body Lift Body Lifts 8 06-08-2014 06:35 PM
Energy Suspension - Body mount bushings Body Lifts 3 12-24-2012 11:39 AM
Prothane 76-79 CJ7 1" body lift Body Lifts 3 06-10-2011 05:58 PM
