Daystar 1" poly body lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts Next Product
Rating:
Product Information
MSRP: $220.00
Average Price: $117.55
Manufacturer: Daystar
Recommended?
Yes: 104 / No: 2
A good 1" body lift is often the answer to the common oversized tire rub problem. Daystar combines the popular 1" body lift with polyurethane. These are not body puck spacers that you use with your conventional mounts. Longer polyurethane bushings replace the mushy factory rubber bushings to provide less body roll over conventional body lifts. Kits also include longer zinc plated bolts and body washers. The nice thing about a body lift is that it will not compromise the vehicles handling and ride characteristics. Limited Lifetime Warranty. Available in black, red or yellow. Will allow most 31" tires to fit (depends on width and offset).
None
Page 5 of 6 1 2 3 4 5 6 > Last
jeep94yj
jeep94yj's Reviews
09-06-2008, 08:58 AM
Price: $50.00
Recommended? Yes
Comments: One of my first upgrades - most people do a 3-4" body lift, this is a mistake as it puts to much flex on the body and causes stress cracks
dcswindler4
dcswindler4's Reviews
09-05-2008, 09:58 AM
Price: $94.00
Recommended? Yes
Comments: easy install, best body lift out there hands down. replaces everything, not just pucks
ballanjl
ballanjl's Reviews
09-02-2008, 11:41 PM
Price: $90.00
Recommended? Yes
Comments: They were easy to install with back yard mechanic tools. I substituted stainless steel hardware for the carbon steel bolts.
Poobah
Poobah's Reviews
07-09-2008, 06:36 PM
Price: $150.00
Recommended? Yes
Comments: I had a different body lift installed - teraflex - but when we went to install the Poison Spyder Ricochet Rockers, it turns out I had to upgrade to the poly... Probably a good thing - replaced those old bushings and whatnot...
phizer350
phizer350's Reviews
07-01-2008, 10:43 AM
Price: $137.00
Recommended? Yes
Comments: It was actually easy to install, for a body lift. Great quality. No problems so far. I highyl recommend if you need that extra inch to clear some tires.
longarm
longarm's Reviews
06-20-2008, 02:53 AM
Price: $125.00
Recommended? Yes
Comments: After installing this product I noticed a nice difference. I would recommend this product.
biged31
biged31's Reviews
06-14-2008, 11:25 AM
Price: $100.00
Recommended? Yes
Comments: Good kit, easy to install. Moving the fan shroud was a pain. Took about 2 hours to install the kit.
Dwayne93YJ
Dwayne93YJ's Reviews
06-10-2008, 02:43 PM
Price: $125.00
Recommended? Yes
Comments: I installed this when I realized that one two of my body mounts were still attached and not broken. Installation was time consuming, but the end result was what I wanted. Holding up very well after 1.5 years.
chrismw491
chrismw491's Reviews
06-08-2008, 11:01 PM
Price: $100.00
Recommended? Yes
Comments: 1" boddy lift helps with the 3" spring lift for more articulation...i would definately get them if you plan to go big
79BlackPearl
79BlackPearl's Reviews
06-08-2008, 01:07 AM
Price: $114.00
Recommended? Yes
Comments: Just installed. Product was easy to install. Only issue they left out 1 7/16" bolt.
Ghost00TJ
Ghost00TJ's Reviews
06-04-2008, 06:51 PM
Price: $135.00
Recommended? Yes
Comments: black poly, everything I needed and easy install by myself. Had to grind a little on front tub mount holes to fit metal portion n, no big deal. Had to cut slots in fan shroud in liou of MML.
TJ Flexer
TJ Flexer's Reviews
05-27-2008, 11:05 AM
Price: $145.00
Recommended? Yes
Comments: It is actually a Prothane BL but this is the closest I could get to the same lift using the forum's set-up. All and all it is a good lift and it came with a t-case linkage bracket
Jeebs
Jeebs's Reviews
05-14-2008, 01:22 AM
Price: $115.00
Recommended? Yes
Comments: I like the fact that it replaces the factory pucks. Some said it would squeak but after having it on for months I've heard nothing.
XTC Jpr13
XTC Jpr13's Reviews
05-08-2008, 10:11 PM
Price: $75.00
Recommended? Yes
Comments: gets the job done well and allows for a little more tire clearance. Straight forward install the is not difficult!
MugZy_YJ_94
ka-mai
MugZy_YJ_94's Reviews
05-02-2008, 03:50 AM
Price: $150.00
Recommended? Yes
Comments: nice and clean way to gain some extra clearance. very compleet kit, that install easy one you get the old stuff out.
discomonkey
discomonkey's Reviews
04-16-2008, 01:38 PM
Price: $125.00
Recommended? Yes
Comments: Hasn't started poping yet???
cj847
cj847's Reviews
04-14-2008, 10:01 PM
Price: $120.00
Recommended? Yes
Comments: No complaints. Easy install.
RVA_TJ06
RVA_TJ06's Reviews
04-01-2008, 11:00 PM
Price: $120.00
Recommended? Yes
Comments: Easy install.
oldballz
oldballz's Reviews
03-31-2008, 03:04 AM
Price: $50.00
Recommended? Yes
Comments: easy install, soft ride
Benderff
Benderff's Reviews
03-24-2008, 08:12 PM
Price: $98.00
Recommended? Yes
Comments: Good ride. No noise
ThreadForumRepliesLast Post
JKS 1.25" Body Lift Body Lifts 113 12-23-2016 04:32 PM
Performance Accessories 3 inch body lift3 inch body lift Body Lifts 23 06-05-2016 03:55 AM
Prothane 87-95 YJ 1`` Body Lift Body Lifts 8 06-08-2014 06:35 PM
Black Mountain 2" Body Lift Body Lifts 10 10-28-2013 11:00 AM
Prothane 76-79 CJ7 1" body lift Body Lifts 3 06-10-2011 05:58 PM
