Daystar 1" poly body lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts Next Product
Rating:
Product Information
MSRP: $220.00
Average Price: $117.55
Manufacturer: Daystar
Recommended?
Yes: 104 / No: 2
A good 1" body lift is often the answer to the common oversized tire rub problem. Daystar combines the popular 1" body lift with polyurethane. These are not body puck spacers that you use with your conventional mounts. Longer polyurethane bushings replace the mushy factory rubber bushings to provide less body roll over conventional body lifts. Kits also include longer zinc plated bolts and body washers. The nice thing about a body lift is that it will not compromise the vehicles handling and ride characteristics. Limited Lifetime Warranty. Available in black, red or yellow. Will allow most 31" tires to fit (depends on width and offset).
None
Page 3 of 6 1 2 3 4 5 6 > Last
Tomsatx
Tomsatx's Reviews
01-13-2011, 01:28 PM
Price: $125.00
Pros: Easy to install, price, does not reuse rubber mounts
Cons: none so far
Recommended? Yes
Comments: Great product! I almost got a JKS kit, but found out that their kits reuse the existing rubber mounts. This does not. Highly recommended from reviews I read and through others on the board.
Nicho
Nicho's Reviews
12-21-2010, 08:42 PM
Price: $140.00
Pros: One step closer to the Tummy Tuck
Cons: None so far
Recommended? Yes
Comments: Step towards my TT.
frAnken_rubi
frAnken_rubi's Reviews
12-05-2010, 10:38 AM
Price: $100.00
Pros: great body lift, easy to install
Cons: None
Recommended? Yes
Comments: Found this on ebay for a deal to good to pass up. Very easy to install and looks great.
patricknash1
patricknash1's Reviews
09-22-2010, 12:04 AM
Price: $150.00
Pros: Easy to install and very good ride quality
Cons: None
Recommended? Yes
Comments: The install took a few hours but was pretty easy, just had to keep moving the jack around to get the mounts in the right spot. Been great so far, ride quality feels good.
tanman2003
tanman2003's Reviews
08-28-2010, 09:04 PM
Price: $139.00
Pros: Good lift, rides better
Cons: reuses old parts, so if they are rusted out, you have to get new stuff, although I was lucky and my stuff wasn't that rusted
Recommended? Yes
Comments: I highly recommend this product for any wrangler.
FireJeep540
FireJeep540's Reviews
07-30-2010, 02:12 PM
Price: $150.00
Pros: excellent way to add an inch
Cons: more engine vibs transfer
Recommended? Yes
Comments: Only problem I have is the lack of directions that came with my setup. I like that it looks factory in away.
jeepwrangler97
jeepwrangler97's Reviews
07-26-2010, 11:54 PM
Price: $150.00
Pros: Drives better, complete replacement mounts, more clearance for raised gas tank and a tummy tuck.
Cons: The only real downside was reusing the stock steel inserts, one of them took me nearly half an hour to get out of the stock mount.
Recommended? Yes
Comments: If you have a pretty old Jeep, or rust, I would look into ordering at least a few of the mount inserts from the dealer, one of mine took a long time to get out and I don't have much rust on my TJ. Other than that, it is complete and I like the way the Jeep drives after, but I am also running poly engine and trans mounts as well.
eas0202233
eas0202233's Reviews
07-26-2010, 02:28 PM
Price: $100.00
Pros: quality
Cons: none
Recommended? Yes
Comments: Got it from amazon great price shipped fast
rocko-n-miss
rocko-n-miss's Reviews
07-19-2010, 11:11 PM
Price: $95.00
Pros: complete kit almost complete instructions.
Cons: fading,
Recommended? Yes
Comments: Wanted black they sent red, called they said their choice since out of stock??????? Really, thought I was the buyer! A phone call would have been nice. the red fades out quickly!
luckychris
luckychris's Reviews
06-24-2010, 05:39 PM
Price: $150.00
Pros: pretty easy to install, makes a nice difference in ride (vs the factory rubber)
Cons: none, aside from not being able to sit on bigger tires
Recommended? Yes
Comments: I really just wanted to replace my stock rubber with something a wee-bit taller, and never worry about replacing it again.
The kit was really easy to install, and I'm really pleased with the results
dropped74
dropped74's Reviews
06-06-2010, 09:27 PM
Price: $109.00
Pros: Gave me the needed lift and replaced worn out body mounts.
Cons: None
Recommended? Yes
Comments: This is a great product but the instructions could have been more detailed.
WillysEdition04
WillysEdition04's Reviews
05-12-2010, 05:16 PM
Price: $95.00
Pros: Replaces rubber mount, so no stacking of plastic and rubber pucks. Poly will last forever on this rig.
Cons: Poly makes for a slightly stiffer ride than rubber
Recommended? Yes
Comments: Pretty easy install, I like that it's one piece instead of stacking a puck on the factory bushing.
Jims-87YJ
Jims-87YJ's Reviews
05-09-2010, 06:46 PM
Price: $110.00
Pros: Nice kit everything included, Great Customer service!
Cons: Bought the red kit and after almost three years the front rad supports became real faded and started to deteriorate, called Daystar and they shipped out replacements!!!
Recommended? Yes
Comments: This kit is very nice, included everything, and there customer service is awesome.
akordboy
akordboy's Reviews
05-07-2010, 11:46 AM
Price: $1.00
Pros:
Cons:
Recommended? Yes
Comments:
Marctwayne
Marctwayne's Reviews
03-30-2010, 11:51 PM
Price: $120.00
Pros: Complete kit Full replacement of factory mounts
Cons: None so far
Recommended? Yes
Comments: Box showed up with everything that is needed. The parts went in with very little work. hardest part about doing the body lift was keeping 15 plus years of dirt out of your eyes. Oh the joys of working under a Jeep. Start to finish was about 2 hr.
bzoerb
bzoerb's Reviews
03-12-2010, 05:45 AM
Price: $150.00
Pros: polyurethane bushings replace the mushy factory rubber bushings to provide less body roll over conventional body lifts
Cons: seems good no neg
Recommended? Yes
Comments:
A good 1 body lift is often the answer to the common oversized tire rub problem. Daystar combines the popular 1 body lift with polyurethane. These are not body puck spacers that you use with your conventional mounts. Longer polyurethane bushings replace the mushy factory rubber bushings to provide less body roll over conventional body lifts. Kits also include longer zinc plated bolts and body washers. The nice thing about a body lift is that it will not compromise the vehicles handling and ride characteristics. Limited Lifetime Warranty. Available in black, red or yellow. Will allow most 31 tires to fit (depends on width and offset).
MountainGrizz
MountainGrizz's Reviews
02-24-2010, 01:40 PM
Price: $100.00
Pros: Added Wheel Tuck, Added Lift
Cons: Takes alot of time installing.
Recommended? Yes
Comments: I added the body lift to my 4" suspension lift, perfect ride for 35". I was able to raise my fuel tank 1" with the body lift, and now going to get a Belly Skid to raise my trasfer case.
weldonfoto
weldonfoto's Reviews
02-03-2010, 09:26 PM
Price: $140.00
Pros: well made, everything needed, easy install
Cons: not cheaper, wish it came with adapters for dropping the radiator shroud.
Recommended? Yes
Comments: Installed this body lift kit in about half a day intermixed with doing a few other things while the body was lifted from the frame. Was an easy install, mostly because my original body mounts were not rusted in like so many others older jeeps. Hardest part was figuring out how best to drop the radiator shroud but that was just making choices. 1" BL is just enough, any more would look bad and it gives my 29" tire just enough clearance on old/worn springs. Haven't notices any negative effects.
armywrench94
armywrench94's Reviews
11-09-2009, 10:18 PM
Price: $100.00
Cons: none
Recommended? Yes
Comments: Good quality body lift I would recomend this lift
Boodyrider
Boodyrider's Reviews
11-01-2009, 01:56 AM
Price: $50.00
Pros: lifts the body, clearance for BL, bellyup, and raised gas skid
Cons: reuses stock components
Recommended? Yes
Comments: So far has held up well.
ThreadForumRepliesLast Post
JKS 1.25" Body Lift Body Lifts 113 12-23-2016 04:32 PM
Performance Accessories 3 inch body lift3 inch body lift Body Lifts 23 06-05-2016 03:55 AM
Prothane 87-95 YJ 1`` Body Lift Body Lifts 8 06-08-2014 06:35 PM
Black Mountain 2" Body Lift Body Lifts 10 10-28-2013 11:00 AM
Prothane 76-79 CJ7 1" body lift Body Lifts 3 06-10-2011 05:58 PM
