Notices
Daystar 1" poly body lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Body Lifts Next Product
Rating:
Product Information
MSRP: $220.00
Average Price: $117.55
Manufacturer: Daystar
Recommended?
Yes: 104 / No: 2
A good 1" body lift is often the answer to the common oversized tire rub problem. Daystar combines the popular 1" body lift with polyurethane. These are not body puck spacers that you use with your conventional mounts. Longer polyurethane bushings replace the mushy factory rubber bushings to provide less body roll over conventional body lifts. Kits also include longer zinc plated bolts and body washers. The nice thing about a body lift is that it will not compromise the vehicles handling and ride characteristics. Limited Lifetime Warranty. Available in black, red or yellow. Will allow most 31" tires to fit (depends on width and offset).
None
Page 2 of 6 1 2 3 4 5 6 > Last
Hunter7158
Hunter7158's Reviews
01-05-2013, 10:40 PM
Price: $200.00
Pros: Easy Clearance for tires and other upgrades
Cons: None
Recommended? Yes
Comments: Forget the price I paid. Daystar makes great products with great instructions. Definitely would recommend.
Chuck_WeZy
Chuck_WeZy's Reviews
10-18-2012, 10:39 AM
Price: $100.00
Pros: Good instructions and allows for other mods by making room above the engine and drive train in general.
Cons: Larger BLs will alter center of gravity and the geometry of the Jeep.
Recommended? Yes
Comments: Very easy install to begin with but the instructions and pictures will eliminate any doubt. The only hard part is dealing with some tight spaces in the grille and seized bolts if your Jeep is older. I have no issues after over 5 years of use and abuse and I have given no maintenance besides checking the torque of the bolts.
yj94ne
yj94ne's Reviews
08-20-2012, 10:52 AM
Price: $115.00
Pros: ..
Cons: ..
Recommended? Yes
Comments: Seems good so far. Poly bushings are much better than the crushed 20 year old stock bushings
jrayzhunter
jrayzhunter's Reviews
06-20-2012, 11:40 AM
Price: $110.00
Pros: Easy Install Quality Product
Cons: None
Recommended? Yes
Comments: The body lift provided the perfect lift and was simple to install. (Harder for me because I had to fabricate new body mounts because the old ones sheared off the tub). Directions were easy to follow and no need to buy extra products. Could be installed in a couple of hours with limited problems.
jonji01
jonji01's Reviews
05-18-2012, 09:05 AM
Price: $150.00
Pros: Easy install
Cons: None
Recommended? Yes
Comments: Good product
flying76cj7
flying76cj7's Reviews
05-03-2012, 02:14 AM
Price: $120.00
Pros: all poly construction
Cons: none
Recommended? Yes
Comments: love it easy to install on my cj7
cavmedic
cavmedic's Reviews
03-30-2012, 02:31 PM
Price: $200.00
Pros: Replaced factory cab mounts as well as 1 inch lift
Cons: RED!!!
Recommended? Yes
Comments: Great product, strong!!!!!
Gainer
Gainer's Reviews
03-24-2012, 08:53 AM
Price: $155.00
Pros: Very easy install. took about 2 hours
Cons: none yet
Recommended? Yes
Comments: quick and easy install
Sundowner
Sundowner's Reviews
03-10-2012, 01:16 AM
Price: $125.00
Pros: Great fit, no problems with installation.
Cons: None
Recommended? Yes
Comments: This body lift went on in about an hour. The instructions could be slightly more clear, but once lay out all the parts in their given order there's really no way to get anything confused. The only issue we had was needing to slightly clearance two of the holes in the frame for the upper mount bushings to slip into, but an air grinder and carbide die made this a 15-second job. The galvanized hardware looks good, but I'll probably throw some primer and paint on it just to kill the brightness and give a touch more protection.
Tips for Installation:
- Leave the front mount loose and install it last.
- Jack the body up about 3/4" more than you think you need...this makes the crossmember mounts simple to install.
- Check the factory fog light wiring for needed length...
Ring611
Ring611's Reviews
01-14-2012, 09:35 PM
Price: $35.00
Pros: easy instal, great quality
Cons: directions
Recommended? Yes
Comments: Great product. east to install. make sure you loosen up your gas filler tube directions dont tell you and if you dont think about it you hear a crack and break your plactic gas cap. no big-e product is great quaility is great.
chrbone
chrbone's Reviews
12-20-2011, 10:58 AM
Price: $110.00
Pros: Comes with all parts needed to replace old bushings. Great customer service!!!
Cons: None
Recommended? Yes
Comments: Great product and sales/customer service team.
hotelconucc93
hotelconucc93's Reviews
11-16-2011, 10:45 AM
Price: $111.00
Pros: asdf asdsadf asdfasdfasdf asdf
Cons: fasdfasdfasdfasdfasdfasdfasdfasdfasdf asdf
Recommended? Yes
Comments: asdf asdfasdfs asdf asd asdf asd asd sadf asd asd
nofearwindham
nofearwindham's Reviews
10-27-2011, 11:29 AM
Price: $90.00
Pros: Easy install
Cons: Color fades
Recommended? Yes
Comments: I bought off of eBay way back for pretty cheap. Gave me clearance for 31s, I liked the looks of the red on my red jeep but the front ones faded to orange after a few years. They dont squeek and went on very easy.
Gobbles347
Gobbles347's Reviews
07-20-2011, 11:54 PM
Price: $147.00
Pros: Like that it is all new body mounts that are just 1in taller instead of pucks
Cons: none so far
Recommended? Yes
Comments: So far so good just installed them but love them the ride feels no different from stock, maybe even better
Carkinjim3
Carkinjim3's Reviews
06-21-2011, 12:26 PM
Price: $152.00
Pros: Great quality kit!
Cons: None
Recommended? Yes
Comments: This kit is a great value and very good quality. I'll never use any other brand!
Btowntaz
Btowntaz's Reviews
05-24-2011, 02:43 PM
Price: $100.00
Pros: Was very easy to install and didn't reuse any old parts.
Cons: Will have to adjust radiator shroud to keep fan from hitting.
Recommended? Yes
Comments: Took about 2 hours to install. Looks great!
cpistorius
cpistorius's Reviews
05-11-2011, 12:03 AM
Price: $100.00
Pros: Easy to install, durable, good reviews.
Cons: Don't go more than an inch or it will look horrible.
Recommended? Yes
Comments: The hardest thing about installing this was getting the old body mounts off, 20+ years of rust and mud takes it toll! Be careful not to jack up one side too far, or bad things can happen.
twoleos617
twoleos617's Reviews
02-25-2011, 02:32 PM
Price: $80.00
Pros: Well built Looks great
Cons: None
Recommended? Yes
Comments: Got a great deal on amazon and shipped free. This product is well thought out and built to last. Looks good under the rig but doesnt stand out that you have lifted the body. Worth the time and money!
Beefalobart
Beefalobart's Reviews
02-11-2011, 01:07 AM
Price: $160.00
Pros: Looks great and comes with everything
Cons: none
Recommended? Yes
Comments: Best way to get an inch on the body spec when using a 1" motor mount lift to keep everything in line. Also with only 1" you gain that in wheel clearance and less of the unsightly gap with larger body lifts.
YJoe1993
YJoe1993's Reviews
01-18-2011, 03:23 AM
Price: $100.00
Pros: Replaces old rubber mounts. Does not look bad
Cons: nothing at all
Recommended? Yes
Comments: This 1" BL is great. The fact that it replaced old mounts while adding 1" of a lift was awesome. It was not too hard to install either.
ThreadForumRepliesLast Post
JKS 1.25" Body Lift Body Lifts 100 07-21-2015 01:28 PM
Performance Accessories 3 inch body lift3 inch body lift Body Lifts 20 02-15-2015 02:16 PM
Black Mountain 2" Body Lift Body Lifts 10 10-28-2013 11:00 AM
Prothane 87-95 YJ 1`` Body Lift Body Lifts 7 08-11-2013 06:58 PM
Prothane 76-79 CJ7 1" body lift Body Lifts 3 06-10-2011 05:58 PM
