Off Road Only - Off Road Only ADE-II Theft Protection Device Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Consoles, Security & Storage Next Product
Rating:
Product Information
MSRP: $49.99
Average Price: $49.99
Manufacturer: Off Road Only
Recommended?
Yes: 2 / No: 0
Company Website: http://www.offroadonly.com/
Got a Jeep Wrangler?
Leave it parked with the top off during the summer?
Got a manual transmission?
All it takes is someone to pop the ignition lock, start the vehicle and drive away with your Jeep!
Once installed, the ADE-II System will automatically disable multiple electrical systems that your vehicle requires to run. For the Jeep TJ, these systems are: Ignition System, Fuel Pump, Fuel Injectors, and the Automatic Shut Down Relay.
With the ADE-II installed, after the ignition key is turned to the run position, you swipe one of the supplied magnets past the hidden switch that you pick where to install behind the plastic dash, and the relay will re enable the electronic circuits that were disabled.
Now, unless the thief knows where to pass the magnet, or has the wherewithal to figure out why its not starting, most likely you'll find the Jeep with a broken lock cylinder... and not just find its tracks.
There is a by-pass built in, so on a day where you're on the trail or you may have others driving your Jeep, you can make a simple connection and by-pass the system, so others don't need to know the position of the magnet.
The install manual is documented for Jeep Wrangler TJ's, from 1997 to 2006 models. This system may be used on any vehicle, with or without fuel injection, just need to properly determine which circuit to interrupt.
None
OZFive
OZFive's Reviews
04-10-2011, 05:37 PM
Price: $49.99
Pros: Simple installation. Does what it is supposed to. Looks like no security system is installed, easy to use. Clear instructions.
Cons: The wire crimps were too hard to clamp down and I ended up replacing them.
Recommended? Yes
Comments: Works like a charm and everything is taped up and mounted so that it canot be seen and looks OEM.
I feel much better about my Jeep sitting top and doorless in parking lots and on the street.
briguy3030
briguy3030's Reviews
03-07-2011, 06:44 PM
Price: $49.99
Pros: Works as advertised Easy install even for electric novice Cheap price System bypass feature
Cons: None
Recommended? Yes
Comments: Amazing how clipping one wire & splicing in this little package will change the way your Jeep will survive out on the mean streets!
Instructions included a detailed, in-depth & include clear, concise wiring diagrams & pictures for all TJ's
Definitely satisfied & feel more secure in during those topless & doorless summers let alone 365 days a year
ThreadForumRepliesLast Post
M.O.R.E (Mountain Off Road Engineering) Lift for TJ's: BLTJ97 Body Lifts 15 12-23-2015 08:58 PM
Smittybilt Roof Rack & Off Road Basket Roof Racks & Cargo Areas 5 07-09-2014 01:57 PM
Off Road Only LiteDOTs™ LED Tail lights Lighting, Lenses & Bulbs 10 05-23-2014 09:01 AM
Pilot - NV-802CP 6" Off Road Utility Lights Lighting, Lenses & Bulbs 5 04-05-2012 08:45 PM
Off Road Only LiteDOTS LED Tail Lights Lighting, Lenses & Bulbs 12 09-14-2011 05:00 PM
