Comments: 60k on first set of 35's and just put on the second set. Cleans out great for mud and snow, floats on sand better than most mud grip tires I have used, grips rocks and when aired down conforms to the rock and pulls you over it. Road noise is significantly less than most mud tires. Pavement traction is outstanding, cornering and even heavy braking these tires just stick it everytime.
Siskle and Ebert would say
2 thumbs up!
The only con I can even think about is the lack of sidewall tread when you get in a tight washout and need the sidewall of the tire to pull you though. Although even as they are they do OK
